Monitor your MongoDB servers either locally or remotely!
Connect your MongoDB servers either remotely and locally. A collective batch of data is gathered every minute by this extension and sent to the Dynatrace platform for detailed analysis.
serverStatus@admin, listDatabases, and dbStats permissions. The MongoDB Built In Cluster Monitor Role has these permissions already set up.Along with the username and password you can configure the extension to:
authSource property in the connection string).tlsCAFile argument of the MongoClient).tlsCertificateKeyFile of the MongoClient).
These file paths need to be accessible on all ActiveGates in the group or locally on the OneAgent Host
SCRAM-SHA-1, SCRAM-SHA-256, PLAIN, DEFAULT.
If no mechanism is specified, PyMongo will automatically use a default value depending on MondoDB version.
SCRAM-SHA-1SCRAM-SHA-1 or SCRAM-SHA-256The formula for consumption of the extension is:
Per connected process/port: (17 + 5 * <# of Databases>)
Activating the extension locally consumes the included metrics per host unit.
When activating your extension using monitoring configuration, you can limit monitoring to one of the feature sets. To work properly the extension has to collect at least one metric after the activation.
| Metric name | Metric key | Description |
| Locks - Current Global Queue | mongodb.locks.global_current_queue | The number of operations queued because of a lock. |
| Locks - Global Total Time | mongodb.locks.global_total_time | The time, in microseconds, since the database last started and created the globalLock. This is roughly equivalent to total server uptime. |
| Locks - Current Global Acquired Locks | mongodb.locks.global_acquire | Number of times the lock was acquired in the specified mode. |
| Locks - Current Global Aqcuired Waits | mongodb.locks.global_acquire_wait | Number of times the lock acquisitions encountered waits because the locks were held in a conflicting mode. |
| Locks - Global Time Acquired (Microseconds) | mongodb.locks.global_time_acquire | Cumulative wait time in microseconds for the lock acquisitions. |
| Locks - Current Global Deadlocks | mongodb.locks.global_deadlocks | Number of times the lock acquisitions encountered deadlocks. |
| Current connections | mongodb.current_connections | — |
| Available connections | mongodb.available_connections | — |
| Insert operations | mongodb.insert_operations2.count | — |
| Query operations | mongodb.query_operations2.count | — |
| Update operations | mongodb.update_operations2.count | — |
| Delete operations | mongodb.delete_operations2.count | — |
| Getmore operations | mongodb.getmore_operations2.count | — |
| Command operations | mongodb.command_operations2.count | — |
| Resident memory | mongodb.resident_memory | — |
| Virtual memory | mongodb.virtual_memory | — |
| Current queue | mongodb.current_queue | — |
| Active clients | mongodb.active_clients | — |
| Regular asserts | mongodb.regular_asserts2.count | — |
| Warning asserts | mongodb.warning_asserts2.count | — |
| Message asserts | mongodb.message_asserts2.count | — |
| User asserts | mongodb.user_asserts2.count | — |
| Rollover asserts | mongodb.rollover_asserts2.count | — |
| Page Faults | mongodb.page_faults | The total number of page faults |
| Uptime | mongodb.uptime | The number of seconds that the MongoDB process has been active. |
| Objects | mongodb.db.objects | — |
| Indexes | mongodb.db.indexes | — |
| Data size | mongodb.db.db_data_size | — |
| Storage size | mongodb.db.db_storage_size | — |
| Index size | mongodb.db.db_index_size | — |
| Replica Set - Oplog Size | mongodb.rs.oplog_size | The range between the earliest and latest oplog entires |
| Replica Set - Oplog Window | mongodb.rs.oplog_window | The time window covered by the oplog (Replication headroom) |
| Cache - Pages Requested | mongodb.cache.pages_requested | Number of pages reqeusted from the cache |
| Cache - Pages Read | mongodb.cache.pages_read | Number of pages read into the cache |
