The SNMP Autodiscovery extension scans through subnets and helps users discover their full inventory of SNMP-enabled network devices. In addition, this extension also includes a topology model that aims to be generic enough that most sources for data relating to network devices can be expressed through a simple set of common entities: network device, network port, and network interface.
We've started applying this model to some of our most popular SNMP extensions for technologies like Cisco, F5, Palo Alto, and Juniper. This has allowed us to unify all network entities, simplify our queries, and show relevant network data regardless of the monitoring source.
To see how the
Infrastructure & Operations app visualizes this data, see Supercharge your end-to-end infrastructure and operations observability experience (Dynatrace blog).
This guide walks you through the concepts that tie this topology together, and explain how you—as an extension developer or data integrator—can leverage the same model.
As this is a technical guide, we will take a complete example based on a trimmed-down version of the F5 BIG-IP extension.
Three extension manifests are attached to this guide:
1_initial.yaml is the unmodified extension.
It monitors an F5 load balancer, sending data to Dynatrace, but without any awareness of the model.
2_basic.yaml showcases basic usage.
Dynatrace now knows that the F5 load balancer is a network device with interfaces and ports. Other apps will show it too.
3_advanced.yaml showcases advanced usage.
The network device and interface now have access to more data. The network device has also been given additional attributes and charts to display.
See the Manifest files section below to learn more about these files.
You can use an online tool like diffchecker to better focus on the changes between the three manifests.
It's important to understand that the topology model is defined largely by the SNMP Autodiscovery extension. Other extensions and integrations only need to ensure the right data is sent to Dynatrace and optionally define any additional charts to display as part of the web UI.
Let's have a look at the topology entities and relationships.
(network:device)
(network:port)
(network:interface)
These entity types are tied together by the following relationships:
network:port -runsOn-> network:device
network:interface -runsOn-> network:device
network:interface -isChildOf-> network:port
As mentioned earlier, other extensions and integrations only need to send the data in the correct format to leverage this topology. Mandatory dimensions must be present on all metrics, whereas optional dimensions can be added to a single metric to reduce unnecessary data splitting.
The following metrics and dimensions are available for network devices.
Mandatory dimensions:
Key: device.address
Usage: identifies each device and decides when new entity instances should be created
Key: monitoring.mode
Usage: must have fixed value "Extension". This affects the UI and tell Dynatrace this entity is monitored.
Key: sys.name
Usage: labels the device, giving the entity its name.
Key: device.type
Usage: a string to represent the type of device. Can be the name of a technology, make/model, or simply a label like "L3 Switch". Will populate the devType attribute of the entity.
Optional (recommended) dimensions:
Key: device.port
Usage: registers a listening port on the device. No additional entities are created, but the dt.listen\ports attribute will be populated from it.
Key: sys.description
Usage: registers the device’s description against the devDescription attribute. Can be manufacturer information or any descriptive text.
Metrics:
Key: com.dynatrace.extension.network_device.sysuptime
Description: The time, in system ticks (1/100 second), since the last system reboot.
Key: com.dynatrace.extension.network_device.cpu_usage
Description: The system's CPU usage expressed as a percentage
Key: com.dynatrace.extension.network_device.cpu_ratio
Description: The system's CPU usage expressed as a ratio
Key: com.dynatrace.extension.network_device.memory_used
Description: The amount of memory, in kilobytes, used by the device
Key: com.dynatrace.extension.network_device.memory_free
Description: The amount of memory, in kilobytes, currently free on the device
Key: com.dynatrace.extension.network_device.memory_total
Description: The total (used and free) amount of memory, in kilobytes, available on the device
Key: com.dynatrace.extension.network_device.memory_usage
Description: The current memory used by the device, expressed as a percentage of total memory
The following are metrics and dimensions available for network interfaces.
Key: mac.address
Usage: in combination with the name, identifies each interface and when to create new entity instances. Separately, it also identifies network ports and when to create new instances.
Key: if.name
Usage: in combination with the MAC address, identifies each interface. It also gives each interface entity a name.
Metrics:
Key: com.dynatrace.extension.network_device.if.status
Description: A state metric representing a network interface, whose value is always 1 and its dimensions indicate its state details.
Additional dimensions (extracted as entity attributes):
Key: oper.status
Usage: The operational state of the interface (up/down/etc.).
Key: admin.status
Usage: The admin state of the interface (up/down/etc.).
Key: if.speed
Usage: The speed/bandwidth of the interface.
Key: com.dynatrace.extension.network_device.if.bytes_in.count
Description: The volume of traffic, in bytes, inboud to the network interface.
Key: com.dynatrace.extension.network_device.if.bytes_out.count
Description: The volume of traffic, in bytes, outbound from the network interface.
This should guarantee that network device, network port, and network interface entities are created correctly from your data. At this point, you can leverage either the (Classic) Technologies or
Infrastructure & Operations app to visualize these devices.
In the (Classic) Technologies app, navigate to ../ui/apps/dynatrace.classic.technologies/ui/entity/list/network:interface
In the
Infrastructure & Operations app, select the Network Devices tab
Building on top of the previous changes, this section focuses on how to extend the network model with additional metrics, relationships to existing entities, and UI customizations.
In many cases, you probably already have an extension or integration that sends specialized data about a particular type of network device. In these situations, the model can be used to draw some “same as” relationships from your existing entities to the generic ones, effectively attaching new metrics to them, customizing their attributes, and injecting some of your existing charts into their UI.
Once you implemented the proposed changes, follow these additional steps:
Attach your existing data to the network device:
Create a new entry in topology.types as follows:
- name: network:deviceenabled: truedisplayName: Network devicerules: [] # You will populate this at the next step
Add rules to attach your data to the entity (replace [])
Note: You can identify an existing entity type that resembles a network device and copy all the rules from its definition
Ensure that every rule defines the following:
- idPattern: network_device_{device.address}instanceNamePattern: "{sys.name}"role: default
Note: device.address and sys.name are placeholders that can hold any other dimension, but they must identify a management IP address and a device name.
Attach your existing data to the network interface:
- name: network:interfaceenabled: truedisplayName: Network interfacerules: [] # You will populate this in the next step
Add rules to attach your data to the entity (replace the above []).
