Adjust the sensitivity of anomaly detection for extension events in Dynatrace Classic
  • Dynatrace Classic
  • How-to guide
  • 1-min read
Extensions that you have installed provide various event thresholds that are evaluated by anomaly detection. The particular list depends on the extension.
To configure performance-anomaly thresholds for infrastructure components that are monitored with extensions
  1. Go to Settings > Anomaly detection > Extension events. Here you'll find a list of all the event types that your installed monitoring extensions provide.
  2. Expand the required event to see and configure available thresholds.
Related tags
Dynatrace Platform
