Customize JMX extensions
JMX extensions are defined by JSON files.
An extension definition consists of three main elements: metadata
, metrics
, and UI
1The basic format is as follows:2 {3 "version": "1.0",4 "name": "custom.jmx.hornetq",5 "type": "JMX",6 "entity": "PROCESS_GROUP_INSTANCE",7 "metricGroup": "tech.HornetQ",8 "configUI" : {9 "displayName": "HornetQ JMX"10 },11 "metrics": [ ],12 "ui": {13 "keycharts" : [ ],14 "charts": [ ]15 }16 }
Metadata
Each JMX extension has the following mandatory properties:
Field | Type | Description |
version | String | The extension version, in format d.dd , must be updated whenever the extension definition is updated |
name | String | A unique extension name in Java package format. Custom JMX extension names should follow the custom.jmx.name rule. You can only user letters, numbers, and "-", "_" characters. For example, custom.jmx.newPlugin-Ver2 |
type | String | Always use JMX |
entity | String | Always use PROCESS_GROUP_INSTANCE |
metricGroup | String | Metric group is used for grouping custom metrics into a hierarchical namespace where different sources, for example multiple extensions, can contribute. Moreover, the metric group becomes a primary part of the metric key. Hence, once defined, it can't be changed. Allowed characters are letters, numbers, and "-", "_" characters. |
configUI.displayName | String | Human-readable extension name. This name is displayed on the Dynatrace Monitoring extensions page once the extension is uploaded. |
Metrics
This part of the JSON defines which metrics are collected by the extension. Each metric is defined by JSON in a format similar to the following:
1{2 "timeseries": {3 "key": "Queue.ConsumerCount",4 "unit": "Count",5 "displayname": "Queue Consumer Count",6 "dimensions": [7 "rx_pid"8 ]9 },10 "alert_settings": [11 {12 "alert_id": "too_many_consumers",13 "event_type": "PERFORMANCE_EVENT",14 "event_name": "Too many consumers",15 "description": "The {metricname} of {severity} is {alert_condition} the threshold of {threshold}",16 "threshold": 35.0,17 "alert_condition": "ABOVE",18 "samples":5,19 "violating_samples":3,20 "dealerting_samples":5,21 "value_extractor": "MAX"22 }23 ],24 "source": {25 "domain": "org.hornetq",26 "keyProperties": {27 "type": "Queue"28 },29 "attribute": "ConsumerCount"30 }31 }
Timeseries
This part specifies the metadata of a metric.
key | String | Metric name. Must be unique within this extension. Only letters, numbers, and "-" , "_" characters are allowed. |
unit | String | Metric unit. Must be one of the available units described below |
dimensions | String array | Must contain rx_pid at index 0 . This ensures that JMX attributes get the system process ID (PID) as a dimension. Additional dimensions can be used to, for example, provide one metric per JMX ObjectName key property value (for example, QueueName , ThreadPoolName , or ConnectionPoolName ). Only letters, numbers, and "-" , "_" characters are allowed. |
displayname | String | Metric display name representing the metric in Dynatrace. This field is obligatory. It must be different than the metric key. |
Available units:
NanoSecond
, MicroSecond
, MilliSecond
, Second
, Byte
, KiloByte
, MegaByte
, BytePerSecond
, BytePerMinute
, KiloBytePerSecond
, KiloBytePerMinute
, MegaBytePerSecond
, MegaBytePerMinute
, Count
, PerSecond
, PerMinute
Alert settings
This part specifies the configuration of one or more alerts for a given timeseries.
alert_id | String | Unique alert ID. Only letters, numbers, and "-" , "_" characters are allowed. |
event_type | String | Allowed types: PERFORMANCE_EVENT , ERROR_EVENT , AVAILABILITY_EVENT . |
description | String | Description defines alert message, following code snippets could be used: {threshold} the value of the custom threshold that was violated, {severity} the violating value, {entityname} the display name of the entity where the metric violated, {violating_samples} the number of violating samples that led to that event, {dimensions} a string containing the violating dimensions of the metric, {alert_condition} a string showing if above or below threshold is alerting |
event_name | String | Event name displayed on UI pages. |
threshold | Float | The value of the threshold. |
alert_condition | String | ABOVE or BELOW. |
samples | Integer | Size of the “window” in which violating_samples are counted. |
violating_samples | Integer | The number of violating samples that rise an alert. |
dealerting_samples | Integer | The number of not violating samples that deactivate the alert. |
value_extractor | String | Dynatrace captures a value every 10 seconds but only sends one aggregate value per minute. This specifies how to aggregate these 10 second values. Possible values: MIN , MAX , SUM , COUNT , AVG , MEDIAN , P90 . Default value is AVG |
Source
This part specifies how a metric is collected using JMX. The following attributes are required for all metrics:
domain | String | Domain name of the MBean |
keyProperties | Key, Value pairs | Key properties of the MBean. Values can contain wildcards (* ) |
attribute | String | Name of attribute that contains the metric value. |
Optional attributes are:
attributePath | String | See CompositeData |
allowAdditionalKeys | Boolean | If false, the keyProperties need to match exactly. Additional keys in the name will lead to a mismatch. If true, then additional key properties beside those specified in "keyProperties" are allowed and ignored. |
calculateDelta | bool | If true, calculate the change in values of the given attribute. Value = attribute(t) - attribute(t-1). This is useful for monotonically increasing values. |
calculateRate | bool | If true, calculate the rate of changes per seconds. This is used in combination with calculateDelta to convert an absolute attribute (eg. Request Count) to a rate (eg. Requests per Second). Value = attribute / query interval |
aggregation | String | It is used to aggregate multiple values if more than 1 MBean matches the domain and key property filter. Possible values: SUM, AVG, MIN, MAX |
splitting | Object | Set Splitting |
Splitting
Splittings can be used to define an additional dimension for a metric. This dimension must be defined in the dimension
property of the timeseries and the splitting
property of the source.
