Classic AWS Lambda integration
  • Dynatrace Classic
  • Overview
  • 2-min read
  • Published Aug 11, 2025
This page refers to the classic AWS Lambda integration. For the latest version, see Monitor AWS Lambda.
Dynatrace provides you with a dedicated AWS Lambda layer that contains the Dynatrace extension for AWS Lambda.
Trace Python, Node.js, and Java Lambda functions
Integrate Dynatrace Lambda Layer on container images
Deploy Dynatrace Lambda Layers when deployed via a container image.
  • How-to guide
Read this guide
Validate integration
Debug potential configuration or monitoring issues for AWS Lambda integration.
Read this troubleshooting guide
Trace .NET Lambda functions
Monitor AWS Lambda with OpenTelemetry
Prerequisites for monitoring AWS Lambda with OpenTelemetry
  • How-to guide
Read this guide
Trace AWS Lambda .NET Core functions with OpenTelemetry .NET
Learn how to use OpenTelemetry to trace AWS Lambda .NET Core functions.
  • How-to guide
Read this guide
OpenTelemetry interoperability
OpenTelemetry interoperability in Python
Connect Dynatrace AWS Lambda extension to the OpenTelemetry Python instrumentation via OpenTelemetry interoperability.
  • How-to guide
Read this guide
OpenTelemetry interoperability in Node.js
Connect Dynatrace AWS Lambda extension to the OpenTelemetry Node.js instrumentation via OpenTelemetry interoperability.
  • How-to guide
Read this guide
OpenTelemetry interoperability in Java
Connect Dynatrace AWS Lambda extension to the OpenTelemetry Java API via OpenTelemetry interoperability.
  • Reference
Read this reference
AWS Lambda logs in context of traces
Configure log message enrichment with OpenTelemetry on AWS Lambda.
  • How-to guide
Read this guide
Related tags
Infrastructure ObservabilityAWS
