PostgreSQL extension
  • Latest Dynatrace
  • Extension
  • Published Oct 27, 2025
Monitor your Postgres performance via our new EF2.0 extension framework.
1 of 2
Get started
Overview
PostgresSQL monitoring solution is based on a remote monitoring approach implemented as a Dynatrace ActiveGate extension. The extension queries Postgres databases for key performance and health. Dynatrace's DAVIS AI then analyzes these metrics to provide anomaly and problem analysis.
Use cases
  • Monitor the health state and performance of their PostgreSQL setup.
  • Detect anomalies and alert on them.
  • Take pre-emptive measures to avoid service degradations.
Requirements
  • There must be connectivity between the ActiveGate, where the extension is deployed, and the Postgres database.
  • Database user with proper permissions must be provided. Example:
    CREATE USER dynatrace WITH PASSWORD '<PASSWORD>' INHERIT;
    GRANT pg_monitor TO dynatrace;
For top query monitoring:
  • pg_stat_statements view (must be enabled)[https://www.postgresql.org/docs/current/pgstatstatements.html#PGSTATSTATEMENTS].
  • pg_stat_statements.track_planning must be turned on to enable plan fetching.
For execution plan details monitoring:
  • Special dynatrace.dynatrace_execution_plan function must be created in the database, to which you will connect and from which the execution plans will be fetched.
    CREATE SCHEMA dynatrace;
    CREATE OR REPLACE FUNCTION dynatrace.dynatrace_execution_plan(
    query text,
    OUT explain JSON
    ) RETURNS SETOF JSON
    LANGUAGE plpgsql
    VOLATILE
    RETURNS NULL ON NULL INPUT
    SECURITY DEFINER
    ROWS 1
    SET plan_cache_mode = force_generic_plan
    AS
    $$DECLARE
    arg_count integer;
    open_paren text;
    close_paren text;
    explain_cmd text;
    json_result json;
    BEGIN
    /* reject statements containing a semicolon in the middle */
    IF pg_catalog.strpos(
    pg_catalog.rtrim(dynatrace_execution_plan.query, ';'),
    ) OPERATOR(pg_catalog.>) 0 THEN
    RAISE EXCEPTION 'query string must not contain a semicolon';
    END IF;
    /* get the parameter count */
    SELECT count(*) INTO arg_count
    FROM pg_catalog.regexp_matches( /* extract the "$n" */
    pg_catalog.regexp_replace( /* remove single quoted strings */
    'g'
    '\$\d{1,}',
    'g'
    IF arg_count OPERATOR(pg_catalog.=) 0 THEN
    open_paren := '';
    close_paren := '';
    ELSE
    open_paren := '(';
    close_paren := ')';
    END IF;
    /* construct a prepared statement */
    EXECUTE
    pg_catalog.concat(
    'PREPARE _stmt_',
    open_paren,
    pg_catalog.rtrim(
    pg_catalog.repeat('unknown,', arg_count),
    close_paren,
    ' AS ',
    /* construct an EXPLAIN statement */
    explain_cmd :=
    pg_catalog.concat(
    'EXPLAIN (FORMAT JSON, ANALYZE FALSE) EXECUTE _stmt_',
    open_paren,
    pg_catalog.rtrim(
    pg_catalog.repeat('NULL,', arg_count),
    close_paren
    /* get and return the plan */
    EXECUTE explain_cmd INTO json_result;
    RETURN QUERY SELECT json_result;
    /* delete the prepared statement */
    DEALLOCATE _stmt_;
    END;$$;
    Notice that the function above is defined with SECURITY DEFINER, meaning it executes with the privileges of the user who defined it, not the one executing it. This is due to the fact that the permissions required to EXPLAIN a query are the same as the one required to run that query, meaning that the user with which this function is defined needs to have a sufficient priveliges to run PREPARE and EXPLAIN on the queries it will be explaining. As such, for full functionality ensure that the function is defined with the appropriate user.
  • The monitoring user will need to have USAGE grant on the dynatrace schema.
    GRANT USAGE ON SCHEMA dynatrace to <username>
  • In some PostgreSQL configurations you might also need to set search_path for the monitoring user:
    ALTER USER dynatrace SET search_path to dynatrace, public;
Compatibility information
  • PostgreSQL version 11+.
Activation and setup
Dynatrace version 1.255+
To activate remote monitoring:
  1. In Dynatrace Hub Hub, select PostgreSQL.
  2. Select Install.
  3. Add new monitoring configuration.
Details
Licensing and cost
The metrics collected through this extension consume Dynatrace Davis Data Units (see DDUs for metrics).
