This is a general description of the unified analysis extension YAML file and ways to create custom visualizations and configure cards, dashboards, and injections.
To customize the details page, start with the detailsSettings and specify the types of information to be included on a unified analysis page. This enables you to customize the page to show all of the data points, charts, and visuals that are most relevant and beneficial to you.
detailsSettings:staticContent:showProblems: trueshowProperties: trueshowTags: trueshowGlobalFilter: trueshowAddTag: truelayout:autoGenerate: falsecards:- key: cpu_memtype: CHART_GROUP- key: diskstype: ENTITIES_LIST
staticContentEnable or disable static elements like problems, properties, tags, global filter and Add tag option.
| Field | Type | Description | Required |
| boolean | If | Required |
layoutReference cards that should be shown on the page (like chart groups or entity lists) or use the automatically generated page layout.
| enum | Possible values for | Optional |
The detailsInjections field defines injections for the entity details page. This information can be used to better evaluate user experience and also help with root-cause analysis.
Injections must be supported by the page—the layout needs to include an injected cards placeholder.
detailsInjections:- type: CHART_GROUPentitySelectorTemplate: type(custom:host), toRelationship.sameAs($(entityConditions))key: injectedChartGroups- type: ENTITIES_LISTkey: injectedListwidth: HALF_SIZE- type: EVENTSkey: injectedEventswidth: FULL_SIZE
| enum | Defines the type of card available to inject. Possible values: | Required |
| String | The unique key of the card, which is used to reference desired card configuration. | Required |
| String | Entity selector pointing to related entities. DetailsIt can serve multiple purposes—selecting the entity where the chart will be displayed and filtering them based on certain rules or relating entities. It is used in conjunction with
For example, when the card with the following configuration is displayed on the host page.
The
| Optional |
| enum | A value that determines how much vertical space the card is taking. Possible values: | Optional |
The detailsFilter field defines filters for the entity details page. It enables you to customize the page to show only the data you want to see. It automatically displays metric dimension filters if there are any dimension splits on the page (chart or metric table). To display only metric dimension filters, define it as empty (detailsFilters: {}).
detailsFilters:relationships:- type(HOST_GROUP), toRelationship.isInstanceOf($(entityConditions))- type(AZURE_REGION), fromRelationship.isSiteOf($(entityConditions))entityFilters:- displayName: filtersfilters:- type: entityNamedisplayName: namefreeText: falsemodifier: containsdefaultSearch: truedistinct: falseentityTypes:- my:interface
relationshipsYou can enable filtering by configuring the relationship between page entity type and related entity type. For example, filter process list by host name:
relationships:- type(HOST) AND toRelationship.isProcessOf($(entityConditions))
You can also configure the filtering on multiple levels. For example, filter the processes by host group name:
relationships:- type(HOST) AND toRelationship.isProcessOf($(entityConditions))- type(HOST) AND fromRelationship.isInstanceOf(type(HOST_GROUP))
entityFiltersThe block that defines the groups of filters (these are displayed slightly grayed out in the filtering list).
| Array | The actual filters that are part of this group. | Required |
| String | Must reference an attribute of the entity you are filtering. Note: every entity has | Required |
| String | How this filter is labelled within the web UI. | Required |
| boolean | When | Optional |
| boolean | If | Optional |
| Array | A mandatory list of entity types that this filter applies to. If you omit this, your filtering bar just shows a spinning wheel because of the incomplete definition. | Optional |
The listSettings section enables you to customize the list view of the unified analysis page. You can change the selection and order of columns, how the list is sorted, and the number of rows to display.
listSettings:staticContent:showGlobalFilter: trueheader:title: My hostsdescription: My hosts listicon: hostlayout:autoGenerate: falsecards:- type: CHART_GROUPkey: chart- type: ENTITIES_LISTkey: entitiesList- type: INJECTIONS
staticContent RequiredEnable or disable static elements like problems, properties, tags, global filter, and the Add tag option.
| Object | The definition of the page header. | Optional |
| Array | A list of breadcrumbs leading to the page. | Optional |
layout RequiredReference cards that should be shown on the page (like chart groups or entity lists) or use the automatically generated page layout.
