Monitoring unavailable events
  • Latest Dynatrace
  • Explanation
  • 2-min read
A monitoring unavailable event indicates a widespread monitoring interruption, where the majority of your installed OneAgents lose their connection with the Dynatrace server.
Symptoms
This usually manifests itself as a lack of visibility in terms of both availability and performance monitoring. In case of a monitoring interruption:
  • Dynatrace automatically suppresses all individual Host unavailable problems and alerts you to the monitoring interruption.
  • All hosts are set to the availability state Unmonitored for the duration of the monitoring outage.
Probable causes
Monitoring interruptions can have different root causes depending on the type of Dynatrace deployment you're running:
  • Dynatrace SaaS environments are administered by the Dynatrace DevOps team, who post all operational issues to dynatrace.status.io.
  • For environments running in Dynatrace Managed deployments, it's most likely that the monitoring interruption is caused by an issue within your own data center or network configuration.
Regardless of the type of Dynatrace deployment, a common cause of monitoring interruptions is ActiveGate operating issues. To minimize the risk of interruptions caused by ActiveGate, you can use ActiveGate self-monitoring metrics to assess the health of your ActiveGates in a timely manner.
Troubleshooting
To troubleshoot a monitoring unavailable event, see Troubleshooting monitoring interruptions.
Problem and alert filtering
The monitoring unavailable severity level enables you to filter for these highly critical alerts and quickly route them to your monitoring operations teams.
Problems
To view monitoring unavailable problems
  1. Go to Problems.
  2. In the Filter by box, select Severity: Monitoring unavailable.
For more on problems, see Dynatrace Intelligence.
Related tags
Dynatrace Platform
