Use the built-in forecast (Dynatrace Classic)
  • Dynatrace Classic
  • Tutorial
  • 5-min read
Dynatrace provides a built-in forecast based on your consumption patterns, and you can enhance it with business context to build a budget-adjusted projection.
Who is this for?
FinOps practitioners, engineers, and platform team leads who want to understand the Dynatrace built-in forecast, decide when to trust it, and enhance it with business context they already know.
What will you learn?
In this tutorial, you'll learn how to:
  • Read the built-in Account Management forecast and recognize its components.
  • Decide when to challenge the forecast and layer in business context.
  • Act on forecast variances using a decision table.
Before you begin
Prerequisites
  • Access to Account Management with Subscription viewer permissions.
  • At least 15 days of consumption history.
  • A Dynatrace Platform Subscription (DPS) for a single account. The built-in forecast isn't available for DPS for Hybrid, where several SaaS or Managed accounts consume from one DPS.
1. Read the built-in forecast
Once you have at least 15 days of consumption history, Account Management provides automated forecasts. To see these, go to Account Management > Subscription > Overview.
The built-in forecast becomes available once your account has 15 or more days of cost data.
Here's what's included in an automated forecast:
ComponentDescriptionUse case
Median forecast
Most likely end-of-period consumption.
Primary planning number.
Upper bound
Higher-end projection accounting for variability.
Conservative / worst-case planning.
Lower bound
Lower-end projection.
Best-case scenario.
Forecast event
Alert when forecast exceeds commitment.
Early warning system.
The built-in forecast is reliable for stable, mature environments with consistent usage patterns. Treat it with caution when:
  • Your environment had major changes in the last 30 days (new apps, migrations, decommissions).
  • You have less than 30 days of data.
  • You know of planned workload changes not yet reflected in consumption.
In these cases, layer your own business context on top.
2. Enhance the forecast with business context
Dynatrace forecasts are consumption-based. They don't know about your roadmap. You add value by layering in what you know.
Here's how to use your business context to enhance the automated forecasts:
Dynatrace median forecast (baseline)
+ Planned workload additions
- Planned retirements / decommissions
+ Anticipated organic growth
± Seasonal adjustments
= Business-adjusted forecast
And here's that calculation with some example figures:
ComponentValue
Dynatrace median forecast (end of period)
$480,000
+ New application launching Q3 (estimated)
+$40,000
− Legacy system retirement Q2 (estimated)
−$25,000
+ Organic growth adjustment (10%)
+$48,000
$543,000
Document your adjustments, because serve as a record for forecast accuracy reviews at the end of the period.
3. Act on forecast variances
You might notice that your actual costs consistently vary from the automated forecasts. Here's how to identify when you need to act:
SituationSignalAction
Slightly under (<10%)
Normal variance
Monitor; no action needed.
Significantly under (<20%)
Potential under-use
Review whether value is being left on the table.
Consistently under
Over-committed
Consider commitment reduction at renewal.
Trending over (10–20%)
On-demand usage likely
Initiate optimization review; alert stakeholders.
Significantly over (>20%)
Budget risk
Escalate, implement optimization measures, consider commitment adjustment.
Congratulations!
You can now use the built-in Account Management forecast as part of your DPS planning. Specifically, you can:
  • Read the median, upper-bound, and lower-bound projections.
  • Recognize when to challenge the forecast and apply business context.
  • Choose appropriate response actions when actual costs deviate from the forecast.
Next steps
Set a forecast event alert in Account Management. For more information, see Cost Controls.
Related topics
  • Control
  • Account Management
Related tags
Dynatrace Platform