A rough estimation of the amount of DDUs consumed by metric ingest can be obtained through the following formula:
( (11 * number of instances)
+ (29 * number of databases)
+ (1 * number of tablespaces)
) * 525.6 DDUs/year
For logs, regular DDU consumption for log monitoring applies. Depending on your licensing model, refer either to DDU consumption for Log Management and Analytics or DDUs for Log Monitoring Classic.
If your license consists of Custom Metrics, each custom metric is equivalent to 525.6 DDUs/yr. For more information, see Metric Cost Calculation.
Monitoring top queries
If both the Dynatrace log monitoring is enabled and the pg_stat_statements view is available, Dynatrace will ingest the top 100 queries (sorted by total execution time) every 5 minutes and store them as logs. These logs are available either from the database instance screen or on the Databases App, under Top queries by total execution time.
To filter by these queries on a dashboard or notebook, one can filter by dt.extension.name = com.dynatrace.extension.postgres and event.group = top_queries. See below a DQL query example:
fetch logs
| filter dt.extension.name=="com.dynatrace.extension.postgres" and event.group=="top_queries"
| sort total_exec_time desc
Regardless of whether pg_stat_statements is available or not, Dynatrace will still collect queries from pg_stat_activity as part of the Queries feature set, which are similarly ingested as logs with event.group = longest_queries.
Fetching execution plan details
For SaaS users who have access to the Databases app and who have top query monitoring enabled (see previous section), fetching execution plans for these queries is possible. This can be done from the Databases app, under Statement performance, by clicking Request on the execution plan for a specific query.
For that query, the extension will then attemp to execute the following:
SELECT * from dynatrace.dynatrace_execution_plan({query})
and then ingest into Dynatrace the first row of the column named explain. These execution plans are ingested as logs with event.group = execution_plans.
Feature sets
When activating your extension using monitoring configuration, you can limit monitoring to one of the feature sets. To work properly the extension has to collect at least one metric after the activation.
Metric nameMetric keyDescription
Latest transaction XID agepostgres.xid_ageDifference between the current transaction's XID and datfrozenxid. If this value exceeds 2^31, this can cause a database crash due to transaction ID wraparound.
Number of backendspostgres.numbackendsNumber of backends currently connected to this database
Committed transactionspostgres.xact_commit.countNumber of transactions in this database that have been committed
Rolled back transactionspostgres.xact_rollback.countNumber of transactions in this database that have been rolled back
Block read from diskpostgres.blks_read.countNumber of disk blocks read in this database
Blocks found in buffer cachepostgres.blks_hit.countNumber of times disk blocks were found already in the buffer cache, so that a read was not necessary
Live rows returnedpostgres.tup_returned.countNumber of live rows fetched by sequential scans and index entries returned by index scans in this database
Live rows fetched by index scanspostgres.tup_fetched.countNumber of live rows fetched by index scans in this database
Rows insertedpostgres.tup_inserted.countNumber of rows inserted by queries in this database
Rows updatedpostgres.tup_updated.countNumber of rows updated by queries in this database
Rows deletedpostgres.tup_deleted.countNumber of rows deleted by queries in this database
Queries canceled due to conflictpostgres.conflicts.countNumber of queries canceled due to conflicts with recovery in this database
Temporary files createdpostgres.temp_files.countNumber of temporary files created by queries in this database
Data written to temporary filespostgres.temp_bytes.countTotal amount of data written to temporary files by queries in this database
Deadlockspostgres.deadlocks.countNumber of deadlocks detected in this database
Data file blocks reading timepostgres.blk_read_time.countTime spent reading data file blocks by backends in this database
Data file blocks writing timepostgres.blk_write_time.countTime spent writing data file blocks by backends in this database
Database Sizepostgres.db_sizeSize of the database in bytes
Data page checksum failurespostgres.checksum_failures.countNumber of data page checksum failures detected in this database. Only available if data checksums are enabled.
