A monitoring unavailable event indicates a widespread monitoring interruption, where the majority of your installed OneAgents lose their connection with the Dynatrace server.
This usually manifests itself as a lack of visibility in terms of both availability and performance monitoring. In case of a monitoring interruption:
Monitoring interruptions can have different root causes depending on the type of Dynatrace deployment you're running:
Regardless of the type of Dynatrace deployment, a common cause of monitoring interruptions is ActiveGate operating issues. To minimize the risk of interruptions caused by ActiveGate, you can use ActiveGate self-monitoring metrics to assess the health of your ActiveGates in a timely manner.
To troubleshoot a monitoring unavailable event, see Troubleshooting monitoring interruptions (Dynatrace Classic).
The monitoring unavailable severity level enables you to filter for these highly critical alerts and quickly route them to your monitoring operations teams.
To view monitoring unavailable problems
Severity: Monitoring unavailable.For more on problems, see Davis AI.
