Dynatrace provides a dedicated REST API for the ingestion and management of custom events. The API is available in two principal locations:
The full API documentation is available at Events API v2.
Dynatrace supports the following API endpoints for querying and ingesting custom events:
| ActiveGate Type | Base URL |
Dynatrace SaaS |
Environment ActiveGate1 |
Containerized Environment ActiveGate |
Environment ActiveGates listen by default on port 9999. If you changed that port, adjust the port in the URL accordingly.
Be sure to specify your environment ID at the correct location in the URL.
Authentication is handled using a Classic access token and the Authorization HTTP header.
Authorization: Api-Token dt.....
To authenticate, create a Classic access token:
Access Tokens.Required scopes: Ingest events (events.ingest) or Query events (events.read). You can also combine scopes.
Unfiltered network ports
Make sure the TCP ports used by ActiveGate (either 443 or 9999) are not blocked by a firewall or any other network management solution.
Up-to-date SSL trust store
To avoid SSL certificate issues with expired or missing root certificates, make sure your system's certificate trust store is up to date.
See Events API v2 for a full list of ActiveGate examples for the different request types.
In addition to ActiveGate, OneAgent also provides a dedicated HTTP (not HTTPS) endpoint for local-only event ingestion. The following restrictions apply:
POST request)OneAgent does not support content compression using the HTTP header Content-Encoding yet. If you need to use content compression, please export to ActiveGate.
To send events to OneAgent, you first need to enable the Extension Execution Controller (EEC). You can do this globally for the whole environment, for host groups, or only for specific hosts.
Go to
Deployment Status > OneAgents.
On the OneAgent deployment page, turn off Show new OneAgent deployments.
In the Filter by field, enter Host group, and then select the host group you want to configure from the dropdown list.
The host list is now filtered by the selected host group. Each listed host has a Host group: <group name> link, where <group name> is the name of the host group that you want to configure.
The Host group property is not displayed when the selected host doesn't belong to any host group.
Select the host group name in any row.
As you have filtered by host group, all displayed hosts go to the same host group.
Hosts Classic.With EEC enabled, the OneAgent installations on the respective hosts will start accepting requests at the URL http://localhost:14499/v2/events/ingest.
OneAgent uses by default the TCP port 14499 for this endpoint. You can change the port with oneagentctl.
The EEC ingestion endpoint is only available with Full-Stack and Infrastructure Monitoring deployments. It is not available with containerized setups. Use ActiveGate as the export endpoint for container applications.
Being a local-only endpoint, OneAgent does not require authentication.
Being a local-only endpoint, there should not be much network configuration required unless you have restricted local network communication, in which case you need to make sure any such restrictions do not apply to the used TCP port (default 14499).
The following curl command sends a POST request to the local OneAgent endpoint at /v2/events/ingest, indicates a JSON content type, and provides the JSON event data using the --data parameter.
curl --request POST --url http://localhost:14499/v2/events/ingest --header "Content-type: application/json" --data "{ \"eventType\": \"AVAILABILITY_EVENT\", \"title\": \"Demo title\" }"
