Migrate from classic AWS Lambda integration (Dynatrace Classic)
  • Dynatrace Classic
  • How-to guide
  • 2-min read
AWS Lambda functions monitored with classic OneAgent layers should be updated to the latest generation monitoring layer to take full advantage of Dynatrace’s enhanced observability capabilities.
To migrate AWS Lambda functions currently monitored with classic OneAgent layers
  1. Review the system requirements of the latest generation AWS Lambda monitoring layer.
  2. Remove the classic layer from the AWS Lambda function.
  3. Remove the configuration (environment variables starting with DT or the dtconfig.json file).
  4. Follow the setup instructions in Trace Lambda functions (Dynatrace Classic).
Alternatively, you can reuse the configuration created for the classic AWS Lambda layer with the following adaptations that make the latest generation of Dynatrace AWS Lambda monitoring backward-compatible.
  • Change the name of the environment variable DT_CLUSTER_ID to DT_CLUSTER.
  • Change the default status of OpenTelemetry integration to disabled by doing one of the following:
    • Remove the environment variable DT_OPEN_TELEMETRY_ENABLE_INTEGRATION
    • Remove the entry OpenTelemetry.EnableIntegration from the dtconfig.json file.
Once these adaptations are complete, remove the classic layer and add the latest generation layer. Ensure that the selected layer matches the correct architecture and be aware of differences in system requirements and available features. The latest generation layers are located in a different Dynatrace AWS account than the classic layers. That's why the account number part of the layer ARN changes from 725887861453 to 585768157899.
Comparison between classic and latest AWS Lambda
The tables below compare key features and performance metrics between the classic and latest AWS Lambda implementations.
Feature comparison
The table below compares features for Java layers tested in hello-world Lambda functions (only returning a response) with 512 MB of allocated memory.
FeatureAWS Lambda (classic)AWS Lambda (latest)
Supported sensors
Few built-in
Many built-in
Cold start invocation overhead (typical)
< 4,000 ms
< 1,500 ms1
Warm start invocation overhead (typical)
70–80 ms
60 ms
Response time overhead (typical)
20 ms
< 5 ms
Log enrichment
Manual
Automatic for supported frameworks, structured logs
Layer size for traces-only layer
< 10 MB
> 15 MB, depending on OneAgent
Token stored in Secret Manager
Supported for non-SnapStart
Supported
Supported
Supported
Code base
Based on OpenTelemetry SDK
OneAgent
1
For .NET runtimes, cold start invocation overhead is ~5,000 ms.
Runtime-specific comparison
RuntimeAWS Lambda (classic)AWS Lambda (latest)
Java
8, 11, 17, 21
11, 17, 21
Node.js
16, 18, 20, 22
20, 22, 242
Python
3.9, 3.10, 3.11, 3.12, 3.13, 3.14
.NET
Manual instrumentation only
.NET 8, .NET 10
2
Requires OneAgent version 1.329+.
Java
Minimum memory
1,500 MB
128 MB
Handler function definition
In class
In class or base class
SnapStart
Supported
Supported
Node.js
Module type
CommonJS
CommonJS, ESM (opt-in)3
3
ESM support is experimental. To enable it, set the DT_ENABLE_ESM_LOADERS environment variable to true. Note that aws-sdk tracing support is available for CommonJS only. Enabling ESM support increases memory consumption.
.NET
SnapStart
Supported
Supported
Related tags
Infrastructure ObservabilityAWS
