Notebooks and Dashboards use cases
The following use cases show some of the ways you can use Notebooks and Dashboards to leverage visualization and analysis of data ingested into Grail.
Analyze and report with security snippets
Application Security
In this use case, you use snippets to visualize exposure to vulnerabilities, prioritize remediation efforts, and communicate findings to owning teams.
Determine threat exposure with security templates
In this use case, you use the Threat exposure template to visualize the risk and impact of vulnerabilities (Dashboards) or analyze the impact of vulnerabilities and prioritize remediation efforts (Notebooks).
Run instant queries to debug intrusions ![Instant intrusion response](https://cdn.bfldr.com/B686QPH3/at/t8vf2xps83sbh27xkh5sp8c/DT0642.svg?auto=webp&width=72&height=72)
In this use case, once you set up a workflow that notifies you when an attack occurs, determines what is affected, and enriches the data with context, you can immediately respond to discoveries and perform further investigations on logs by running a sequence of DQL queries in Notebooks tailored to the attack type.
