TensorFlow Keras Observability
TensorFlow and its user-friendly Keras sequential interface represent state-of-the-art technology for training and running deep learning models.
TensorFlow represents a general-purpose machine learning framework that allows data scientists to build, train and run all kinds of AI models on top.
TensorFlow also ships together with a convenient debugging server called TensorBoard that allows data scientists to collect and visualize all relevant training information such as logs, events, and metrics within a Web dashboard.
See below an example screenshot of TensorBoard and how it visualizes the progress of model training:
TensorBoard based AI training visualization
While TensorBoard is a great tool for local debugging of your AI model, it is not applicable for long-term observability of your running AI model in production.
As TensorBoard data collection is built on top of a flexible TensorFlow callback receiver interface, it is easy to directly send observability information about your running AI model to Dynatrace.
All that is necessary is a dedicated TensorFlow callback implementation that collects the data and forwards to a Dynatrace monitoring environment.
Dynatrace TensorFlow callback receiver
A TensorFlow callback receiver implementation does receive important information updates during training and evaluation phase of a model.
See below the implementation of a Dynatrace TensorFlow callback receiver that forwards metric data during training and evaluation of a model.
import tensorflow as tf
from tensorflow import keras
import requests
# Custom TensorFlow Keras callback receiver that sends the logged metrics
# to a Dynatrace monitoring environment.
# Read more about writing your own callback receiver here:
# https://www.tensorflow.org/guide/keras/custom_callback
class DynatraceKerasCallback(keras.callbacks.Callback):
metricprefix = ''
modelname = ''
url = ''
apitoken = ''
batch = ''
# Constructor that takes a metric prefix, the name of the current model that is used,
# the Dynatrace metric ingest API endpoint (e.g.: https://your.live.dynatrace.com/api/v2/metrics/ingest)
# and the Dynatrace API token (with metric ingest scope enabled)
def __init__(self, metricprefix='tensorflow.', modelname='', url='', apitoken=''):
self.metricprefix = metricprefix
self.modelname = modelname
self.url = url
self.apitoken = apitoken
def send_metric(self, name, value, tags):
tags_str = ''
for tag_key in tags:
tags_str = tags_str + ',{key}={value}'.format(key=tag_key, value=tags[tag_key])
line = '{prefix}.{name}{tags} {value}\n'.format(prefix=self.metricprefix, tags=tags_str, model=self.modelname, name=name, value=value)
self.batch = self.batch + line
def flush(self):
print(self.batch)
r = requests.post(self.url, headers={'Content-Type': 'text/plain', 'Authorization' : 'Api-Token ' + self.apitoken}, data=self.batch)
self.batch = ''
def on_train_end(self, logs=None):
keys = list(logs.keys())
for m in keys:
self.send_metric(m, logs[m], { 'model' : self.modelname, 'stage' : 'train' })
self.flush()
def on_epoch_end(self, epoch, logs=None):
for m in keys:
self.flush()
def on_test_end(self, logs=None):
for m in keys:
self.send_metric(m, logs[m], { 'model' : self.modelname, 'stage' : 'test' })
self.flush()
def on_predict_end(self, logs=None):
for m in keys:
self.send_metric(m, logs[m], { 'model' : self.modelname, 'stage' : 'predict' })
self.flush()
Example Keras model training and evaluation
In the following example, a Keras model loads a well-known sample data set (MNIST) and trains a Keras sequential model.
A Dynatrace TensorFlow callback receiver is configured that automatically receives and forwards the accuracy and loss metric to the configured monitoring environment.
In a production deployment of the model (the evaluation step) the same Dynatrace callback receiver is used to continuously receive observability data about the running model.
print("TensorFlow version:", tf.__version__)
import time
# load the Dynatrace callback receiver
from dynatrace import DynatraceKerasCallback
# Load a sample data set
mnist = tf.keras.datasets.mnist
(x_train, y_train), (x_test, y_test) = mnist.load_data()
x_train, x_test = x_train / 255.0, x_test / 255.0
# Define a model
model = tf.keras.models.Sequential([
tf.keras.layers.Flatten(input_shape=(28, 28)),
tf.keras.layers.Dense(128, activation='relu'),
tf.keras.layers.Dropout(0.2),
tf.keras.layers.Dense(10)
# Define a loss function
loss_fn = tf.keras.losses.SparseCategoricalCrossentropy(from_logits=True)
# Compile the model
model.compile(optimizer='adam',
loss=loss_fn,
metrics=['accuracy'])
# Define the tensor board callbacks
dt_callback = DynatraceKerasCallback(metricprefix='tensorflow', modelname='mnist-classifier', url='https://<YOUR_ENV>.live.dynatrace.com/api/v2/metrics/ingest', apitoken='<YOUR_TOKEN>')
# Train the model
model.fit(x_train, y_train, epochs=5, callbacks=[dt_callback])
# Use the model in production
while True:
model.evaluate(x_test, y_test, verbose=2, callbacks=[dt_callback])
time.sleep(60)
Visualize TensorFlow model metrics in Dynatrace
Once the Dynatrace TensorFlow callback receiver is registered within your own AI model, all the collected metrics are forwarded to your monitoring environment.
The screenshot below shows a Data Explorer visualization of the accuracy metric that was collected from the TensorFlow callback receiver:
AI Observability in Dynatrace for Tensorflow and Keras