1"splitting": {2 "name": "name",3 "type": "keyProperty",4 "keyProperty": "name"5 }
To define multiple splittings, use the following format:
1"splittings":[2 {3 "name":"name",4 "type":"keyProperty",5 "keyProperty":"name"6 },7 {8 "name":"context",9 "type":"keyProperty",10 "keyProperty":"context"11 }12]
The following attributes must be present for each splitting:
name | String | Must match the dimension name defined for the timeseries |
type | String | Must always be keyProperty |
keyProperty | String | Defines which key property of the ObjectName of an MBean is used for splitting. |
Example of a metric with an additional splitting
The following example shows how to define a metric that provides multiple timeseries within a single metric:
1{2 "timeseries": {3 "key": "XY.Size",4 "unit": "Count",5 "displayname": "Queue Consumer Count",6 "dimensions": [7 "rx_pid",8 "name"9 ]10 }11 "source": {12 "domain": "com.sample",13 "keyProperties": {14 "type": "XY",15 "name": "*"16 },17 "attribute": "Size",18 "splitting": {19 "name": "name",20 "type": "keyProperty",21 "keyProperty": "name"22 }23 }24 }
For example, MBeans com.sample:type=XY,name=A and com.sample:type=XY,name=B
will result in two timeseries, the first for "A" and the second for "B".
CompositeData
To extract values of individual keys returned as CompositeData
type by an attribute, you need to use the attributePath
mechanism and point to the key you're interested in.
For example, let's say you want to extract the value of used
from the HeapMemoryUsage
attribute. HeapMemoryUsage
is a CompositeData
type that returns the following list of value-key pairs:
1{2 committed: integer,3 init: integer,4 max: integer,5 used: integer6}
Define the metric that points to the MBean with the HeapMemoryUsage
attribute and, in the source
section, point the attributePath
to the used
key. For example:
1"source": {2 "domain": "java.lang",3 "keyProperties": {4 "type": "Memory",5 },6 "attribute": "HeapMemoryUsage",7 "attributePath": "get(\"used\")"8 }
UI config
This part of the JSON defines how metrics are charted on the process page. It contains a mandatory charts section and an optional keycharts section. Each section has the same format and looks like this:
1{2 "ui": {3 "keymetrics" : [4 {5 "key" : "requestCount",6 "aggregation" : "avg",7 "mergeaggregation" : "sum",8 "displayname" : "Requests"9 }10 ],11 "keycharts" : [ ],12 "charts": [ ]13 }14 }
The keymetrics
section is completely optional and allows you to define up to two metrics that should be part of the Process infographic. It has the following attributes:
key | String | The key for the time series to put into the graphic. Only letters, numbers, and "-" , "_" characters are allowed. |
aggregation | String | Aggregation defines the method to aggregate the minute values when working with longer timeframes. Dynatrace captures a value every 10 seconds but only sends one aggregate value per minute. This specifies how to aggregate these 10 second values. |
mergeaggregation | String | If the metric contains multiple dimensions, this defines how to aggregate the dimension values into a single dimension. |
displayname | String | The name to display in the infographic |
Each chart section has the same format and looks like this:
1{2 "group": "Section Name",3 "title": "Chart Name",4 "series": [5 {6 "key": "MetricName",7 "aggregation": "avg",8 "displayname": "Display name for metric",9 "seriestype": "area"10 },11 {12 "key": "Other Metric Name",13 "aggregation": "avg",14 "displayname": "Display name for metric",15 "color": "rgba(42, 182, 244, 0.6)",16 "seriestype": "area"17 }18 ]19 }
The charts section describes how to chart each metric in the details section of the process page (available by selecting Further details).
Both sections allow an array of charts to be defined. A chart has the following required attributes:
group | String | The section name that the chart should be placed in |
title | String | The name of the chart |
series | Array | An array of timeseries and charting definitions. One chart can contain multiple metrics. |
A series has the following attributes:
key | String | The key for the time series to chart |
displayname | String | Display name to display for the metric. Overwrites the metric displayname. Default: metric displayname. |
aggregation | String | How multiple minute values should be aggregated in charts when viewing a longer time frame. Possible values: SUM , AVG , MIN , MAX |
mergeaggregation | String | Key charts don't show multiple dimensions. If the metric contains multiple dimensions, this defines how to aggregate the dimension values into a single dimension. |
color | String | HTML notation of a color (RGB or RGBA). |
seriestype | String | Chart type. Possible values are: line , area , and bar |
rightaxis | Boolean | If true, the metric will be placed on the right axis instead of the left axis. Note that Dynatrace supports dual-axis charts. |
stacked | Boolean | When true, multiple metrics are stacked upon each other. This only works for area and bar charts. |