Note: You can identify an existing type that resembles a network interface and copy all the rules from its definition.
- idPattern: network_interface_{mac.address}_{if.name}instanceNamePattern: "{if.name}"role: default
Note: mac.address and if.name are placeholders that can hold any other dimension, but they must identify a MAC address and an interface name.
Draw the "same as" relationships:
Create two entries in topology.relationships. Each should be based on data similar to what you used in the previous steps.
- fromType: "" # Add your existing entity type that resembles a network devicetypeOfRelation: SAME_AStoType: `network:device`sources:- sourceType: Metricscondition: "" # Match any of the metrics that you used for the network:device entity rule- fromType: "" # Add your existing entity type that resembles a network interfacetypeOfRelation: SAME_AStoType: `network:interface`sources:- sourceType: Metricscondition: "" # Match any of the metrics that you used for the network:interface entity rule
Customize the UI:
Create a new entry in screens for the network device:
screens:- entityType: network:device
Display a drilldown link to the specialized entity:
Add a RELATION type property to the propertiesCard pointing to your existing entity
propertiesCard:properties:- type: RELATIONrelation:# replace your_type with your existing entity typeentitySelectorTemplate: type(your_type),fromRelationships.isSameAs($(entityConditions))displayName: Linked entityconditions:# Replace your_type with your existing entity type- relatedEntity|entitySelectorTemplate=type(your_type),fromRelationships.isSameAs($(entityConditions))# Ensures it only appears on monitored devices- entityAttribute|devMonitoringMode=Extension
Display your existing charts on the Network Device screen:
The easiest way is to inject them by reference from your existing entity's screen.
Note: Never define anything in detailsSettings, always in detailsInjections.
detailsInjections:- type: CHART_GROUPkey: my-custom-chart# replace your_type with your existing entity typeentitySelectorTemplate: type(your_type),fromRelationships.isSameAs($(entityConditions))conditions:# Replace your_type with your existing entity type- relatedEntity|entitySelectorTemplate=type(your_type),fromRelationships.isSameAs($(entityConditions))# Ensures it only appears on monitored devices- entityAttribute|devMonitoringMode=Extension
Define new charts for the network device:
detailsInjections:- type: CHART_GROUPkey: my-custom-chartconditions:# Ensures it only appears on monitored devices- entityAttribute|devMonitoringMode=ExtensionchartsCards:- key: my-custom-charttype: CHART_GROUP# Rest of definition goes here...
The network device entity is associated with an extended set of metrics (coming from the specialized extension), reports additional attributes, displays some of the specialized extension's data on its details page, and retains a drilldown link to the specialized entity.
1_initial.yaml This is the unmodified extension.
1_initial.yaml manifest filename: custom:f5-load-balancerversion: 1.0.0minDynatraceVersion: 1.289.0author:name: Dynatracesnmp:- group: f5interval:minutes: 1dimensions:- key: instance.namevalue: oid:1.3.6.1.2.1.1.5.0- key: failover.statevalue: oid:1.3.6.1.4.1.3375.2.1.14.3.1.0- key: sync.statevalue: oid:1.3.6.1.4.1.3375.2.1.14.1.1.0subgroups:- subgroup: f5-instance-detailstable: falsedimensions:- key: instance.systemnamevalue: oid:1.3.6.1.4.1.3375.2.1.6.1.0- key: instance.systemreleasevalue: oid:1.3.6.1.4.1.3375.2.1.6.3.0- key: instance.systemarchvalue: oid:1.3.6.1.4.1.3375.2.1.6.5.0- key: instance.productversionvalue: oid:1.3.6.1.4.1.3375.2.1.4.2.0metrics:- key: f5.lb.sys.uptimevalue: oid:1.3.6.1.4.1.3375.2.1.6.6.0- subgroup: f5-interface-detailsfeatureSet: interfacetable: truedimensions:- key: interface.namevalue: oid:1.3.6.1.4.1.3375.2.1.2.4.1.2.1.1- key: interface.enabledvalue: oid:1.3.6.1.4.1.3375.2.1.2.4.1.2.1.8- key: interface.statusvalue: oid:1.3.6.1.4.1.3375.2.1.2.4.1.2.1.17- key: mac.addressvalue: $networkFormat(const:macAddress, oid:1.3.6.1.4.1.3375.2.1.2.4.1.2.1.6)metrics:- key: f5.lb.sys.interface.statusvalue: const:1- subgroup: f5-interface-metricsfeatureSet: interfacetable: truedimensions:- key: interface.namevalue: oid:1.3.6.1.4.1.3375.2.1.2.4.4.3.1.1metrics:- key: f5.lb.sys.interface.stat.bytes.in.countvalue: oid:1.3.6.1.4.1.3375.2.1.2.4.4.3.1.3type: count- key: f5.lb.sys.interface.stat.bytes.out.countvalue: oid:1.3.6.1.4.1.3375.2.1.2.4.4.3.1.5type: count- key: f5.lb.sys.interface.stat.pkts.in.countvalue: oid:1.3.6.1.4.1.3375.2.1.2.4.4.3.1.2type: count- key: f5.lb.sys.interface.stat.pkts.out.countvalue: oid:1.3.6.1.4.1.3375.2.1.2.4.4.3.1.4type: count- subgroup: f5-cputable: falsefeatureSet: instance-cpumetrics:- key: f5.lb.sys.global.host.cpu.idle1mvalue: oid:1.3.6.1.4.1.3375.2.1.1.2.20.25.0- key: f5.lb.sys.global.host.cpu.iowait1mvalue: oid:1.3.6.1.4.1.3375.2.1.1.2.20.28.0- key: f5.lb.sys.global.host.cpu.irq1mvalue: oid:1.3.6.1.4.1.3375.2.1.1.2.20.26.0- key: f5.lb.sys.global.host.cpu.softirq1minvalue: oid:1.3.6.1.4.1.3375.2.1.1.2.20.27.0- key: f5.lb.sys.global.host.cpu.stolen1mvalue: oid:1.3.6.1.4.1.3375.2.1.1.2.20.40.0- key: f5.lb.sys.global.host.cpu.system1mvalue: oid:1.3.6.1.4.1.3375.2.1.1.2.20.24.0- key: f5.lb.sys.global.host.cpu.user1mvalue: oid:1.3.6.1.4.1.3375.2.1.1.2.20.22.0- subgroup: f5-memorytable: falsefeatureSet: instance-memorymetrics:- key: f5.lb.sys.host.memory.totalvalue: oid:1.3.6.1.4.1.3375.2.1.7.1.1.0- key: f5.lb.sys.host.memory.usedvalue: oid:1.3.6.1.4.1.3375.2.1.7.1.2.0topology:types:- name: f5lb:instancedisplayName: F5 BIG-IP Instancerules:- idPattern: f5_instance_{instance.name}instanceNamePattern: '{instance.name}'iconPattern: f5sources:- sourceType: Metricscondition: $eq(f5.lb.sys.uptime)attributes:- key: dt.ip_addressesdisplayName: IP Addresspattern: '{device.address}'- key: dt.dns_namesdisplayName: DNS Namepattern: '{instance.name}'- key: OSReleasedisplayName: OS releasepattern: '{instance.systemrelease}'- key: OSArchitecturedisplayName: OS architecturepattern: '{instance.systemarch}'- key: OSNamedisplayName: OS namepattern: '{instance.systemname}'- key: ProductVersiondisplayName: Product versionpattern: '{instance.productversion}'- key: FailoverStatuspattern: '{failover.state}'displayName: Failover status- key: SyncStatuspattern: '{sync.state}'displayName: Config sync statusrole: default- idPattern: f5_instance_{instance.name}instanceNamePattern: '{instance.name}'iconPattern: f5sources:- sourceType: Metricscondition: $prefix(f5.lb)requiredDimensions: []attributes: []role: default- name: f5lb:interfacedisplayName: F5 BIG-IP Interfacerules:- idPattern: f5_interface_{instance.name}_{interface.name}instanceNamePattern: '{interface.name}'iconPattern: network-interfacessources:- sourceType: Metricscondition: $eq(f5.lb.sys.interface.status)attributes:- key: EnabledStatedisplayName: Enabled Statepattern: '{interface.enabled}'- key: MacAddressdisplayName: MAC Addresspattern: '{mac.address}'- key: StatusdisplayName: Statuspattern: '{interface.status}'role: default- idPattern: f5_interface_{instance.name}_{interface.name}instanceNamePattern: '{interface.name}'iconPattern: network-interfacessources:- sourceType: Metricscondition: $prefix(f5.lb.sys.interface)requiredDimensions: []attributes: []role: defaultrelationships:- fromType: f5lb:interfacetypeOfRelation: RUNS_ONtoType: f5lb:instancesources:- sourceType: Metricscondition: $prefix(f5.lb.sys.interface)screens:- entityType: f5lb:instancedetailsSettings:staticContent:showProblems: trueshowProperties: trueshowTags: trueshowGlobalFilter: trueshowAddTag: truetarget: BOTHlayout:autoGenerate: falsecards:- key: f5_instance-charts-cputype: CHART_GROUP- key: f5_instance-charts-memorytype: CHART_GROUPchartsCards:- key: f5_instance-charts-cputarget: BOTHmode: NORMALdisplayName: CPUnumberOfVisibleCharts: 4chartsInRow: 4charts:- displayName: CPU BreakdownvisualizationType: GRAPH_CHARTgraphChartConfig:connectGaps: truestacked: truemetrics:- metricSelector: f5.lb.sys.global.host.cpu.idle1m:splitBy("dt.entity.f5lb:instance")dqlQuery: timeseries idle1m=avg(f5.lb.sys.global.host.cpu.idle1m),by:{`dt.entity.f5lb:instance`},filter:{`dt.entity.f5lb:instance`==$(entityId)}visualization:displayName: Idle- metricSelector: f5.lb.sys.global.host.cpu.system1m:splitBy("dt.entity.f5lb:instance")dqlQuery: timeseries system1m=avg(f5.lb.sys.global.host.cpu.system1m),by:{`dt.entity.f5lb:instance`},filter:{`dt.entity.f5lb:instance`==$(entityId)}visualization:displayName: System- metricSelector: f5.lb.sys.global.host.cpu.user1m:splitBy("dt.entity.f5lb:instance")dqlQuery: timeseries user1m=avg(f5.lb.sys.global.host.cpu.user1m),by:{`dt.entity.f5lb:instance`},filter:{`dt.entity.f5lb:instance`==$(entityId)}visualization:displayName: Uservisualization:themeColor: DEFAULTseriesType: AREA- displayName: System CPUvisualizationType: GRAPH_CHARTgraphChartConfig:connectGaps: truemetrics:- metricSelector: f5.lb.sys.global.host.cpu.system1m:splitBy("dt.entity.f5lb:instance")dqlQuery: timeseries system1m=avg(f5.lb.sys.global.host.cpu.system1m),by:{`dt.entity.f5lb:instance`},filter:{`dt.entity.f5lb:instance`==$(entityId)}visualization:themeColor: BLUEseriesType: LINE- displayName: User CPUvisualizationType: GRAPH_CHARTgraphChartConfig:connectGaps: truemetrics:- metricSelector: f5.lb.sys.global.host.cpu.user1m:splitBy("dt.entity.f5lb:instance")dqlQuery: timeseries user1m=avg(f5.lb.sys.global.host.cpu.user1m),by:{`dt.entity.f5lb:instance`},filter:{`dt.entity.f5lb:instance`==$(entityId)}visualization:themeColor: BLUEseriesType: LINE- displayName: Idle CPUvisualizationType: GRAPH_CHARTgraphChartConfig:connectGaps: truemetrics:- metricSelector: f5.lb.sys.global.host.cpu.idle1m:splitBy("dt.entity.f5lb:instance")dqlQuery: timeseries idle1m=avg(f5.lb.sys.global.host.cpu.idle1m),by:{`dt.entity.f5lb:instance`},filter:{`dt.entity.f5lb:instance`==$(entityId)}visualization:themeColor: BLUEseriesType: LINE- key: f5_instance-charts-memorytarget: BOTHmode: NORMALdisplayName: MemorynumberOfVisibleCharts: 4hideEmptyCharts: truecharts:- displayName: Memory breakdownvisualizationType: GRAPH_CHARTgraphChartConfig:connectGaps: trueyAxes:- key: y-absoluteposition: LEFTvisible: true- key: y-relativeposition: RIGHTvisible: truemin: '0'max: '100'metrics:- metricSelector: f5.lb.sys.host.memory.total:splitBy("dt.entity.f5lb:instance")dqlQuery: timeseries total=avg(f5.lb.sys.host.memory.total),by:{`dt.entity.f5lb:instance`},filter:{`dt.entity.f5lb:instance`==$(entityId)}yAxisKey: y-absolutevisualization:themeColor: BLUEseriesType: AREAdisplayName: Total- metricSelector: f5.lb.sys.host.memory.used:splitBy("dt.entity.f5lb:instance")dqlQuery: timeseries used=avg(f5.lb.sys.host.memory.used),by:{`dt.entity.f5lb:instance`},filter:{`dt.entity.f5lb:instance`==$(entityId)}yAxisKey: y-absolutevisualization:themeColor: ORANGEseriesType: AREAdisplayName: Used
2_basic.yaml This showcases basic usage.
