The following page lists the default limits of Davis AI components.
Some of the problems and events limits apply per provider. The following providers are subject to limits:
AGENT_LOCAL_REST_API_INGESTAVAILABILITYBASELININGEVENTS_REST_API_INGESTKUBERNETES_ANOMALY_DETECTIONKUBERNETES_EVENTLOG_EVENTSMETRIC_EVENTSONEAGENTOPENPIPELINE_DATA_EXTRACTIONREAL_USER_MONITORINGSYNTHETICThe maximum number of simultaneously active Davis problems within a single environment is 10,000.
The maximum number of simultaneously active Davis events within a single environment, across all event providers, is 15,000.
The maximum number of simultaneously active Davis events per event provider is 4,000. Example of the event provider: event.provider = "AVAILABILITY".
The maximum number of Davis events per event provider that can be processed within an hour is 100,000. This limit is replenished every hour.
Certain events override default limits. See the table below for more information.
| Event provider | Maximum limit |
| 200,000 Davis events processed per hour. |
| The default of 100,000 Davis events processed per hour applies. |
The maximum lifetime for active events is 60 days. If the underlying anomaly doesn't disappear after 60 days, the respective event is closed and a new one is created.
The maximum problem merging timeframe is 90 minutes. If the problem remains unresolved for more than 90 minutes, no new events will be merged into it after that.
This measure ensures that Davis AI avoids collecting unrelated information for long-lasting incidents.
| Item | Maximum limit | Description |
Number of metric events | 10,000 per environment | The maximum number of metric events that can be configured. |
Number of monitored dimensions | 100,000 | This limit applies across all customer-defined metric selector metric events. Dynatrace also counts aggregated dimensions towards the limit. Once the limit is reached, no additional dimensions will be monitored. |
Number of static threshold metric event configurations | 100 | The maximum number of static threshold model metric event configurations created with metric selector. |
Number of static threshold monitored dimensions | 1,000 per configuration | The maximum number of static threshold monitored dimensions. Once the limit is reached, no additional dimensions will be monitored. |
Number of auto-adaptive threshold metric event configurations | 100 | The maximum number of metric event configurations that use the auto-adaptive threshold model. |
Number of auto-adaptive threshold monitored dimensions | 1,000 per configuration | The maximum number of auto-adaptive threshold monitored dimensions. Once the limit is reached, no additional dimensions will be monitored. |
Number of seasonal baseline metric event configurations | 100 | The maximum number of metric event configurations that use the seasonal baseline model. |
Number of seasonal baseline monitored dimensions | 500 per configuration | The maximum number of seasonal baseline monitored dimensions. Once the limit is reached, no additional dimensions will be monitored. |
Hard monitored dimension limit | 10,000 per configuration | If the number of monitored dimensions exceeds the hard limit, the query will start failing. |
Number of simultaneously active alerts | 200 per configuration | The maximum number of simultaneously active alerts per metric key-based configuration. |
