ActiveGate deployed on a host using an installer—depending on a selected purpose—consists of multiple processes delivering several functionalities. The container image covers only a subset of that, provided by the core ActiveGate process.
An ActiveGate container image currently supports only a subset of routing and monitoring as well as private synthetic.
For a complete overview, see ActiveGate purposes and functionality (Dynatrace Classic).
| Installer | Container | |
OneAgent routing | ||
API |
Infrastructure Monitoring | ||
Cloud monitoring |
Extensions | ||
Synthetic monitors | ||
ZRemote |
ActiveGate auto-update is supported only for host-based ActiveGates deployed using an installer.
In Kubernetes environments, ActiveGate updates are managed by the container runtime.
ActiveGate is updated automatically on pod restart whenever there is a new version available, unless the image already specifies a certain version.
Remote configuration management doesn't support containerized ActiveGates.
A containerized ActiveGate configuration is not persistently stored. It is declarative, using the Kubernetes native means of configuration, so any changes triggered by the remote configuration management mechanism would be lost upon container restart.