2_basic.yaml manifest filename: custom:f5-load-balancerversion: 1.1.0minDynatraceVersion: 1.289.0author:name: Dynatrace# In this example, we add the basic metrics & dimensions for the network model.# We chose to spread them in-between the existing metrics where possible, but# they could just as well be extracted into separate groups & subgroups.snmp:- group: f5interval:minutes: 1dimensions:- key: instance.namevalue: oid:1.3.6.1.2.1.1.5.0- key: failover.statevalue: oid:1.3.6.1.4.1.3375.2.1.14.3.1.0- key: sync.statevalue: oid:1.3.6.1.4.1.3375.2.1.14.1.1.0# Adding the mandatory dimensions here ensures they appear everywhere- key: monitoring.modevalue: const:Extension- key: sys.namevalue: oid:1.3.6.1.2.1.1.5.0- key: device.typevalue: const:F5 Load balancersubgroups:- subgroup: f5-instance-detailstable: falsedimensions:- key: instance.systemnamevalue: oid:1.3.6.1.4.1.3375.2.1.6.1.0- key: instance.systemreleasevalue: oid:1.3.6.1.4.1.3375.2.1.6.3.0- key: instance.systemarchvalue: oid:1.3.6.1.4.1.3375.2.1.6.5.0- key: instance.productversionvalue: oid:1.3.6.1.4.1.3375.2.1.4.2.0metrics:- key: f5.lb.sys.uptimevalue: oid:1.3.6.1.4.1.3375.2.1.6.6.0- key: com.dynatrace.extension.network_device.sysuptimevalue: oid:1.3.6.1.4.1.3375.2.1.6.6.0- subgroup: f5-interface-detailsfeatureSet: interfacetable: truedimensions:- key: interface.namevalue: oid:1.3.6.1.4.1.3375.2.1.2.4.1.2.1.1- key: if.namevalue: oid:1.3.6.1.4.1.3375.2.1.2.4.1.2.1.1- key: interface.enabledvalue: oid:1.3.6.1.4.1.3375.2.1.2.4.1.2.1.8- key: interface.statusvalue: oid:1.3.6.1.4.1.3375.2.1.2.4.1.2.1.17- key: mac.addressvalue: $networkFormat(const:macAddress, oid:1.3.6.1.4.1.3375.2.1.2.4.1.2.1.6)metrics:- key: f5.lb.sys.interface.statusvalue: const:1- key: com.dynatrace.extension.network_device.if.statusvalue: const:1- subgroup: f5-interface-metricsfeatureSet: interfacetable: truedimensions:- key: interface.namevalue: oid:1.3.6.1.4.1.3375.2.1.2.4.4.3.1.1metrics:- key: f5.lb.sys.interface.stat.bytes.in.countvalue: oid:1.3.6.1.4.1.3375.2.1.2.4.4.3.1.3type: count- key: f5.lb.sys.interface.stat.bytes.out.countvalue: oid:1.3.6.1.4.1.3375.2.1.2.4.4.3.1.5type: count- key: com.dynatrace.extension.network_device.if.bytes_in.countvalue: oid:1.3.6.1.4.1.3375.2.1.2.4.4.3.1.3type: count- key: com.dynatrace.extension.network_device.if.bytes_out.countvalue: oid:1.3.6.1.4.1.3375.2.1.2.4.4.3.1.5type: count- key: f5.lb.sys.interface.stat.pkts.in.countvalue: oid:1.3.6.1.4.1.3375.2.1.2.4.4.3.1.2type: count- key: f5.lb.sys.interface.stat.pkts.out.countvalue: oid:1.3.6.1.4.1.3375.2.1.2.4.4.3.1.4type: count- subgroup: f5-cputable: falsefeatureSet: instance-cpumetrics:- key: com.dynatrace.extension.network_device.cpu_usagevalue: oid:1.3.6.1.4.1.3375.2.1.1.2.20.29.0- key: f5.lb.sys.global.host.cpu.idle1mvalue: oid:1.3.6.1.4.1.3375.2.1.1.2.20.25.0- key: f5.lb.sys.global.host.cpu.iowait1mvalue: oid:1.3.6.1.4.1.3375.2.1.1.2.20.28.0- key: f5.lb.sys.global.host.cpu.irq1mvalue: oid:1.3.6.1.4.1.3375.2.1.1.2.20.26.0- key: f5.lb.sys.global.host.cpu.softirq1minvalue: oid:1.3.6.1.4.1.3375.2.1.1.2.20.27.0- key: f5.lb.sys.global.host.cpu.stolen1mvalue: oid:1.3.6.1.4.1.3375.2.1.1.2.20.40.0- key: f5.lb.sys.global.host.cpu.system1mvalue: oid:1.3.6.1.4.1.3375.2.1.1.2.20.24.0- key: f5.lb.sys.global.host.cpu.user1mvalue: oid:1.3.6.1.4.1.3375.2.1.1.2.20.22.0- subgroup: f5-memorytable: falsefeatureSet: instance-memorymetrics:- key: f5.lb.sys.host.memory.totalvalue: oid:1.3.6.1.4.1.3375.2.1.7.1.1.0- key: f5.lb.sys.host.memory.usedvalue: oid:1.3.6.1.4.1.3375.2.1.7.1.2.0- key: com.dynatrace.extension.network_device.memory_usedvalue: oid:1.3.6.1.4.1.3375.2.1.7.1.4.0- key: com.dynatrace.extension.network_device.memory_totalvalue: oid:1.3.6.1.4.1.3375.2.1.7.1.3.0topology:types:- name: f5lb:instancedisplayName: F5 BIG-IP Instancerules:- idPattern: f5_instance_{instance.name}instanceNamePattern: '{instance.name}'iconPattern: f5sources:- sourceType: Metricscondition: $eq(f5.lb.sys.uptime)attributes:- key: dt.ip_addressesdisplayName: IP Addresspattern: '{device.address}'- key: dt.dns_namesdisplayName: DNS Namepattern: '{instance.name}'- key: OSReleasedisplayName: OS releasepattern: '{instance.systemrelease}'- key: OSArchitecturedisplayName: OS architecturepattern: '{instance.systemarch}'- key: OSNamedisplayName: OS namepattern: '{instance.systemname}'- key: ProductVersiondisplayName: Product versionpattern: '{instance.productversion}'- key: FailoverStatuspattern: '{failover.state}'displayName: Failover status- key: SyncStatuspattern: '{sync.state}'displayName: Config sync statusrole: