Create your first Azure connection to start ingesting topology, metrics, logs, and events from your Azure environment into Dynatrace.
Once you onboard your Azure subscription, Dynatrace SaaS creates a connection to it and performs API calls to your Azure subscription to poll telemetry.
The integration does not deploy or use ActiveGate compute resources inside your Azure subscription to poll telemetry. The experience is transparent and fully managed by Dynatrace SaaS.
You can create your first Azure connection via:
Settings app: Create an Azure connection and onboard Azure environments step by step using the onboarding wizard.
CLI: Create Azure connections and monitoring configurations using dtctl, the Dynatrace command-line interface.
API: Create Azure connections and monitoring configurations via the Dynatrace REST API, using federated identity or client secret authentication.
Azure Government and Azure China sovereign clouds are not supported.
A single Dynatrace environment allows up to 500 connections. If you need to exceed this limit, contact Dynatrace support.
Each Azure connection requires a dedicated service principal. The same service principal cannot be used across multiple connections.
Deleting an existing Azure connection within Dynatrace permanently deletes its associated monitoring configuration. There is no way to restore it.
Free and trial Azure subscriptions are subject to lower API rate limits, so throttling may occur more frequently in those environments. See Azure Resource Manager request limits for details on the limits that apply to your subscription type.
If the same Azure subscription is monitored by more than one connection, see Identify and resolve overlapping Azure subscription monitoring.