Time spent by sessionspostgres.session_time.countTime spent by database sessions in this database
Time spent executing SQL statementspostgres.active_time.countTime spent executing SQL statements in this database
Time spent idlingpostgres.idle_in_transaction_time.countTime spent idling while in a transaction in this database
Established sessionspostgres.sessions.countTotal number of sessions established
Abandoned sessionspostgres.sessions_abandoned.countNumber of database sessions to this database that were terminated because connection to the client was lost
Fatal error terminated sessionspostgres.sessions_fatal.countNumber of database sessions to this database that were terminated by fatal errors
Killed sessionspostgres.sessions_killed.countNumber of database sessions to this database that were terminated by operator intervention
Scheduled checkpoints performedpostgres.checkpoints_timed.countNumber of scheduled checkpoints that have been performed
Requested checkpoints performedpostgres.checkpoints_req.countNumber of requested checkpoints that have been performed
Checkpoints write timepostgres.checkpoint_write_time.countTotal amount of time that has been spent in the portion of checkpoint processing where files are written to disk
Checkpoint sync timepostgres.checkpoint_sync_time.countTotal amount of time that has been spent in the portion of checkpoint processing where files are synchronized to disk
Buffers written during checkpointspostgres.buffers_checkpoint.countNumber of buffers written during checkpoints
Buffers written by background writerpostgres.buffers_clean.countNumber of buffers written by the background writer
Cleaning scan stopspostgres.maxwritten_clean.countNumber of times the background writer stopped a cleaning scan because it had written too many buffers
Buffers written by backendpostgres.buffers_backend.countNumber of buffers written directly by a backend
Backend fsync executionspostgres.buffers_backend_fsync.countNumber of times a backend had to execute its own fsync call
Buffers allocatedpostgres.buffers_alloc.countNumber of buffers allocated
Replication WAL restart delaypostgres.replication.restart_delayDifference between current WAL LSN and the restart_lsn as reported by pg_replication_slots
Replication WAL confirmed flush lagpostgres.replication.confirmed_flush_lagDifference between current WAL LSN and the confirmed_flush_lsn as reported by pg_replication_slots
Replication WAL write lagpostgres.replication.write_lagTime elapsed between flushing recent WAL locally and receiving notification that this standby server has written it, as reported by pg_stat_replication.
Replication WAL flush lagpostgres.replication.flush_lagTime elapsed between flushing recent WAL locally and receiving notification that this standby server has written and flushed it, as reported by pg_stat_replication.
Replication WAL replay lagpostgres.replication.replay_lagTime elapsed between flushing recent WAL locally and receiving notification that this standby server has written, flushed and applied it, as reported by pg_stat_replication.
Instance uptimepostgres.uptimeTime since the instance has been started
Active backend processespostgres.activity.activeNumber of server processes executing a query
Idle backend processespostgres.activity.idleNumber of server processes waiting for a new client command
Idle in transaction backends processespostgres.activity.idle_in_transactionNumber of server processes in transaction not currently executing a query
Idle in transaction aborted backends processespostgres.activity.idle_in_transaction_abortedNumber of server processes in transaction not currently executing a query where one of the statements caused an error
Fast-path function backend processespostgres.activity.fastpath_function_callNumber of server processes executing a fast-path function call
Number of lockspostgres.locksNumber of locks as reported by pg_locks
Instance recovery modepostgres.recovery.stateIndicate that the instance is in recovery mode. 1 if in recovery, 0 otherwise.
Tablespace sizepostgres.tablespace.sizeTablespace size in bytes
WAL diff sizepostgres.wal_diff_sizeSize of difference between current WAL and last WAL replay
WAL records per minutepostgres.wal_records.countNumber of WAL records generated per minute
WAL fpi per minutepostgres.wal_fpi.countNumber of WAL full page images generated per minute
WAL bytespostgres.wal_bytes.countTotal amount of WAL generated in bytes
WAL buffers fullpostgres.wal_buffers_full.countNumber of times WAL data was written to disk because WAL buffers became full
WAL writepostgres.wal_write.countNumber of times WAL buffers were written out to disk via XLogWrite request
WAL syncpostgres.wal_sync.countNumber of times WAL files were synced to disk via issue_xlog_fsync request
WAL write timepostgres.wal_write_time.countTotal amount of time spent writing WAL buffers to disk via XLogWrite request, in milliseconds
WAL sync timepostgres.wal_sync_time.countTotal amount of time spent syncing WAL files to disk via issue_xlog_fsync request, in milliseconds
Limitations
Top queries:
  • For security reasons ALTER statements are excluded from top query collection.
Execution plan details:
  • Only available to SaaS users with DB App installed. The extensions:configuration.actions:write permission is required to trigger the execution plan fetching.
  • Execution plan can only be fetched from the database where dynatrace.dynatrace_execution_plan function has been created.
FAQ
This extension will run from your Dynatrace ActiveGates and connect to the configured databases. Once the connection has been established, the extension will regularly run queries on the database to gather performance and health metrics, reporting the results back to Dynatrace.
Only SELECT queries are executed to collect data. To see exactly which queries are executed, download the extension yaml artifact by going to Release notes, opening a release and pressing the Download version button.
From version 2.3.0 onwards, query execution frequency is controlled by the configuration variables query-interval and heavy-query-interval. Most of the queries executed by the extension will run every query-interval minutes (with a default of 1 minute), while the queries under the Queries feature set will run every heavy-query-interval minutes (with a default of 5 minutes).
For older versions, most queries run every minute, with exceptions for the heavy queries mentioned above, which run every 5 minutes.
In order to support a wide range of Postgres versions we need to have several versions of the same queries running at the same time, since over time Postgres has changed column names for several tables. As such, it is expected for some queries to fail, but as long as there is no missing data, there is no cause for concern.
Related tags
DatabaseSQLSQLPostgresApplication Observability