default- idPattern: f5_instance_{instance.name}instanceNamePattern: '{instance.name}'iconPattern: f5sources:- sourceType: Metricscondition: $prefix(f5.lb)requiredDimensions: []attributes: []role: default- name: f5lb:interfacedisplayName: F5 BIG-IP Interfacerules:- idPattern: f5_interface_{instance.name}_{interface.name}instanceNamePattern: '{interface.name}'iconPattern: network-interfacessources:- sourceType: Metricscondition: $eq(f5.lb.sys.interface.status)attributes:- key: EnabledStatedisplayName: Enabled Statepattern: '{interface.enabled}'- key: MacAddressdisplayName: MAC Addresspattern: '{mac.address}'- key: StatusdisplayName: Statuspattern: '{interface.status}'role: default- idPattern: f5_interface_{instance.name}_{interface.name}instanceNamePattern: '{interface.name}'iconPattern: network-interfacessources:- sourceType: Metricscondition: $prefix(f5.lb.sys.interface)requiredDimensions: []attributes: []role: defaultrelationships:- fromType: f5lb:interfacetypeOfRelation: RUNS_ONtoType: f5lb:instancesources:- sourceType: Metricscondition: $prefix(f5.lb.sys.interface)screens:- entityType: f5lb:instancedetailsSettings:staticContent:showProblems: trueshowProperties: trueshowTags: trueshowGlobalFilter: trueshowAddTag: truetarget: BOTHlayout:autoGenerate: falsecards:- key: f5_instance-charts-cputype: CHART_GROUP- key: f5_instance-charts-memorytype: CHART_GROUPchartsCards:- key: f5_instance-charts-cputarget: BOTHmode: NORMALdisplayName: CPUnumberOfVisibleCharts: 4chartsInRow: 4charts:- displayName: CPU BreakdownvisualizationType: GRAPH_CHARTgraphChartConfig:connectGaps: truestacked: truemetrics:- metricSelector: f5.lb.sys.global.host.cpu.idle1m:splitBy("dt.entity.f5lb:instance")dqlQuery: timeseries idle1m=avg(f5.lb.sys.global.host.cpu.idle1m),by:{`dt.entity.f5lb:instance`},filter:{`dt.entity.f5lb:instance`==$(entityId)}visualization:displayName: Idle- metricSelector: f5.lb.sys.global.host.cpu.system1m:splitBy("dt.entity.f5lb:instance")dqlQuery: timeseries system1m=avg(f5.lb.sys.global.host.cpu.system1m),by:{`dt.entity.f5lb:instance`},filter:{`dt.entity.f5lb:instance`==$(entityId)}visualization:displayName: System- metricSelector: f5.lb.sys.global.host.cpu.user1m:splitBy("dt.entity.f5lb:instance")dqlQuery: timeseries user1m=avg(f5.lb.sys.global.host.cpu.user1m),by:{`dt.entity.f5lb:instance`},filter:{`dt.entity.f5lb:instance`==$(entityId)}visualization:displayName: Uservisualization:themeColor: DEFAULTseriesType: AREA- displayName: System CPUvisualizationType: GRAPH_CHARTgraphChartConfig:connectGaps: truemetrics:- metricSelector: f5.lb.sys.global.host.cpu.system1m:splitBy("dt.entity.f5lb:instance")dqlQuery: timeseries system1m=avg(f5.lb.sys.global.host.cpu.system1m),by:{`dt.entity.f5lb:instance`},filter:{`dt.entity.f5lb:instance`==$(entityId)}visualization:themeColor: BLUEseriesType: LINE- displayName: User CPUvisualizationType: GRAPH_CHARTgraphChartConfig:connectGaps: truemetrics:- metricSelector: f5.lb.sys.global.host.cpu.user1m:splitBy("dt.entity.f5lb:instance")dqlQuery: timeseries user1m=avg(f5.lb.sys.global.host.cpu.user1m),by:{`dt.entity.f5lb:instance`},filter:{`dt.entity.f5lb:instance`==$(entityId)}visualization:themeColor: BLUEseriesType: LINE- displayName: Idle CPUvisualizationType: GRAPH_CHARTgraphChartConfig:connectGaps: truemetrics:- metricSelector: f5.lb.sys.global.host.cpu.idle1m:splitBy("dt.entity.f5lb:instance")dqlQuery: timeseries idle1m=avg(f5.lb.sys.global.host.cpu.idle1m),by:{`dt.entity.f5lb:instance`},filter:{`dt.entity.f5lb:instance`==$(entityId)}visualization:themeColor: BLUEseriesType: LINE- key: f5_instance-charts-memorytarget: BOTHmode: NORMALdisplayName: MemorynumberOfVisibleCharts: 4hideEmptyCharts: truecharts:- displayName: Memory breakdownvisualizationType: GRAPH_CHARTgraphChartConfig:connectGaps: trueyAxes:- key: y-absoluteposition: LEFTvisible: true- key: y-relativeposition: RIGHTvisible: truemin: '0'max: '100'metrics:- metricSelector: f5.lb.sys.host.memory.total:splitBy("dt.entity.f5lb:instance")dqlQuery: timeseries total=avg(f5.lb.sys.host.memory.total),by:{`dt.entity.f5lb:instance`},filter:{`dt.entity.f5lb:instance`==$(entityId)}yAxisKey: y-absolutevisualization:themeColor: BLUEseriesType: AREAdisplayName: Total- metricSelector: f5.lb.sys.host.memory.used:splitBy("dt.entity.f5lb:instance")dqlQuery: timeseries used=avg(f5.lb.sys.host.memory.used),by:{`dt.entity.f5lb:instance`},filter:{`dt.entity.f5lb:instance`==$(entityId)}yAxisKey: y-absolutevisualization:themeColor: ORANGEseriesType: AREAdisplayName: Used
3_advanced.yaml This showcases advanced usage.
