OpenTelemetry is an observability framework for cloud-native software. It is used to instrument frameworks and components and export telemetry data (traces, metrics, and logs) for analysis to gain insights into your software's performance and behavior.
Dynatrace is a key contributor to this open source project. To learn more about Dynatrace OpenTelemetry support, see OpenTelemetry and Dynatrace (Dynatrace Classic).
You can send metrics to Dynatrace via:
