Configure build label propagation
  • Latest Dynatrace
  • 2-min read
Build label propagation enables you to provide build and version metadata information to the injected OneAgent about the newly deployed pods. This information is then visible on the Properties and tags section of your entities pages.
How it works
You can reference the value of a metadata field in an environment variable.
env:
- name: MY_POD_NAMESPACE
valueFrom:
fieldRef:
fieldPath: metadata.namespace
Then OneAgent injects into the newly deployed pods and collects the metadata provided via environment variables.
Enable build label propagation
To enable build label propagation, you need to set feature.dynatrace.com/label-version-detection to true in DynaKube. Note that since enabling build label propagation requires webhook injection, it only works with applicationMonitoring and cloudNativeFullStack deployments.
apiVersion: dynatrace.com/v1beta5
kind: DynaKube
metadata:
namespace: dynatrace
annotations:
feature.dynatrace.com/label-version-detection: "true"
spec:
oneAgent:
cloudNativeFullStack: {}
Default behavior
  • The DT_RELEASE_VERSION environment variable gets the value from metadata.labels['app.kubernetes.io/version'].
  • The DT_RELEASE_PRODUCT environment variable gets the value from metadata.labels['app.kubernetes.io/part-of'].
For example, if your application has the following pod:
apiVersion: v1
kind: Pod
metadata:
labels:
app.kubernetes.io/version: "1.0.0"
app.kubernetes.io/part-of: "store"
spec:
the value of the labels is added to the environment variables of the injected containers:
apiVersion: v1
kind: Pod
metadata:
labels:
app.kubernetes.io/part-of: "Store"
spec:
containers:
- name: app
env:
- name: "DT_RELEASE_VERSION"
valueFrom:
fieldRef:
fieldPath: metadata.labels['app.kubernetes.io/version']
- name: "DT_RELEASE_PRODUCT"
valueFrom:
fieldRef:
fieldPath: metadata.labels['app.kubernetes.io/part-of']
If the DT_RELEASE_VERSION or DT_RELEASE_PRODUCT environment variables are already set on the container before the OneAgent injection, they will not be overwritten.
Configuration options
You can annotate your namespace to provide further mappings or overrule the defaults for pods within that namespace.
  • Each annotation key is mapped to a specific environment variable.
  • Each annotation value is the reference path in fieldPath.
  • The available information for fieldPath is the same as for fieldRef.
Example to overwrite the default values for version and product, and enable stage and build-version:
annotations:
mapping.release.dynatrace.com/version: "metadata.annotations['my-version']"
mapping.release.dynatrace.com/product: "metadata.labels['app.kubernetes.io/name']"
mapping.release.dynatrace.com/stage: "metadata.namespace"
mapping.release.dynatrace.com/build-version: "metadata.labels['release.dynatrace.com/stage']"
Each of these annotations configures a different environment variable:
Holds the fieldPath used for DT_RELEASE_VERSION.
If this annotation is missing, mapping falls back to the default behavior.
Holds the fieldPath used for DT_RELEASE_PRODUCT.
Holds the fieldPath used for DT_RELEASE_STAGE.
Holds the fieldPath used for DT_RELEASE_BUILD_VERSION.
The values aren't validated by Dynatrace Operator or the webhook, so make sure they are valid.
