Validate a settings container
  • Latest Dynatrace
  • Reference
  • Published Oct 13, 2026
Validate a Dynatrace settings container with a custom validator using the Settings API to check a group of related values before you save them.
POSTSaaShttps://{your-environment-id}.apps.dynatrace.com/platform/settings/v1/values/{schema-id}:validate-container
Overview
You use the schema-id path parameter and the required validator-id query parameter to validate a settings container, a group of related values, with a custom validator of the schema. The optional scope and schema-version query parameters set the context. Typical usage is checking related fields together in a settings editor.
Authentication
To execute this request, you need a platform token or OAuth access token with settings:schemas:read scope. To learn how to obtain and use it, see Tokens and authentication.
Parameters
ParameterTypeDescriptionInRequired
schema-idstring
The ID of the schema.
pathRequired
scopestring
The ID of the scope.
queryOptional
validator-idstring
The identifier of the validator.
queryRequired
schema-versionstring
Version of the schema.
queryOptional
bodyCustomContainerValidationRequest
The JSON body of the request. Contains the settings object to be validated.
bodyRequired
Request body objects
The CustomContainerValidationRequest object
The request payload for a custom validation of a container.
ElementTypeDescriptionRequired
pathstring
The path of the container being validated.
Optional
keystring
The key of the setting being validated.
Optional
valueCustomContainerValidationRequestValue
The container value.
Required
The CustomContainerValidationRequestValue object
Request body JSON model
This is a model of the request body, showing the possible elements. It has to be adjusted for usage in an actual request.
"path": "string",
"key": "string",
"value": {}
Response
Response codes
CodeTypeDescription
200ValidationResponse
Validated. Details in the response body.
404--
429--
503--
4XX--
5XX--
Response body objects
The ValidationResponse object
validboolean-
messagestring-
constraintViolationsViolationResponse[]-
The ViolationResponse object
messagestring-
pathstring-
Response body JSON models
"valid": true,
"message": "string",
"constraintViolations": [
"path": "string"
Related tags
Platform APIDynatrace Platform
