Metric selector conversion guide
  • Latest Dynatrace
  • How-to guide
  • 20-min read
Grail metrics are queried with DQL, while classic metrics are queried using metric selectors. This guide shows how to convert classic metric selector expressions to DQL so you can smoothly and efficiently transition to Grail.
Automatically convert metric selectors to DQL
To make converting queries easier, Data Explorer and Dashboards Classic can now help you transform your existing metric selector queries into DQL.
Because there isn't an exact, one-to-one mapping between Classic metric selectors and DQL, some queries will require manual adjustments during the conversion. The troubleshooting section on this page can help you in these scenarios.
In this section, you'll learn how to use the conversion tool in Dynatrace to produce DQL from existing Classic metric selectors.
From Data Explorer to Notebooks or Dashboards
To automatically convert the metric selector to a DQL query in Notebooks or Dashboards
  1. Go to Data Explorer to create and run your query.
    Data Explorer: standard view
    The metric selector for this query in the advanced mode reads as:
    builtin:host.cpu.usage:splitBy("dt.entity.host"):sort(value(auto,descending)):limit(20)
  2. Select Open with… in the upper-right corner of the Data Explorer Result section.
    Data Explorer: Open with
  3. Follow the on-screen instructions to:
    • Select a destination application (Notebooks or Dashboards)
    • Select a destination document (a new or existing notebook or dashboard, depending on the destination application you selected)
  4. When the destination document is displayed, verify the resulting query.
    Notebook DQL
    In our example, the resulting query is
    timeseries usage = avg(dt.host.cpu.usage), by: { dt.entity.host }
    | sort arrayAvg(usage) desc
    | fieldsAdd entityName(dt.entity.host)
    | limit 20
    If you have questions, see the troubleshooting section.
Manually convert metric selectors to DQL
If your metric selector is not automatically convertable, in this section you'll learn how to manually convert your metric selector to DQL.
  1. Verify whether your metric can be converted by searching Built-in Metrics on Grail to find some metrics that have focused migration guides.
  2. Check that all Classic transformations in your metric selector are supported.
  3. Begin converting your metric selector with a focus on the DQL timeseries command. Several aggregations and transformations, including filter and splitBy, can be included in this initial command.
  4. Remaining arithmetic and transformations that do not belong in the timeseries command can be added by additional commands as illustrated below.
Troubleshooting Converted DQL
How can I find the new metric key for my Classic metric on Grail?
A list of Classic metrics and their equivalents in Grail can be found in the Built-in Metrics on Grail. Bear in mind that not all Classic metrics have Grail equivalents migration guides, and some metrics are not yet supported on Grail.
Why doesn't my Classic metric work in DQL?
You should use Grail metrics when querying DQL. A list of Classic metrics and their equivalents in Grail can be found in Built-in Metrics on Grail.
Some metrics, such as those prefixed with builtin:apps, are not supported on Grail and cannot be queried with DQL. The full list is available on Built-in Metrics on Grail.
Why can't I use the "Open with…" button in Data Explorer?
Not all Classic metric selectors have equivalent DQL. If you're not sure whether your Classic metric is supported on Grail, look it up on Built-in Metrics on Grail.
Why doesn’t my new DQL query result match exactly after I converted my metric selector?
In the process of transitioning from classic queries to Grail in Dynatrace, you might notice some differences in your query results. This is expected, as not all classic metrics have direct equivalents in Grail. However, if you encounter differences where you expect the queries to match, the following scenarios might help explain why.
It's possible that none of the following scenarios describe your query if you converted your Metrics Classic selector yourself. Try creating the DQL using the transpiler and comparing the results.
Aggregations
In DQL, there are equivalent aggregations for avg, sum, min, max, count, and percentile.
builtin:host.cpu.usage:splitby():avg
For example, the Classic metric selector query above can be converted to DQL as follows:
timeseries avg(dt.host.cpu.usage)
Time aggregation
Specifying a time aggregation is possible with both the Metrics Classic metric selector and DQL.
builtin:host.cpu.usage:max:splitby():avg
The example above calculates the average maximum CPU usage across all hosts. It can be converted to DQL with the rollup parameter as follows:
timeseries avg(dt.host.cpu.usage, rollup:max)
Median aggregation
You can reproduce the Metrics Classic median aggregation with the parametrized function percentile(..., 50).
builtin:host.cpu.usage:avg:splitby():median
For example, the Metrics Classic metric selector query above can be converted to DQL as follows:
timeseries median=percentile(dt.host.cpu.usage, 50, rollup:avg)
Value aggregation
The Metrics Classic value aggregation performs a sum for count metrics, and is therefore equivalent to the timeseries sum aggregation.
builtin:service.requestCount.total:splitBy():value
timeseries sum(dt.service.request.count)
Auto aggregation
The Metrics Classic metric selector includes a pseudo-aggregation called auto. Based on the metric's metadata, auto selects the default aggregation for that metric. DQL doesn't have an equivalent pseudo-aggregation, however, so you need to explicitly specify the aggregation.
builtin:host.cpu.usage:splitby():auto
For example, the Metrics Classic metric builtin:host.cpu.usage defaults to the avg aggregation. Therefore, the Metrics Classic metric selector above can be converted to DQL as follows:
How can I find my metric's default aggregation?