3_advanced.yaml manifest filename: custom:f5-load-balancerversion: 1.2.0minDynatraceVersion: 1.289.0author:name: Dynatrace# In this example, we add topology rules for customizing the network model.# And modify the screens to customize the UI of the network device.# All other changes done so far stay the same.snmp:- group: f5interval:minutes: 1dimensions:- key: instance.namevalue: oid:1.3.6.1.2.1.1.5.0- key: failover.statevalue: oid:1.3.6.1.4.1.3375.2.1.14.3.1.0- key: sync.statevalue: oid:1.3.6.1.4.1.3375.2.1.14.1.1.0# Adding the mandatory dimensions here ensures they appear everywhere- key: monitoring.modevalue: const:Extension- key: sys.namevalue: oid:1.3.6.1.2.1.1.5.0- key: device.typevalue: const:F5 Load balancersubgroups:- subgroup: f5-instance-detailstable: falsedimensions:- key: instance.systemnamevalue: oid:1.3.6.1.4.1.3375.2.1.6.1.0- key: instance.systemreleasevalue: oid:1.3.6.1.4.1.3375.2.1.6.3.0- key: instance.systemarchvalue: oid:1.3.6.1.4.1.3375.2.1.6.5.0- key: instance.productversionvalue: oid:1.3.6.1.4.1.3375.2.1.4.2.0metrics:- key: f5.lb.sys.uptimevalue: oid:1.3.6.1.4.1.3375.2.1.6.6.0- key: com.dynatrace.extension.network_device.sysuptimevalue: oid:1.3.6.1.4.1.3375.2.1.6.6.0- subgroup: f5-interface-detailsfeatureSet: interfacetable: truedimensions:- key: interface.namevalue: oid:1.3.6.1.4.1.3375.2.1.2.4.1.2.1.1- key: if.namevalue: oid:1.3.6.1.4.1.3375.2.1.2.4.1.2.1.1- key: interface.enabledvalue: oid:1.3.6.1.4.1.3375.2.1.2.4.1.2.1.8- key: interface.statusvalue: oid:1.3.6.1.4.1.3375.2.1.2.4.1.2.1.17- key: mac.addressvalue: $networkFormat(const:macAddress, oid:1.3.6.1.4.1.3375.2.1.2.4.1.2.1.6)metrics:- key: f5.lb.sys.interface.statusvalue: const:1- key: com.dynatrace.extension.network_device.if.statusvalue: const:1- subgroup: f5-interface-metricsfeatureSet: interfacetable: truedimensions:- key: interface.namevalue: oid:1.3.6.1.4.1.3375.2.1.2.4.4.3.1.1metrics:- key: f5.lb.sys.interface.stat.bytes.in.countvalue: oid:1.3.6.1.4.1.3375.2.1.2.4.4.3.1.3type: count- key: f5.lb.sys.interface.stat.bytes.out.countvalue: oid:1.3.6.1.4.1.3375.2.1.2.4.4.3.1.5type: count- key: com.dynatrace.extension.network_device.if.bytes_in.countvalue: oid:1.3.6.1.4.1.3375.2.1.2.4.4.3.1.3type: count- key: com.dynatrace.extension.network_device.if.bytes_out.countvalue: oid:1.3.6.1.4.1.3375.2.1.2.4.4.3.1.5type: count- key: f5.lb.sys.interface.stat.pkts.in.countvalue: oid:1.3.6.1.4.1.3375.2.1.2.4.4.3.1.2type: count- key: f5.lb.sys.interface.stat.pkts.out.countvalue: oid:1.3.6.1.4.1.3375.2.1.2.4.4.3.1.4type: count- subgroup: f5-cputable: falsefeatureSet: instance-cpumetrics:- key: com.dynatrace.extension.network_device.cpu_usagevalue: oid:1.3.6.1.4.1.3375.2.1.1.2.20.29.0- key: f5.lb.sys.global.host.cpu.idle1mvalue: oid:1.3.6.1.4.1.3375.2.1.1.2.20.25.0- key: f5.lb.sys.global.host.cpu.iowait1mvalue: oid:1.3.6.1.4.1.3375.2.1.1.2.20.28.0- key: f5.lb.sys.global.host.cpu.irq1mvalue: oid:1.3.6.1.4.1.3375.2.1.1.2.20.26.0- key: f5.lb.sys.global.host.cpu.softirq1minvalue: oid:1.3.6.1.4.1.3375.2.1.1.2.20.27.0- key: f5.lb.sys.global.host.cpu.stolen1mvalue: oid:1.3.6.1.4.1.3375.2.1.1.2.20.40.0- key: f5.lb.sys.global.host.cpu.system1mvalue: oid:1.3.6.1.4.1.3375.2.1.1.2.20.24.0- key: f5.lb.sys.global.host.cpu.user1mvalue: oid:1.3.6.1.4.1.3375.2.1.1.2.20.22.0- subgroup: f5-memorytable: falsefeatureSet: instance-memorymetrics:- key: f5.lb.sys.host.memory.totalvalue: oid:1.3.6.1.4.1.3375.2.1.7.1.1.0- key: f5.lb.sys.host.memory.usedvalue: oid:1.3.6.1.4.1.3375.2.1.7.1.2.0- key: com.dynatrace.extension.network_device.memory_usedvalue: oid:1.3.6.1.4.1.3375.2.1.7.1.4.0- key: com.dynatrace.extension.network_device.memory_totalvalue: oid:1.3.6.1.4.1.3375.2.1.7.1.3.0topology:types:# These are already existing rules which we can copy & adjust- name: f5lb:instance # Closely resembles a network devicedisplayName: F5 BIG-IP Instancerules:- idPattern: f5_instance_{instance.name}instanceNamePattern: '{instance.name}'iconPattern: f5sources:- sourceType: Metricscondition: $eq(f5.lb.sys.uptime)attributes:- key: dt.ip_addressesdisplayName: IP Addresspattern: '{device.address}'- key: dt.dns_namesdisplayName: DNS Namepattern: '{instance.name}'- key: OSReleasedisplayName: OS releasepattern: '{instance.systemrelease}'- key: OSArchitecturedisplayName: OS architecturepattern: '{instance.systemarch}'- key: OSNamedisplayName: OS namepattern: '{instance.systemname}'- key: ProductVersiondisplayName: Product versionpattern: '{instance.productversion}'- key: FailoverStatuspattern: '{failover.state}'displayName: Failover status- key: SyncStatuspattern: '{sync.state}'displayName: Config sync statusrole: default- idPattern: f5_instance_{instance.name}instanceNamePattern: '{instance.name}'iconPattern: f5sources:- sourceType: Metricscondition: $prefix(f5.lb)requiredDimensions: []attributes: []role: default- name: f5lb:interface # Closely resembles a network interfacedisplayName: F5 