Get ActiveGate connection information
  • Latest Dynatrace
  • Reference
  • Published Oct 13, 2026
Get the connection information an ActiveGate needs to connect to your Dynatrace environment with the Fleet Management API, for example during setup.
GETSaaShttps://{your-environment-id}.apps.dynatrace.com/v1/activegate/connection-info
Overview
You use this operation to retrieve the connection information for ActiveGates in your environment. It takes no parameters and returns the connection details with a 200 response. Typical usage is configuring a new ActiveGate, for example in an automated deployment that sets up the connection without manual steps.
Authentication
To execute this request, you need a platform token or OAuth access token with fleet-management:activegate.connection-info:read scope. To learn how to obtain and use it, see Tokens and authentication.
Parameters
The request doesn't provide any configurable parameters.
Response
Response codes
CodeTypeDescription
200ConnectionInfo
Success
4XXErrorEnvelope
Client side error.
5XXErrorEnvelope
Server side error.
Response body objects
The ConnectionInfo object
Connection info with tenant data and initial tenant endpoint
ElementTypeDescription
initialEndpointstring
Initial tenant endpoint.
tenantTokenstring
Tenant token.
tenantUUIDstring
Tenant UUID.
The ErrorEnvelope object
errorError-
The Error object
codeinteger
The HTTP status code
constraintViolationsConstraintViolation[]
A list of constraint violations
messagestring
The error message
The ConstraintViolation object
locationstring-
messagestring-
parameterLocationstring-
The element can hold these values
  • HEADER
  • PATH
  • PAYLOAD_BODY
  • QUERY
pathstring-
Response body JSON models
"initialEndpoint": "string",
"tenantToken": "string",
"tenantUUID": "string"
"error": {
"code": 1,
"constraintViolations": [
"location": "string",
"message": "string",
"parameterLocation": "HEADER",
"path": "string"
"message": "string"
Related tags
Platform APIDynatrace Platform