Custom metrics can be determined from the metric key directly. A Metrics Classic metric.key with the .count suffix uses the value aggregation by default (and therefore will use a sum in the converted DQL). All other custom metrics use the avg aggregation by default.
For non-custom metrics (generally metric keys that contain a colon :), there are two options:
  1. Use the automatic converter to convert a simple metric selector such as
  2. Look up the defaultAggregation property of your metric's metadata via the Metrics Classic Metrics browser or the metric metadata API.
What if my metric selector is missing an aggregation?
Because Metrics Classic metric selectors don't require an explicit aggregation, it's possible to omit the aggregation entirely. The auto transformation is used implicitly in these cases.
Consequently, this metric selector is equivalent to the examples above.
Count aggregation
The vast majority of Metrics Classic count aggregations return cardinality–the number of series represented by a metric. The DQL count function returns cardinality as well.
builtin:host.cpu.usage:splitBy():count
For example, many Dynatrace users want to count the number of hosts. This selector is converted to DQL as follows:
timeseries num_hosts = count(dt.host.cpu.usage)
Variation: count observations
The Metrics Classic count transformation does ultimately depend on the metric metadata. In some scenarios, count returns the number of observations reported to a metric. This behavior is uncommon but nevertheless useful in these scenarios.
record_processing_time:splitBy("host.name"):count
The above metric selector queries a hypothetical custom metric. As a custom metric without the .count suffix (see below), the count transformation here calculates the count of records processed. The converted DQL uses sum(..., rollup:total):
timeseries records_processed = sum(record_processing_time, rollup:total)
How do I know if my query counts observations or cardinality?
The final behavior of count ultimately depends on a number of conditions. The automatic converter performs all these checks for you. You can provide a simple metric selector and determine from the resulting DQL which count is performed. For example:
Group by
The Metrics Classic splitBy transformation is replaced by the timeseries by parameter.
builtin:service.requestCount.total:splitBy("dt.entity.service"):sum
For example, the Metrics Classic metric selector queries above can be converted to DQL as follows:
timeseries sum(dt.service.request.count), by:{dt.entity.service}
Merge
The Metrics Classic merge transformation is a counterpart to the splitBy transformation. There is no equivalent to merge in DQL, as it can be expressed equivalently with splitBy.
builtin:host.net.nic.bytesRx:merge("dt.entity.network_interface"):avg
Because the Metrics Classic metric builtin:host.net.nic.bytesRx has two dimensions, dt.entity.host and dt.entity.network_interface, the above merge on dt.entity.network_interface is equivalent to a split on dt.entity.host:
builtin:host.net.nic.bytesRx:splitBy("dt.entity.host"):avg
Consequently, the metric selector can be converted to DQL as described in the split by transformation section:
timeseries bytes_rx=avg(dt.host.net.nic.bytes_rx), by:{dt.entity.host}
Filter
The Metrics Classic filter transformation is equivalent to the timeseries filter parameter.
builtin:cloud.aws.dynamo.tables
:filter(
in(
"dt.entity.aws_availability_zone",
entitySelector("type(aws_availability_zone),entityName.equals(~"us-east-1a~")")
):splitBy():sort(value(auto,descending)):limit(20)
As Metrics Classic filter transformations rely on entity selectors, the same syntax is readily supported in DQL with the classicEntitySelector function.
timeseries tables=avg(dt.cloud.aws.dynamo.tables),
by:{dt.entity.aws_availability_zone},
filter:{
in(
dt.entity.aws_availability_zone,
classicEntitySelector("type(aws_availability_zone),entityName.equals(\"us-east-1a\")")
Filter conditions
The following table shows Metrics Classic filter conditions and their equivalent DQL.
Classic filter conditionDQL function
prefixstartsWith
suffixendsWith
containscontains
eq== equals
ne!= not equals
inin
seriesConstructed from comparisons to array functions
existsKeyNot supported on Grail
remainderNot supported on Grail
Entity selector existsKey and remainder have no equivalent in DQL and are ignored at conversion.