BIG-IP Interfacerules:- idPattern: f5_interface_{instance.name}_{interface.name}instanceNamePattern: '{interface.name}'iconPattern: network-interfacessources:- sourceType: Metricscondition: $eq(f5.lb.sys.interface.status)attributes:- key: EnabledStatedisplayName: Enabled Statepattern: '{interface.enabled}'- key: MacAddressdisplayName: MAC Addresspattern: '{mac.address}'- key: StatusdisplayName: Statuspattern: '{interface.status}'role: default- idPattern: f5_interface_{instance.name}_{interface.name}instanceNamePattern: '{interface.name}'iconPattern: network-interfacessources:- sourceType: Metricscondition: $prefix(f5.lb.sys.interface)requiredDimensions: []attributes: []role: default# These are new rules added to customize the model- name: network:deviceenabled: truedisplayName: Network devicerules:- idPattern: network_device_{device.address} # must follow `network_device_{...}` patterninstanceNamePattern: '{instance.name}'iconPattern: f5sources:- sourceType: Metricscondition: $eq(f5.lb.sys.uptime) # It's important to target specialized metrics, not the generic onesattributes:- key: dt.ip_addressesdisplayName: IP Addresspattern: '{device.address}'- key: dt.dns_namesdisplayName: DNS Namepattern: '{instance.name}'- key: OSReleasedisplayName: OS releasepattern: '{instance.systemrelease}'- key: OSArchitecturedisplayName: OS architecturepattern: '{instance.systemarch}'- key: OSNamedisplayName: OS namepattern: '{instance.systemname}'- key: ProductVersiondisplayName: Product versionpattern: '{instance.productversion}'- key: FailoverStatuspattern: '{failover.state}'displayName: Failover status- key: SyncStatuspattern: '{sync.state}'displayName: Config sync statusrole: default- idPattern: network_device_{device.address}instanceNamePattern: '{instance.name}'iconPattern: f5sources:- sourceType: Metricscondition: $prefix(f5.lb)requiredDimensions: []attributes: []role: default- name: network:interfaceenabled: truedisplayName: Network interfacerules:- idPattern: network_interface_{mac.address}_{interface.name} # must follow `network_interface_{...}_{...}` patterninstanceNamePattern: '{interface.name}'iconPattern: network-interfacessources:- sourceType: Metricscondition: $eq(f5.lb.sys.interface.status) # Again, we target specialized metrics, not generic onesattributes:- key: EnabledStatedisplayName: Enabled Statepattern: '{interface.enabled}'- key: MacAddressdisplayName: MAC Addresspattern: '{mac.address}'- key: ifOperStatusdisplayName: Operational statuspattern: '{interface.status}'role: default- idPattern: network_interface_{mac.address}_{interface.name}instanceNamePattern: '{interface.name}'iconPattern: network-interfacessources:- sourceType: Metricscondition: $prefix(f5.lb.sys.interface)requiredDimensions: []attributes: []role: defaultrelationships:- fromType: f5lb:interfacetypeOfRelation: RUNS_ONtoType: f5lb:instancesources:- sourceType: Metricscondition: $prefix(f5.lb.sys.interface)# Adding the same as relationships- fromType: f5lb:interfacetypeOfRelation: SAME_AStoType: network:interfacesources:- sourceType: Metricscondition: $prefix(f5.lb.sys.interface)- fromType: f5lb:instancetypeOfRelation: SAME_AStoType: network:devicesources:- sourceType: Metricscondition: $prefix(f5.lb)screens:# Customizing the screen for the network device- entityType: network:devicepropertiesCard:properties:# Show a link to the specialized entity- type: RELATIONrelation:entitySelectorTemplate: type(f5lb:instance),fromRelationships.isSameAs($(entityConditions))displayName: F5 Load balancerconditions:# Apply only to devices that have a same as relation, who are monitored by Extension# These 2 conditions are used althroughout the screen definition- relatedEntity|entitySelectorTemplate=type(f5lb:instance),fromRelationships.isSameAs($(entityConditions))- entityAttribute|devMonitoringMode=Extension# Must define everything in `detailsInjections` and not `detailsSettings`!detailsInjections:# This card is injected by reference, meaning we don't have to duplicate the definition again- type: CHART_GROUPkey: f5_instance-charts-cpu# When using `entitySelectorTemplate`, the card is understood to be defined as part of the# resolved entity's screen definition, and not the current screen definition.entitySelectorTemplate: type(f5lb:instance),fromRelationships.isSameAs($(entityConditions))conditions:- relatedEntity|entitySelectorTemplate=type(f5lb:instance),fromRelationships.isSameAs($(entityConditions))- entityAttribute|devMonitoringMode=Extension# Of course, full definitions are still supported- type: CHART_GROUPkey: network-interfaces-listchartsCards:- key: network-interfaces-listmode: NORMALtarget: BOTH # Use CLASSIC for Managed, PLATFORM for SaaS, or BOTH for bothdisplayName: TrafficnumberOfVisibleCharts: 1conditions:# Even if your card is generic, you should still apply this condition so that only# monitored devices display the card.