The listInjections field defines injections for the entity list page. Injections must be supported by the page—the layout needs to include an injected cards placeholder.
listInjections:- type: CHART_GROUPkey: injectedChartGroups- type: ENTITIES_LISTkey: injectedListwidth: HALF_SIZE
The listFilters field defines filters on the list page.
listFilters:relationships:- type(HOST_GROUP), toRelationship.isInstanceOf($(entityConditions))- type(AZURE_REGION), fromRelationship.isSiteOf($(entityConditions))entityFilters:- displayName: filtersfilters:- type: entityNameentityTypes:- HOST_GROUP- AZURE_REGIONfreeText: falsedisplayName: namedistinct: true
entityFiltersThe list of entity filters. For generic entities, the only filter types with suggestions are entityName, tag, healthState, and ipAddress / dt.ip_addresses. Any custom attributes must be set to freeText: true with modifier: equals. There are no suggestions supported, so you must type the exact value to filter.
The propertiesCard field displays the entity properties that are shown on the card as key-value pairs. By default, all available attribute properties are displayed.
propertiesCard:properties:- type: RELATIONrelation:entitySelectorTemplate: NOT VALIDATED IN SCHEMAdisplayName: default- type: ATTRIBUTEattribute:key: attributedisplayName: Attribute
properties RequiredUse this configuration to specify the properties card.
| enum | Defines the type of property. Possible values: | Optional |
RELATIONEnables you to specify the relation to the specific entity.
| String | An entity selector that is used to retrieve the selected entities. DetailsIt can serve multiple purposes—selecting the entity where the chart will be displayed and filtering them based on certain rules or relating entities. It is used in conjunction with
The
| Required |
| String | The name of the relation. | Required |
| String | Displays additional message if no entity is found. By default, the whole property is hidden. | Optional |
ATTRIBUTEEnables you to overwrite attribute display options.
| String | Used to reference the desired attribute. | Required |
| String | The name of the attribute. | Optional |
The chart group cards enable you to visualize the specified metrics in dedicated charts.
metricSelector expression specifies the metrics your chart is based on. For more information, see Metrics API - Metric selector. The examples below use simple metric selector expressions referring directly to the metric keys.chartsCards:- key: chartGroupconditions:- NOT VALIDATED IN SCHEMAnumberOfVisibleCharts: 2charts:- displayName: Chartconditions:- NOT VALIDATED IN SCHEMAvisualizationType: GRAPH_CHARTgraphChartConfig:visualization:themeColor: DEFAULTseriesType: LINEmetrics:- metricSelector: NOT VALIDATED IN SCHEMA- metricSelector: builtin:host.cpu.usage:avgvisualization:themeColor: DEFAULTseriesType: LINE- displayName: Chart2visualizationType: PIE_CHARTpieChartConfig:metric:metricSelector: NOT VALIDATED IN SCHEMAdefaultAggregation: AVGshowLegend: truethemeColor: ORANGE- displayName: Chart3visualizationType: SINGLE_VALUEsingleValueConfig:metric:metricSelector: NOT VALIDATED IN SCHEMAdisplayName: Single valuedefaultAggregation: COUNTshowSparkline: trueshowTrend: true
| String | The unique key of the card, which is used to reference desired card configuration | Required |
Array | Defines the conditions that need to be fulfilled for the chart group card to be visible. | Optional | |
| Integer | The number of charts that are visible on the unified analysis page. | Required |
| enum | Defines the chart group behavior and interactivity. Possile values: | Required |
NORMAL mode enables you to interact with the charts (view different data points or zoom in/out). Charts with STATIC mode are presented in a fixed, restricted manner.
charts| Field | Type | Description | Required |
| String | The title of the card. | Required |
visualizationTypeThe visualizationType defines the type for your chart: a graph chart GRAPH_CHART, a pie chart PIE_CHART, or a single value SINGLE_VALUE. If you don't specify the visualization type, the graph chart is rendered by default.
