A new Dynatrace Docs experience launches December 9, built for people and AI agents. Existing links will redirect.
Adjust the sensitivity of anomaly detection for extension events
Latest Dynatrace
How-to guide
1-min read
Extensions that you have installed provide various event thresholds that are evaluated by anomaly detection. The particular list depends on the extension.
To configure performance-anomaly thresholds for infrastructure components that are monitored with extensions
Go to Settings Classic > Anomaly detection > Extension events. Here you'll find a list of all the event types that your installed monitoring extensions provide.
Expand the required event to see and configure available thresholds.