- entityAttribute|devMonitoringMode=Extensioncharts:- displayName: Traffic in/outvisualizationType: GRAPH_CHARTgraphChartConfig:metrics:# metricSelector is required for Managed- metricSelector: com.dynatrace.extension.network_device.if.bytes_in.count:splitBy("dt.entity.network:device)# dqlQuery is required for SaaSdqlQuery: timeseries bytesIn=avg(com.dynatrace.extension.network_device.if.bytes_in.count),by:{`dt.entity.network:device`},filter:{`dt.entity.network:device`==$(entityId)}visualization:displayName: Bytes In- metricSelector: com.dynatrace.extension.network_device.if.bytes_out.count:splitBy("dt.entity.network:device")dqlQuery: timeseries bytesOut=avg(com.dynatrace.extension.network_device.if.bytes_out.count),by:{`dt.entity.network:device`},filter:{`dt.entity.network:device`==$(entityId)}visualization:displayName: Bytes Out- entityType: f5lb:instancedetailsSettings:staticContent:showProblems: trueshowProperties: trueshowTags: trueshowGlobalFilter: trueshowAddTag: truetarget: BOTHlayout:autoGenerate: falsecards:- key: f5_instance-charts-cputype: CHART_GROUP- key: f5_instance-charts-memorytype: CHART_GROUPchartsCards:- key: f5_instance-charts-cputarget: BOTHmode: NORMALdisplayName: CPUnumberOfVisibleCharts: 4chartsInRow: 4charts:- displayName: CPU BreakdownvisualizationType: GRAPH_CHARTgraphChartConfig:connectGaps: truestacked: truemetrics:- metricSelector: f5.lb.sys.global.host.cpu.idle1m:splitBy("dt.entity.f5lb:instance")dqlQuery: timeseries idle1m=avg(f5.lb.sys.global.host.cpu.idle1m),by:{`dt.entity.f5lb:instance`},filter:{`dt.entity.f5lb:instance`==$(entityId)}visualization:displayName: Idle- metricSelector: f5.lb.sys.global.host.cpu.system1m:splitBy("dt.entity.f5lb:instance")dqlQuery: timeseries system1m=avg(f5.lb.sys.global.host.cpu.system1m),by:{`dt.entity.f5lb:instance`},filter:{`dt.entity.f5lb:instance`==$(entityId)}visualization:displayName: System- metricSelector: f5.lb.sys.global.host.cpu.user1m:splitBy("dt.entity.f5lb:instance")dqlQuery: timeseries user1m=avg(f5.lb.sys.global.host.cpu.user1m),by:{`dt.entity.f5lb:instance`},filter:{`dt.entity.f5lb:instance`==$(entityId)}visualization:displayName: Uservisualization:themeColor: DEFAULTseriesType: AREA- displayName: System CPUvisualizationType: GRAPH_CHARTgraphChartConfig:connectGaps: truemetrics:- metricSelector: f5.lb.sys.global.host.cpu.system1m:splitBy("dt.entity.f5lb:instance")dqlQuery: timeseries system1m=avg(f5.lb.sys.global.host.cpu.system1m),by:{`dt.entity.f5lb:instance`},filter:{`dt.entity.f5lb:instance`==$(entityId)}visualization:themeColor: BLUEseriesType: LINE- displayName: User CPUvisualizationType: GRAPH_CHARTgraphChartConfig:connectGaps: truemetrics:- metricSelector: f5.lb.sys.global.host.cpu.user1m:splitBy("dt.entity.f5lb:instance")dqlQuery: timeseries user1m=avg(f5.lb.sys.global.host.cpu.user1m),by:{`dt.entity.f5lb:instance`},filter:{`dt.entity.f5lb:instance`==$(entityId)}visualization:themeColor: BLUEseriesType: LINE- displayName: Idle CPUvisualizationType: GRAPH_CHARTgraphChartConfig:connectGaps: truemetrics:- metricSelector: f5.lb.sys.global.host.cpu.idle1m:splitBy("dt.entity.f5lb:instance")dqlQuery: timeseries idle1m=avg(f5.lb.sys.global.host.cpu.idle1m),by:{`dt.entity.f5lb:instance`},filter:{`dt.entity.f5lb:instance`==$(entityId)}visualization:themeColor: BLUEseriesType: LINE- key: f5_instance-charts-memorytarget: BOTHmode: NORMALdisplayName: MemorynumberOfVisibleCharts: 4hideEmptyCharts: truecharts:- displayName: Memory breakdownvisualizationType: GRAPH_CHARTgraphChartConfig:connectGaps: trueyAxes:- key: y-absoluteposition: LEFTvisible: true- key: y-relativeposition: RIGHTvisible: truemin: '0'max: '100'metrics:- metricSelector: f5.lb.sys.host.memory.total:splitBy("dt.entity.f5lb:instance")dqlQuery: timeseries total=avg(f5.lb.sys.host.memory.total),by:{`dt.entity.f5lb:instance`},filter:{`dt.entity.f5lb:instance`==$(entityId)}yAxisKey: y-absolutevisualization:themeColor: BLUEseriesType: AREAdisplayName: Total- metricSelector: f5.lb.sys.host.memory.used:splitBy("dt.entity.f5lb:instance")dqlQuery: timeseries used=avg(f5.lb.sys.host.memory.used),by:{`dt.entity.f5lb:instance`},filter:{`dt.entity.f5lb:instance`==$(entityId)}yAxisKey: y-absolutevisualization:themeColor: ORANGEseriesType: AREAdisplayName: Used
device.address come from?You may have noticed there's no special OID-based capturing of the device.address dimension in the shared manifests. This is because the example given is based on the SNMP data source, which automatically adds these dimensions to every collected metric.
Yes. SNMP was given as an example as it is focused on network devices, but any extension can leverage this topology model so long as it sends the same metrics and dimensions described in this guide.
Infrastructure & Operations app?Not yet, but this capability is expected to be available soon, at which point this guide will be updated to include the additional usage details.