GRAPH_CHART| Field | Type | Description | Required |
| enum | Enables you to define a theme color, and series type ( | Required |
| Array | Defines how to retrieve data for a single line in the chart. | Required |
| Array | Defines thresholds after which the background of the chart will change the color to the selected one. | Optional |
metricSelectorA metric selector expression for a dedicated metric line.
| enum | Enables you to define a theme color, and series type ( | Optional |
PIE_CHART| Field | Type | Description | Required |
| Object | Defines how to retrieve data for the pie chart. | Required |
| enum | Defines default aggregation of the chart timeseries. If not defined or selected one is not supported, it is deduced from metrics metadata. | Optional |
SINGLE_VALUE| Field | Type | Description | Required |
| Object | Defines how to retrieve data for the single chart. | Required |
| String | Defines the name of the value. | Optional |
| enum | Defines transformation method, which folds data into single value. Possible values: | Optional |
ConditionName|param1key=param1value|param2key=param2value
| Condition | Parameters | Minimum schema version | Description |
| 224 | Used to demonstrate the conditions feature. | |
| 233 | Indicates if the server deployment type is SaaS. | |
| Feature flag key | 233 | Validates the status of a specific feature flag. |
| Dynamic parameters1 | 231 | Checks if the page's monitored entity possesses certain attributes with specified values or if they exist with any value. |
| 230 | Validates the existence of a specified related entity in the environment. |
| 243 | Validates the presence of a specified extension in the environment, considering other parameters. |
| Specified UI permision | 243 | Confirms if you possess a specified permission (for example, |
| 246 | Determines if the page's monitored entity is active. | |
| Type of the service | 246 | Confirms the type of the service. The scope limited to |
| Type of the service | 248 | Checks if a specified |
| 254 | Checks 3rd generation compatibility. | |
| 256 | Verifies if a given metric key has associated metadata and the last time it was updated. |
When parameters are provided with a specific value, they are formatted as key=value. The system will verify the exact match of this key-value pair. If only the key is provided without any accompanying value, the system will simply check if that key is present using the .exists() method.
The extension is configured to operate on the current host.
Metric key
The specified number of days within which the system checks the most recent updates.
The entities list card displays other entities that are related to the focused entity. The YAML file below lists all Synology disks mapped to an instance of DiskStation Manager on which the details page focuses.
entitySelectorTemplate expression specifies the entities to list on the card. For more information, see Environment API v2 - Entity selector.type(syn:disk),fromRelationships.runsOn($(entityConditions)) lists the entities of type syn:disk that have a relationship of from direction and runsOn type to the syn:diskmanager represented via the $(entityConditions) placeholder that stands for a focused entity.entitiesListCards:- key: disksdisplayName: Synology diskspageSize: 10displayCharts: falseentitySelectorTemplate: "type(syn:disk),fromRelationships.runsOn($(entityConditions))"displayIcons: trueenableDetailsExpandability: truenumberOfVisibleCharts: 2columns:- type: ATTRIBUTEattribute:key: some_attributedisplayName: Some attribute- type: RELATIONrelation:entitySelectorTemplate: type("syn:partition"),fromRelationship.isChildOf($(entityConditions))displayName: PartitionsdisplayAmount: falsefallbackMessage: "no partition"filtering:relationships:- type(syn:partition), fromRelationship.isChildOf($(entityConditions))entityFilters:- displayName: filtersfilters:- type: entityNamedisplayName: namefreeText: truemodifier: containsdefaultSearch: truedistinct: falseentityTypes:- my:interface- type: entityNamedisplayName: Partition namefreeText: truemodifier: containsdefaultSearch: falsedistinct: falseentityTypes:- syn:partition
| String | The card title. | Optional |
| Integer | The number of rows visible on a single page. | Required |
| String | The entity selector is used to find entities that are to be displayed on the list. DetailsIt can serve multiple purposes—selecting the entity where the chart will be displayed and filtering them based on certain rules or relating entities. It is used in conjunction with
The
| Optional |
| Object | Additional attribute or relation columns. | Optional |
| Object | The filtering inside the entity list card. It affects only that card's table and chart group. | Optional |
columnsAdditional columns that are displayed between Name and chart columns. There are 2 types available: ATTRIBUTE and RELATION.
RELATIONEnables you to specify the relation to the entity (1:1 relation) or list of entities (1:n relation).
