Info events in Dynatrace Classic
  • Dynatrace Classic
  • Explanation
  • 4-min read
This page provides information about supported informational events and the logic behind raising them.
Annotation
CUSTOM_ANNOTATION
Annotation events can be sent to Dynatrace by third-party tools to highlight interesting periods in time. There are multiple channels that can be used to automatically report annotations into Dynatrace, including the Events API v2 and monitoring plugins.
Applicable Dynatrace entities
All Dynatrace entities apply to this event.
Deployment
CUSTOM_DEPLOYMENT
Deployment events can be sent to Dynatrace by third-party tools to report software deployments along with important business-process related metadata, such as the authorizer, product owner, and version details. There are multiple channels that can be used to automatically report deployment events into Dynatrace, including the Dynatrace REST API and monitoring plugins.
Info
CUSTOM_INFO
Info events can be sent to Dynatrace by third-party tools to report general information about important events. There are multiple channels that can be used to automatically report information events into Dynatrace, including the Dynatrace REST API and monitoring plugins.
Log pattern matched on host or process
LOG_MATCHED
You can define custom log pattern matching rules that apply to log files on both the host level and the process level. If a user-defined threshold of matching patterns per minute is breached, a log info event will be raised and displayed either on the host or the process level.
Elastic load balancer has a failure rate
ELASTIC_LOAD_BALANCER_HIGH_FAILURE_RATE
Dynatrace automatically reports the number of failed connection attempts to an AWS load balancer. By default, Dynatrace opens an alert if the number of failed connection attempts is higher than 10 per minute in at least 3 of 5 one-minute observation intervals.
The following Dynatrace entities apply to this event:
  • Elastic load balancer
Elastic load balancer has a high unhealthy host rate
ELASTIC_LOAD_BALANCER_HIGH_UNHEALTHY_HOST_RATE
Dynatrace automatically opens an info event when a high rate of unhealthy hosts is detected within an AWS load balancer.
JavaScript framework changes
APPLICATION_JS_FRAMEWORK_DETECTED
Real User Monitoring keeps track of all JavaScript frameworks that are used in your applications. A JavaScript framework change event is opened if either a new JavaScript framework is detected or a JavaScript framework is removed.
  • Application
Marked for termination
MARKED_FOR_TERMINATION
By default, Dynatrace raises a problem when a monitored entity becomes unavailable. However, in some instances, you may need to bring an entity down purposely (for example, disabling monitoring of a host during a maintenance window). To avoid unnecessary notifications and problem alerts, assign this event to any entity you're about to shut down. For the next 60 minutes, it will prevent Dynatrace from raising a problem when the entity becomes unavailable.
The Alert on graceful host shutdown option overrules the MARKED_FOR_TERMINATION event and raises an alert nevertheless.
  • Hosts
Out of memory kill
An "Out of memory kill" event indicates that OOM Killer was triggered to kill the container because it exceeded the container's memory limit.
  • It may indicate that you need to change the memory limit on the container, or that an unexpected amount of memory was being used on the container.
  • This event does not raise an alert, but you can configure a custom event for alerting based on the Out of memory kills metric.
  • Container
Related tags
Dynatrace Platform
