Collect logs from AWS Lambda functions (Dynatrace Classic)
  • Dynatrace Classic
  • How-to guide
  • 7-min read
Dynatrace version 1.263
You can collect logs directly from your AWS Lambda functions and send them to Dynatrace for analysis. The solution is an alternative to the CloudWatch log forwarder with benefits in terms of cost and latency, and is also easier to set up, in particular if AWS Lambda tracing is already in place. As part of the OneAgent installation process, this feature provides a streamlined solution for collecting logs from your Lambda functions.
Prerequisites
  • An ActiveGate with the Log analytics collector module enabled. See Log Monitoring API v2 - POST ingest logs.
Deploy
For Python, Node.js, and Java Lambda functions, Dynatrace provides a single Lambda layer that enables both trace and log collection. For .NET, Dynatrace provides a standalone layer that collects only logs.
Log collection for Python, Node.js, and Java Lambda functions
To deploy the Dynatrace Lambda extension, follow the instructions from Trace Python, Node.js, and Java Lambda functions but with the following two differences:
  1. Under I want to enable, select Traces and Logs.
  2. Either select Create token to create a new access token or enter an existing access token with the logs.ingest permission into the Access Token input field.
If you previously used the Dynatrace Lambda extension without logging, you have to adapt the Lambda Layer Arn as well as the configuration provided in the wizard—by adding the necessary enhancements for the log collector.
Log collection for .NET Lambda functions
For .NET Lambda functions, follow the steps described in Monitor AWS Lambda with OpenTelemetry but with the following two differences:
  1. Under I want to enable, select Logs.
  2. Either select Create token to create a new access token or enter an existing access token with the logs.ingest scope into the Access Token input field.
If you previously used tracing integration without logging, you have to adapt the configuration as provided in the wizard—by adding the necessary enhancements for the log collector.
Turn off Firehose log streaming or CloudWatch log forwarding
If you are currently using it, you must turn off Firehose log streaming or CloudWatch log forwarding for functions on which you wish to use this log collection feature in order to avoid duplicate log exports. See Log monitoring with AWS log forwarder or Stream logs via Amazon Data Firehose.
Usage
After deployment, collected logs for each future function invocation and initialization can be found in the Related logs card on the Lambda function's service page in Dynatrace, and in the Log viewer. You can inspect the log details to find the type of the log under the telemetryevent.type attribute, among other metadata. The content of platform logs is JSON data; the content of function logs is plain text.
Logs in context of traces
To correlate and see application logs with traces in Dynatrace, you need to enrich logs with the trace identifiers. For more details see Logs in context of traces.
Configure
Log event types
Dynatrace collects two log event types, platform events and function logs. To configure which log event types are collected, use the following syntax.
Configure withLocationDefault valueSyntax
JSON file
EventTypes (property in the LogCollection object)
["platform", "function"]
Array of strings, for example "function"1
Environment variables
DT_LOG_COLLECTION_EVENT_TYPES
platform:function
Colon-separated list of log event types, for example function1
1
Set the value to ["function"] (or function) to collect only function logs.
Endpoint
OneAgent version 1.275+
The log export endpoint defaults to the base URL of your configuration deployment screen. You can override it by setting the override-value location to a specific full endpoint URL that contains the path.
Configure withDefault-value locationOverride-value location
JSON file
Connection.BaseUrl
Add the Endpoint property to the LogCollection object.
DT_CONNECTION_BASE_URL
DT_LOG_COLLECTION_ENDPOINT
Environment ActiveGate and default value
If you're using an Environment ActiveGate, make sure the environment ID is included in the default value location or set its value to the full URL of the log ingest endpoint (for example, https://{activegate-host}:9999/e/{your-environment-id}/api/v2/logs/ingest).
If you're using Environment ActiveGate (which is usually the case, if you deployed ActiveGate by yourself) and don't have /e/{your-environment-id} as part of your DT_CONNECTION_BASE_URL (Connection.BaseUrl), you need to set either the
  • DT_LOG_COLLECTION_ENDPOINT environment variable
  • or LogCollection.Endpoint JSON property
to the full URL of the log ingest endpoint (i.e. https://{activegate-host}:9999/e/{your-environment-id}/api/v2/logs/ingest). The environment ID is typically the tenant ID.