The
| Required |
| String | The name of the column. | Required |
| String | If | Required |
| String | Displays additional message if no entity is found. | Optional |
ATTRIBUTEEnables you to specify custom attribute column.
| String | The name of the attribute. | Required |
The events cards display the events related to specified entities.
eventsCards:- key: eventsdisplayName: EventsentitySelectorTemplates:- "$(entityConditions)",- "type(CONTAINER_GROUP_INSTANCE),fromRelationships.isInstanceOf($(entityConditions))",- "type(PROCESS_GROUP_INSTANCE),fromRelationships.isPgiOfCgi(type(CONTAINER_GROUP_INSTANCE),fromRelationships.isInstanceOf($(entityConditions)))"showFiltering: trueshowPagination: truepageSize: 10
| String | The card title. If not set, card are named | Optional |
| Array | The list of entity selector templates. It defines where the events are gathered from. If empty, the events are gathered for current entity. | Optional |
| Integer | The number of rows visible at card load. | Required |
| String | The description of the card. | Optional |
| String | An event selector that is used to fetch events for related entities. | Optional |
| boolean | Show or hide the chart in the card. | Optional |
The logsCards field specifies the behavior of the logs card and has the same functionality as Log viewer. It consists of a bar chart representing different log occurrences during selected timeframe and detailed table where each log is an entry with additional properties like: timestamp, status, content.
logsCards:- key: logsdisplayName: LogsenablePaging: truefilterQuery: event.type!="k8s" AND ($(logEntityAttributeKey) inEntitySelector "$(entityConditions)" OR dt.entity.container_group_instance inEntitySelector "type(CONTAINER_GROUP_INSTANCE),fromRelationships.isInstanceOf($(entityConditions))" OR dt.entity.process_group_instance inEntitySelector "type(PROCESS_GROUP_INSTANCE),fromRelationships.isPgiOfCgi(type(CONTAINER_GROUP_INSTANCE),fromRelationships.isInstanceOf($(entityConditions)))")showFiltering: truepageSize: 10
| String | The predefined filtering for the log table. It is possible to to use LQL syntax also to more complex cases that include entity selectors with unified analysis placeholders in format: | Optional |
| boolean | Controls the visibility of the filter bar. | Optional |
| Integer | The number of rows visible on a single page. | Optional |
The messageCards field specifies the behavior of the message card, like visualization options, theme, or text.
messageCards:- key: message-cardtype: CARDcard:text: internal texttheme: MAINdisplayName: Message Card- key: message-card2type: MESSAGEmessage:text: internal texttheme: INFO
| enum | Defines the type of your message card. The possible values are: | Required |
CARDDisplays the message in the card format with title, description and buttons.
| String | Defines the description of the card. | Required |
| enum | Defines the color theme of the card. The possible values are: | Required |
| String | Defines the title of the card. | Optional |
MESSAGEDisplays the message in the card format with description only.
| enum | Defines the color theme of the message. The possible values are: | Required |
The problemsCard field specifies the behavior of the problems card.
problemsCard:entitySelectorTemplates:- NOT VALIDATED IN SCHEMA- NOT VALIDATED IN SCHEMA1- NOT VALIDATED IN SCHEMA2
| Array | Up to 10 entity selectors, used to fetch data for related entities. | Optional |
The actions field defines actions that are available from the menu.
actions:- actionScope: GLOBAL_DETAILSactions:- actionExpression: actionName|key1=value1- actionScope: CHART_GROUPkey: chartactionLocation: CHARTactions:- actionExpression: actionName|key1=value1- actionScope: ENTITIES_LISTkey: entitiesListactionLocation: TABLE_ENTRYactions:- actionExpression: actionName|key1=value1
| enum | The defined action appears in the settings of the chosen card type. Possible values: | Required |
| String | You can set the | Required |
String | Defines the action expression. | Required | |
| enum | Defines the location of your created action. Possible values: | Optional |
ActionName|param1key=param1value|param2key=param2value
| Action | Parameters | Minimum schema version | Description |
| 221 | Creates a link to the entity configuration page. For example, host settings. | |
| 234 | Creates a link to the entity configuration page. For example, PGI settings from the host page. |
| 236 | Creates a link to the specified Settings 2.0 topic configuration UI. | |
| 243 | Creates a link to the specified Dynatrace Hub capability. | |
| 243 | Creates a link to the specified Extension in Dynatrace Hub. | |
| 253 | Creates a link to the related entity unified analysis page. |
| 254 | Platform intent action. |
| 255 | Redirects to smartscape. |
Settings scope class
Settings scope identifier
Settings schema ID
Action display name
Hub capability URL part
Extension ID used as URL part
Entire intent JSON
| Action | Parameters | Valid for condition | Minimum schema version | Description |
| 218 | Redirects to the entity's settings page and creates links for all its subtypes. | |
| Whole page scope | 218 | Provides a link for sharing feedback. | |
| Whole page scope | 218 | Opens a feedback sharing form. | |
| Chart element type | 223 | Redirects charts to Data Explorer. | |
| 224 | Redirects charts to set alerts on the selected metric. | |
| Chart or Whole Services page scope with | 224 | Pins charts or entire services to the dashboard. | |
| - | 224 | Navigates to the Problems section. | |
| 224 | Creates multiple predefined screen type actions. | |
| 232 | Displays a single card view. | |
| Log card element type | 233 | Redirects to log settings to create a log metric. | |
| Whole page scope | 235 | Navigates to the classic page view. | |
| 236 | Activates the Local Config Mode. | |
| 244 | Opens the sidebar. |
| Details page | 243 | Navigates to specific problem details. |
| Log card element type | 246 | Redirects log cards to the Log Viewer. | |
| 255 | Redirects charts to create a Service Level Objective (SLO). |
Page type expression to be rendered in the sidebar
Problem ID
Metric table is a graphical representation of the metrics data related to the same dimension set.
