While running, the ActiveGate container writes data to certain directories within the root filesystem.
| Purpose of directory | Default path |
ActiveGate configuration |
ActiveGate SSL directory |
ActiveGate temporary files |
ActiveGate logs |
Environment data |
Dump files uploaded to ActiveGate by OneAgent |
See ActiveGate directories (Dynatrace Classic) for estimated size requirements for each directory.
The ActiveGate example deployment has been hardened to minimize potential attacks: securityContext.readOnlyRootFilesystem is set to true.
This prevents the container from modifying any image content, so directories need to be set up using volumes.
securityContext:allowPrivilegeEscalation: falsecapabilities:drop:- allprivileged: falsereadOnlyRootFilesystem: truerunAsNonRoot: trueseccompProfile:type: RuntimeDefault
volumeMounts:- name: server-certs-storagemountPath: /var/lib/dynatrace/gateway/ssl- name: ag-lib-gateway-configmountPath: /var/lib/dynatrace/gateway/config- name: ag-lib-gateway-tempmountPath: /var/lib/dynatrace/gateway/temp- name: ag-lib-gateway-datamountPath: /var/lib/dynatrace/gateway/data- name: ag-log-gatewaymountPath: /var/log/dynatrace/gateway- name: ag-tmp-gatewaymountPath: /var/tmp/dynatrace/gateway
Refer to ActiveGate storage requirements for volume sizing.