How do I convert series filter conditions?
The Metrics Classic series condition consists of an aggregation and a comparison operator, which can be reconstructed from array functions and comparison operators respectively.
builtin:host.disk.usedPct
:filter(series(avg,gt(20)))
timeseries percent = avg(dt.host.disk.used.percent),
by:{dt.entity.host}
| filter arrayAvg(percent) > 20
In this example, avg is replaced by arrayAvg, and gt is replaced by the > (greater than) operator.
Arithmetic
DQL uses variable assignment and sequential commands to improve on the arithmetic in Metrics Classic metric queries. You can learn more in DQL operators.
100 * builtin:kubernetes.resourcequota.limits_memory_used
/ builtin:kubernetes.resourcequota.limits_memory
:splitBy("dt.entity.cloud_application_namespace","k8s.resourcequota.name")
The above metric selector query is formatted to highlight difference with the following converted DQL.
timeseries
limits_memory_used=avg(dt.kubernetes.resourcequota.limits_memory_used),
limits_memory=avg(dt.kubernetes.resourcequota.limits_memory),
by:{dt.entity.cloud_application_namespace, k8s.resourcequota.name}
| fieldsAdd
// use square brackets [] to perform timeseries arithmetic
limits_memory_usage = 100 * limits_memory_used[] / limits_memory[]
There is a clear difference in the approach taken with DQL. Metrics Classic metric selectors mix arithmetic with queries, whereas DQL separates these steps: first you assign the inputs, and then you perform the calculation within a fieldsadd command.
This approach is both easier to read and easier to write:
  • Operations are shorter and clearer by using descriptive variables instead of long expressions.
  • Variable assignment replaces repeated expressions—you need to write an expression only once.
  • Complex expressions can be broken down into separate steps and further commented.
  • Series operations are generic. The same functions and operators can be performed with fetch logs or the makeTimeseries command, for example.
Transformations
The Metrics Classic transformations in this section can be converted to DQL.
Default transformation
The Metrics Classic default transformation is equivalent to the timeseries default parameter.
builtin:host.availability.state:splitBy("dt.entity.host"):sum():default(0)
timeseries availability = sum(dt.host.availability, default:0),
by:dt.entity.host
Default always transformation
The Metrics Classic default(x, always) transformation is a special case. The behavior of always is mapped to the timeseries nonempty parameter.
builtin:host.availability.state:splitBy("dt.entity.host"):sum():default(0,always)
by:{dt.entity.host},
nonempty:true
Delta transformation
The Metrics Classic delta transformation is equivalent to the arrayDelta function in DQL.
builtin:service.errors.fivexx.rate:splitBy():sum:delta
timeseries rate=sum(dt.service.errors.fivexx.rate)
| fieldsAdd rate=arrayDelta(rate)
Fold transformation
The following Metrics Classic fold transformations have equivalent array functions in DQL:
Fold transformationDQL array function
fold(avg)arrayAvg
fold(max)arrayMax
fold(min)arrayMin
fold(sum)arraySum
fold(value)arraySum
fold(count)arraySize
fold(median)arrayMedian
fold(percentile(X))arrayPercentile
For example, this Metrics Classic metric selector query:
builtin:host.cpu.usage:avg:fold(avg)
timeseries usage=avg(dt.host.cpu.usage), by:{dt.entity.host}
| fieldsAdd usage=arrayAvg(usage)
What is the equivalent DQL for fold(auto) or fold?
There are two ways to determine the equivalent DQL:
  1. Use the automatic converter to detect the correct fold transformation.
  2. Replace the empty fold with fold(sum) or fold(avg) and compare the new query results to the original.
An empty fold transformation resolves to either the arraySum or arrayAvg function in DQL, depending on a combination of metric metadata and the sequence of operations before the fold.
Single value visualization
The fold transformation has some implicit uses to be aware of in Data Explorer and Dashboards Classic. The Single value visualization, shown below, displays both a line chart and a single value.
Single value example
Use the scalar:true aggregation parameter to get a single value instead of a time series. To reproduce this visualization, consider the following Metrics Classic metric selector query:
builtin:kubernetes.container.restarts:splitby():sum
It can be converted to DQL as follows:
timeseries restarts.trend_line = sum(kubernetes.container.restarts), restarts = sum(kubernetes.container.restarts, scalar:true)
Last transformation
The Metrics Classic last transformation is equivalent to the arrayLast function in DQL.
builtin:service.response.time:splitBy("dt.entity.service"):percentile(99):last
Can be converted to DQL as follows:
timeseries time=percentile(dt.service.response.time, 99),
| fieldsAdd time=arrayLast(time)
The Metrics Classic lastReal transformation has no equivalent in DQL. It also uses arrayLast at conversion.