metricTableCards:- key: metricTablepageSize: 5displayCharts: trueenableDetailsExpandability: truenumberOfVisibleCharts: 2filtering: {}charts:- displayName: Chartconditions:- NOT VALIDATED IN SCHEMAvisualizationType: GRAPH_CHARTgraphChartConfig:visualization:themeColor: DEFAULTseriesType: LINEmetrics:- metricSelector: NOT VALIDATED IN SCHEMA- metricSelector: builtin:process.cpu:splitBy("process.pid","process.parent_pid","process.executable.name","process.executable.path","process.command_line","process.owner", "dt.entity.process_group_instance")visualization:themeColor: DEFAULTseriesType: LINEconditions:- NOT VALIDATED IN SCHEMA
| Integer | Number of visible charts. | Required |
| Object | Define the charts to display timeseries data in the table. Table columns are based on the dimensions from the metrics results of those charts. Make sure the metrics of all charts have the same dimensions in a result. | Optional |
| Array | Conditions for displaying the chart. | Optional |
| Object | The filtering inside the metric table card. It affects only that cards table and chart group. It automatically displays metric dimension filters if there are any dimension splits. To display only metric dimension filters, define it as empty ( | Optional |
Health cards provide a visual representation of specific metrics within the Dynatrace UI. Each card can be tailored to display up to six distinct tiles, each representing a unique metric or data point.
Health tile can be used as navigation button to specify element on the page that will give more details about that metric.
healthCards:- key: health_cardtiles:- displayName: UptimemetricSelector: builtin:host.uptimedisplayMetricValue: 'true'foldTransformation: LAST_VALUE- displayName: CPUmetricSelector: builtin:host.cpu.usage:avgdisplayMetricValue: 'true'foldTransformation: LAST_VALUEanchor:cardName: Host performancechartName: CPU usage- displayName: Available memorymetricSelector: builtin:host.mem.avail.pctdisplayMetricValue: 'true'foldTransformation: LAST_VALUEanchor:cardName: Host performancechartName: Memory usage- displayName: NetworkmetricSelector: (builtin:host.net.nic.trafficIn:merge("dt.entity.network_interface"):avg)+(builtin:host.net.nic.trafficOut:merge("dt.entity.network_interface"):avg)additionalMetricSelectors:collection:- builtin:host.net.nic.trafficIn:merge("dt.entity.network_interface")- builtin:host.net.nic.trafficOut:merge("dt.entity.network_interface")displayMetricValue: 'true'foldTransformation: LAST_VALUEanchor:cardName: Host performancechartName: Traffic
| String | Unique key, which is used to map to this health card in the page layout config. | Required |
| Array | Collection of tile definitions in the health card. Each tile can display a specific metric. A health card can have up to 6 tiles. | Optional |
tiles| Field | Type | Description | Required |
| String | The name of the health card tile. | Required |
| String | Used to relate problems and specify the metric displayed on the tile. | Required |
| Array | Used to relate problems. Hidden in the UI. | Optional |
| boolean | Determines whether the metric value should be displayed on the tile. | Optional |
| Enum | Defines transformation method, which folds data into single value. Possible values: | Required |
| Object | Defines an element to redirect to when the tile is selected. This can be a specific card or chart name. | Optional |
