With Dynatrace, you can monitor the VSAM and BDAM file access calls from your CICS applications using the CICS module. Each accessed file in a CICS region is represented as a database service on the
Database Services Classic page, including metrics like response time, failure rate, and throughput.
The Distributed traces page lists the file operations and logical file names that are being accessed on the PurePath method-level. The file operations are aggregated per logical file name (for example, in the image below, the READNEXT operation was executed 21 times on the file EXMPCAT).
To start monitoring the file access calls from your CICS applications
In the application program, if the file control API has a SYSID clause with the remote SYSID, the file is recognized as a remote file. However, if the file is defined as remote in the CEDA definition, the CICS module doesn`t recognize the file as a remote file.
To turn off file access monitoring, toggle the z/OS CICS file monitoring sensor and the Instrumentation enabled (change needs a process restart) to off. The CICS region need not have to be restarted for the settings to take effect. The DTAX transaction picks up the file sensor changes (on/off) within 5 minutes.
