Ingest StatsD data with the OTel Collector (Dynatrace Classic)
  • Dynatrace Classic
  • How-to guide
  • 2-min read
The following configuration example shows how you configure a Collector instance to ingest data from an existing StatsD setup and import it as an OTLP request into Dynatrace.
Prerequisites
  • An application generating StatsD messages
  • One of the following Collector distributions with the StatsD receiver, transform processor, and filter processor:
    • The Dynatrace OTel Collector
    • The Dynatrace Bindplane OTel Collector
    • OpenTelemetry Contrib
    • A custom Builder version
  • The Dynatrace API endpoint URL to which the data should be exported
  • A Classic access token with the relevant access scope (only required for SaaS and ActiveGate)
See Collector Deployment and Collector Configuration on how to set up your Collector with the configuration below.
Demo configuration
receivers:
statsd:
endpoint: 0.0.0.0:8125
timer_histogram_mapping:
- statsd_type: "histogram"
observer_type: "histogram"
histogram:
# max size for the auto-scaling exponential histogram OTLP metric
# see below for details
max_size: 100
- statsd_type: "timing"
histogram:
max_size: 100
- statsd_type: "distribution"
histogram:
max_size: 100
exporters:
otlp_http:
endpoint: ${env:DT_ENDPOINT}
headers:
Authorization: "Api-Token ${env:DT_API_TOKEN}"
service:
pipelines:
metrics:
receivers: [statsd]
exporters: [otlp_http]
Configuration validation
Validate your settings to avoid any configuration issues.
Components
For our configuration, we configure the following components.
Receivers
Under receivers, we specify the statsd receiver as active receiver component for our Collector instance. We configure the receiver to listen on all network interfaces to port 8125, which is the port typically used for StatsD.
The receiver is configured to aggregate histogram, timer, and distribution messages into exponential histograms, which are later processed for Dynatrace ingestion. The receiver uses auto-scaling exponential histograms, and we have selected a maximum size of 100. This means that the histogram will begin with very granular bucket boundaries and automatically re-scale itself if it receives data points that would result in more than 100 buckets.
For a full list of configuration parameters and supported StatsD metric types, see the StatsD receiver documentation.
Exporters
Under exporters, we specify the default otlp_http exporter and configure it with our Dynatrace API URL and the required authentication token.
For this purpose, we set the following two environment variables and reference them in the configuration values for endpoint and headers.
  • DT_ENDPOINT contains the base URL of the Dynatrace API endpoint (for example, https://{your-environment-id}.live.dynatrace.com/api/v2/otlp).
  • DT_API_TOKEN contains your Classic access token with the Ingest metrics (metrics.ingest) scope.
Service pipeline
Under service, we assemble our receiver, processors, and exporter objects into a metrics pipeline, which accepts StatsD data and ingests it into Dynatrace.
Limits and limitations
Metrics are ingested using the OpenTelemetry protocol (OTLP) via the Dynatrace OTLP API and are subject to the API's limits and restrictions. For more information see:
  • OpenTelemetry metrics limitations
  • Dynatrace metrics mapping
Related topics
  • Scrape Prometheus metrics with the OTel Collector (Dynatrace Classic)
Related tags
Application Observability