Limit transformation
The Metrics Classic limit transformation is equivalent to the limit command in DQL.
For example, this Metrics Classic metric selector query (formatted for clarity):
builtin:host.cpu.usage:splitBy("dt.entity.host"):avg
:sort(value(avg,descending))
:limit(3)
| limit 3
Names transformation
The Metrics Classic names transformation is equivalent to the entityName DQL function.
builtin:dt.host.disk.avail:splitBy("dt.entity.host", "dt.entity.disk"):max:names
timeseries avail = max(dt.host.cpu.usage),
by:{dt.entity.host, dt.entity.disk}
| fieldsadd entityName(dt.entity.host), entityName(dt.entity.disk)
Parents transformation
The Metrics Classic parents transformation is not directly supported in DQL, but in many cases it can be reproduced.
For example, this Classic metric selector query (formatted for clarity):
builtin:tech.jvm.threads.count:avg
:splitBy("dt.entity.process_group_instance")
:parents:splitBy("dt.entity.host"):avg
uses the parents transformation, so it can split on the parent dt.entity.host dimension. Because data is already enriched in Grail, you can instead split by the host dimension directly.
timeseries avg(dt.runtime.jvm.threads.count),
by:{dt.entity.host}
How do I convert my selector if the parent dimension isn't in Grail?
Missing enriched dimensions may indicate a bug in the metric calculation. In this case, please report the issue to the Dynatrace support team.
Partition transformation
The Metrics Classic partition transformation is unique in that it creates new series from existing ones. The equivalent DQL makes use of iterative expressions.
builtin:host.disk.avail:fold(avg):limit(3)
:partition("disk_usage",
value("underused",gt(450000000000)),
value("optimal",otherwise))
timeseries avail=avg(dt.host.disk.avail), by: { dt.entity.disk, dt.entity.host }
| fieldsAdd avail=arrayAvg(avail)
| fieldsAdd disk_usage=if(avail>450000000000, "underused", else: "optimal")
| limit 3
How do I partition timeseries elements?
This example Metrics Classic metric selector query (formatted for clarity):
builtin:host.disk.avail:auto:limit(3)
| expand disk_usage=array("underused", "optimal")
| fieldsAdd avail=if(disk_usage=="underused",
if(avail[]>450000000000, avail[]),
else:if(disk_usage=="optimal", if(NOT(avail[]>450000000000), avail[])))
| filterOut isNull(arrayMin(avail))
| limit 3
| filterOut isNull(arrayMin(avail)) // arrayMin returns null if all elements are null
Rate transformation
The Metrics Classic rate transformation is equivalent to the timeseries rate parameter.
builtin:service.requestCount.total:splitBy("dt.entity.service"):value:rate(1s)
timeseries total=sum(dt.service.request.count, rate:1s),
Rollup transformation
The Metrics Classic rollup transformations have equivalent array functions in DQL:
Rollup transformationDQL array function
rollup(avg)arrayMovingAvg
rollup(max)arrayMovingMax
rollup(min)arrayMovingMin
rollup(sum)arrayMovingSum
rollup(value)arrayMovingSum
rollup(count)Not supported
rollup(median)Not supported
rollup(percentile(X))Not supported
builtin:host.cpu.usage:splitBy():avg:rollup(avg,5m)
timeseries usage=avg(dt.host.cpu.usage), interval:1m
| fieldsadd usage=arrayMovingAvg(usage, 5)
The moving window is time-agnostic and so the interval parameter has been fixed to 1m to ensure a 5-minute moving average. While the Metrics Classic rollup transformation adjusts the query timeframe to include past data points, the DQL function does not adapt the query timeframe automatically, which means the first n data points are null (if n is the window size). To get the same results, modify the query timeframe on the timeseries command using the from: parameter.
DQL array functions are not a direct replacement for rollup when migrating Metric Events configurations.
Smooth transformation
The Metrics Classic smooth transformation has no equivalent DQL.
Sort transformation
The Metrics Classic sort transformation is equivalent to the sort command in DQL.
:limit(3)
| limit 3
Timeshift transformation
The Metrics Classic timeshift transformation is equivalent to the timeseries shift: parameter.
For example, this MetricsClassic metric selector query:
builtin:host.cpu.usage:splitBy():avg:timeshift(-7d)
timeseries usage=avg(dt.host.cpu.usage), shift:-7d
Unit transformation
The Metrics Classic setUnit and toUnit transformations are not supported directly in DQL.
Instead, you can use the "Units and formats" section of any chart.
Metric percent example
Related tags
Dynatrace Platform
