After setting up Azure Monitor integration, you can start setting up and configuring metric events for alerting.
To configure metric events for alerting, go to Settings > Cloud and virtualization > Azure > Metric events for alerting > Manage alerting rules. On the Metric events for alerting page you can create, enable/disable, and configure recommended alerting rules.
For an overview of all recommended alerting rules for all cloud services, see the list below.
| Name | Alerting rules |
Azure Spring Apps | Azure Spring Apps system CPU usage (static threshold: above 95%), |
Azure Blockchain Service | Azure Blockchain Service CPU usage percentage (static threshold: above 95%), |
Azure Cache for Redis | Azure Redis memory usage % (Static threshold: above 95 %), |
Azure Redis (built-in) | Azure Redis CPU usage % (built-in) (Static threshold: above 95 %) |
Azure Virtual Machine (classic) | Azure Virtual Machine (classic) percentage CPU (static threshold: above 95%). |
Azure Storage Account (classic) | Azure Storage Account (classic) availability (static threshold: below 95%). |
Azure Storage Blob Services (classic) | Azure Storage (classic) Blob Services availability (static threshold: below 95%). |
Azure Storage File Services (classic) | Azure Storage (classic) File Services availability (static threshold: below 95%). |
Azure Storage Queue Services (classic) | Azure Storage (classic) Queue Services availability (static threshold: below 95%). |
Azure Storage Table Services (classic) | Azure Storage (classic) Table Services availability (static threshold: below 95%). |
Azure Data Factory v2 | Azure Data Factory integration runtime CPU utilization (static threshold: above 95%). |
Azure DB for MariaDB | Azure DB for MariaDB CPU percent (static threshold: above 95%), |
Azure DB for MySQL | Azure DB for MySQL CPU percent (static threshold: above 95%), |
Azure DB for PostgreSQL - Flexible Server | Azure DB for PostgreSQL (Flexible) CPU percent (Static threshold: above 95 %), |
Azure DB for PostgreSQL - Server | Azure DB for PostgreSQL CPU percent (static threshold: above 95%), |
Azure DB for PostgreSQL - Hyperscale | Azure DB for PostgreSQL CPU percent (static threshold: above 95%), |
Azure Event Hubs Cluster | Azure Event Hubs CPU usage (static threshold: above 95%), |
Azure Application Insights | Azure Application Insights availability (static threshold: below 95%), |
Azure Key Vault | Azure Key Vault availability (static threshold: below 95%), |
Azure Data Explorer Cluster | Azure Data Explorer Cluster cache utilization (static threshold: above 95%), |
Azure Integration Service Environment | Azure ISE run failure percentage (static threshold: above 5%), |
Azure Logic Apps | Azure Logic Apps run failure percentage (static threshold: above 5%). |
Azure Machine Learning Workspace | Azure Machine Learning CPU utilization (static threshold: above 95%), |
Azure Maps Account | Azure Maps Account availability (static threshold: below 95%). |
Azure Application Gateway (built-in) | Azure Application Gateway unhealthy hosts (built-in) (Static threshold: above 0 ), |
Azure Application Gateway | Azure Application Gateway unhealthy hosts count (Static threshold: above 0 ), |
Azure Firewall | Azure Firewall health state (static threshold: below 95%), |
Azure ExpressRoute Circuit | Azure ExpressRoute Circuit BGP availability (static threshold: below 95%), |
Azure Front Door | Azure Front Door backend health percentage (static threshold: below 95%). |
Azure Connection Monitors | Azure NetworkWatchers probes failed percent (static threshold: above 5%). |
Azure Connection Monitors Preview | Azure NetworkWatchers probes failed percent (static threshold: above 5%), |
Azure Public IP Address | Azure Public IP Address data path availability (static threshold: below 95%). |
Azure Power BI Embedded | Azure Power BI embedded memory thrashing (datasets) (static threshold: above 95%). |
Azure Search Service | Azure Search Service throttled search queries (static threshold: above 5%). |
Azure Mesh Application | Azure Mesh Application CPU utilization (static threshold: above 95%), |
Azure SignalR | Azure SignalR user errors (static threshold: above 5%), |
Azure SQL (built-in) | Azure SQL Database CPU usage % (built-in) (Static threshold: above 95 %), |
Azure SQL Managed Instance | Azure SQL Managed Instance CPU usage (static threshold: above 95%). |
Azure SQL Data Warehouse (legacy) | Azure SQL Data Warehouse CPU usage percentage (static threshold: above 95%), |
Azure SQL Database (DTU) | Azure SQL Database CPU usage % (Static threshold: above 95 %), |
Azure SQL Database - Hyperscale | Azure SQL Hyperscale Database CPU usage percentage (static threshold: above 95%), |
Azure SQL Database (vCore) | Azure SQL Database CPU usage % (Static threshold: above 95 %), |
Azure Stream Analytics Job | Azure Stream Analytics job resource utilization (static threshold: above 95%). |
Azure SQL Pool | Azure Analytics Services DWU used percentage (static threshold: above 95%), |
Azure App Service Environment v2 | Azure App Service Environment CPU percentage (static threshold: above 95%), |
Azure App Service Plan | Azure App Service CPU percentage (static threshold: above 95%), |
Azure API Management Service | Api Management capacity (Static threshold: above 95 %) |
Azure Storage Blob Services | Azure Storage Blob Services availability (Static threshold: below 95%) |
Azure Storage File Services | Azure Storage File Services availability (Static threshold: below 95%) |
Azure Storage Queue Services | Azure Storage Queue Services availability (Static threshold: below 95%) |
Azure Storage Table Services | Azure Storage Table Services availability (Static threshold: below 95%) |
Azure Storage Account | Azure Storage Account availability (Static threshold: below 95 %) |
The number of recommended alerting rules depends on the number of your monitored cloud services.
To add recommended alerting rules for a new cloud service, you first need to add the new service to monitoring.
To add a service to monitoring,
Not all cloud services have their own predefined alerting rules.
Not applicable to new Dynatrace environments created after January 26, 2026.
To enable recommended alerting rules, you first need to create them. You can create alerting rules and automatically enable them, or (if you clear Automatically enable created rules) create them and manually enable them after possible configuration changes.
For example, you can create and automatically enable a first batch of alerts. When you start monitoring new services, you can create alerts for these new services without automatically enabling them (because you want to configure them first).
How you edit rules depends on whether you chose to automatically enable alerts.
You can disable all alerting rules, or disable or delete them selectively.
x in the Delete column.
If you disable any or all of the alerting rules, you can always re-enable them.
