Ingest NetFlow with the OTel Collector (Dynatrace Classic)
  • Dynatrace Classic
  • How-to guide
  • 1-min read
The following configuration example shows how to configure a Collector instance to accept NetFlow packets and ingest them as OTLP requests into Dynatrace.
Prerequisites
  • One of the following Collector distributions with the NetFlow receiver:
    • The Dynatrace Collector
    • The Dynatrace Bindplane OTel Collector
    • OpenTelemetry Contrib
    • A custom Builder version
  • The Dynatrace API endpoint URL to which the data should be exported.
  • A Classic access token with the Ingest logs (logs.ingest) scope.
  • A NetFlow- or sFlow-capable device that can send NetFlow packets to the OTel Collector instance.
See Collector Deployment and Collector Configuration on how to set up your Collector with the configuration below.
Collector configuration
receivers:
netflow:
hostname: "0.0.0.0"
scheme: netflow
port: 2055
sockets: 2
workers: 4
exporters:
otlp_http:
endpoint: ${env:DT_ENDPOINT}
headers:
Authorization: "Api-Token ${env:DT_API_TOKEN}"
sending_queue:
batch:
# Use default batching settings for logs.
min_size: 1800
max_size: 2000
flush_timeout: 60s
service:
pipelines:
logs:
receivers: [netflow]
processors: [batch]
exporters: [otlp_http]
Check the NetFlow receiver documentation for the available configuration options.
We recommend setting the sockets parameter to match the number of CPU cores available on the Collector instance, and the workers parameter to twice the number of sockets. This configuration allows the Collector to process multiple incoming NetFlow packets concurrently, which improves performance.
For extremely large volumes of data, you should parallelize the configuration among multiple Collector instances.
Configuration validation
Validate your settings to avoid any configuration issues.
Components
For our configuration, we configure the following components.
Receivers
Under receivers, we specify the netflow receiver as the active receiver component for our Collector instance and configure it to listen on specified ports.
Processors
Under processors, we specify the batch processor, which batches the incoming NetFlow packets before sending them to Dynatrace. This is useful for optimizing performance and reducing the number of requests sent.
Exporters
Under exporters, we specify the default otlp_http exporter and configure it with our Dynatrace API URL and the required authentication token.
For this purpose, we set the following two environment variables and reference them in the configuration values for endpoint and Authorization.
  • DT_ENDPOINT contains the base URL of the Dynatrace API endpoint (for example, https://{your-environment-id}.live.dynatrace.com/api/v2/otlp).
  • DT_API_TOKEN contains your Classic access token with the Ingest logs (logs.ingest) scope.
Service pipelines
Under service, we assemble our receiver and exporter objects into a logs pipeline, which will listen on the configured address for incoming NetFlow packets and forward them to Dynatrace using the exporter.
Data visualization
The logs records will be available in Dynatrace with fields documented in the receiver documentation.
Limits and limitations
Logs are ingested using the OpenTelemetry protocol (OTLP) via the Dynatrace OTLP API and are subject to the API's limits and restrictions. For more information, see Ingest OpenTelemetry logs.
Related topics
  • Ingest logs from files with the OTel Collector (Dynatrace Classic)
Related tags
Dynatrace Platform
