Validate a settings property
  • Latest Dynatrace
  • Reference
  • Published Oct 13, 2026
Validate a Dynatrace settings property value with a custom validator using the Settings API before you save the settings object it belongs to.
POSTSaaShttps://{your-environment-id}.apps.dynatrace.com/platform/settings/v1/values/{schema-id}:validate-property
Overview
You use the schema-id path parameter and the required validator-id query parameter to validate one property value with a custom validator of the schema. The optional scope and schema-version query parameters set the context. Typical usage is validating user input in a settings editor while the user types.
Authentication
To execute this request, you need a platform token or OAuth access token with settings:schemas:read scope. To learn how to obtain and use it, see Tokens and authentication.
Parameters
ParameterTypeDescriptionInRequired
schema-idstring
The ID of the schema.
pathRequired
scopestring
The ID of the scope.
queryOptional
validator-idstring
The identifier of the validator.
queryRequired
schema-versionstring
Version of the schema.
queryOptional
bodyCustomPropertyValidationRequest
The JSON body of the request. Contains the settings object to be validated.
bodyRequired
Request body objects
The CustomPropertyValidationRequest object
The request payload for a custom validation of a single property value.
ElementTypeDescriptionRequired
pathstring
The path of the property being validated.
Optional
intValueinteger
The property value.
Optional
floatValuenumber
The property value.
Optional
stringValuestring
The property value.
Optional
booleanValueboolean
The property value.
Optional
arrayValue-
The property value.
Optional
Request body JSON model
This is a model of the request body, showing the possible elements. It has to be adjusted for usage in an actual request.
"path": "string",
"intValue": 1,
"floatValue": 1,
"stringValue": "string",
"booleanValue": true,
"arrayValue": [
Response
Response codes
CodeTypeDescription
200ValidationResponse
Validated. Details in the response body.
404--
429--
503--
4XX--
5XX--
Response body objects
The ValidationResponse object
validboolean-
messagestring-
constraintViolationsViolationResponse[]-
The ViolationResponse object
messagestring-
pathstring-
Response body JSON models
"valid": true,
"message": "string",
"constraintViolations": [
"path": "string"
Related tags
Platform APIDynatrace Platform