Fetch token from AWS Secrets Manager
OneAgent version 1.295+
Instead of specifying the authentication token explicitly in the configuration, you can configure OneAgent to fetch a token stored in AWS Secrets Manager.
Prerequisites
  • Make sure you granted the secretsmanager:GetSecretValue permission for the authentication token secret ARN to the Lambda function monitored by OneAgent. For details, see Authentication and access control for AWS Secrets Manager in the AWS Secrets Manager documentation.
  • Make sure the secret value contains only the plaintext authentication token value (without quotes). Note that
    • Secrets with JSON structure are not supported. For details, see Create an AWS Secrets Manager secret in the AWS Secrets Manager documentation.
    • When you retrieve the secret value, Secrets Manager returns by default only the current secret version (AWSCURRENT label). For details, see What's in a Secrets Manager secret? in the AWS Secrets Manager documentation.
To fetch the token for log collection, set the token secret ARN either to the environment variable DT_LOG_COLLECTION_AUTH_TOKEN_SECRETS_MANAGER_ARN or the JSON property LogCollection.AuthTokenSecretsManagerArn.
This option always overrides DT_LOG_COLLECTION_AUTH_TOKEN (LogCollection.AuthToken). If the fetch fails, the log collector will not be able to export log data.
A fetch accesses AWS Secrets Manager only once, during the Lambda function's initialization phase; this causes an increase of the Lambda function's cold start duration.
To fetch the token for trace connection, set another fetch.
Filter logs by level
OneAgent version 1.291+
By default, logs for the configured log event types are collected for all the following log levels, ordered from the lowest to the highest level:
  • TRACE
  • DEBUG
  • INFO
  • WARN
  • ERROR
  • FATAL
For more information, see AWS log-level filtering.
To configure from which level to start log collection, for example, starting from WARN level, set a filter using the following syntax.
Configure withLocationSyntax
JSON file
LogCollection.Filter.MinLevel (LogCollection object has property Filter which has property MinLevel)
<Log level>
Example: {"LogCollection": {"Filter": {"MinLevel": "WARN" }}}
DT_LOG_COLLECTION_FILTER_MIN_LEVEL
<Log level>
Example: WARN
For example, if <Log level> is WARN
  • Logs for TRACE, DEBUG, and INFO levels aren't collected.
  • Logs for WARN, ERROR, and FATAL levels are collected.
To configure log collection filters directly in AWS, see Using Amazon CloudWatch Logs with AWS Lambda. Note that with this option
  • Logs aren't shown on CloudWatch.
  • Dynatrace doesn't collect logs that are already filtered out in AWS.
Enrich logs
OneAgent version 1.337+
You can enrich collected logs with custom tags and fields by setting the DT_TAGS environment variable on your Lambda function. Dynatrace adds these values as attributes to all logs collected from that function.
The DT_TAGS variable supports these fields:
  • Primary tags, for example, primary_tags.<tag>
  • Special fields: dt.cost.costcenter, dt.cost.product, dt.security_context, dt.space (dt.space is available with OneAgent version 1.351+)
  • Primary fields, when not auto-detected from AWS: aws.account.id, aws.region, dt.host_group.id
Example:
DT_TAGS="primary_tags.environment=production dt.cost.costcenter=12345 aws.account.id=111122223333"
Limitations
  • The extension event type isn't supported. Configuring this event type results in an error and log collection doesn't start.
  • Logs collected by the log collector in the classic AWS Lambda integration are not associated with traces and don't appear in the trace view Logs tab—they appear only on the Related logs card or in Log viewer. To connect function logs to traces, use manual log enrichment. See AWS Lambda logs in context of traces for language-specific examples.
  • Automatic log enrichment in the latest AWS Lambda integration applies only to structured logs printed with supported logging frameworks.
  • A log event without a detected log level receives ERROR when the message contains [error] or [ERROR]; otherwise Dynatrace assigns INFO.
  • Combining the standalone collector layer with a OneAgent layer isn't recommended. For both tracing and log collection, use the combined Traces and Logs layer instead.
Troubleshoot
  • Dynatrace does not ingest logs (HTTP 429)
Related topics
  • Trace Lambda functions (Dynatrace Classic)
  • Log monitoring with AWS log forwarder
Related tags
Infrastructure ObservabilityAWS
