Synthetic monitor executions API v2 - POST batch execution
  • Reference
Triggers a batch execution of synthetic monitors.
The request consumes and produces an application/json payload.
POSTSaaShttps://{your-environment-id}.live.dynatrace.com/api/v2/synthetic/executions/batch
POSTEnvironment ActiveGateCluster ActiveGatehttps://{your-activegate-domain}:9999/e/{your-environment-id}/api/v2/synthetic/executions/batch
Authentication
Api-Token:
To execute this request, you need an access token with one of the following scopes:
  • syntheticExecutions.write
  • ExternalSyntheticIntegration
To learn how to obtain and use it, see Personal access tokens.
Parameters
ParameterTypeDescriptionInRequired
bodySyntheticOnDemandExecutionRequest
The JSON body of the request. Contains the parameters of the triggered on-demand execution.
bodyRequired
Request body objects
The SyntheticOnDemandExecutionRequest object
Contains parameters for the on-demand execution of monitors identified by tags, applications, or services.
ElementTypeDescriptionRequired
failOnPerformanceIssueboolean
If true, the execution will fail in case of performance issue.
Optional
failOnSslWarningboolean
Applies to HTTP monitors only. If true, the execution will fail in case of an SSL certificate expiration warning or if the certificate is missing.
Optional
groupSyntheticOnDemandExecutionRequestGroup
Optional
metadataobject
String to string map of metadata properties for execution
Optional
monitorsSyntheticOnDemandExecutionRequestMonitor[]
List of monitors to be triggered.
Optional
processingModestring
The execution's processing mode
The element can hold these values
  • STANDARD
  • DISABLE_PROBLEM_DETECTION
  • EXECUTIONS_DETAILS_ONLY
Optional
stopOnProblemboolean
If true, no executions will be scheduled if a problem occurs.
Optional
takeScreenshotsOnSuccessboolean
If true, the screenshots will be taken during the execution of a browser monitor.
Optional
The SyntheticOnDemandExecutionRequestGroup object
applicationsstring[]
List of application identifiers. Only monitors with all applications assigned will be executed.
Optional
locationsstring[]
The locations from where monitors are to be executed.
Optional
servicesstring[]
List of service identifiers. Only monitors with all services assigned will be executed.
Optional
tagsstring[]
List of tags. Only monitors with all tags assigned will be executed.
Optional
The SyntheticOnDemandExecutionRequestMonitor object
Contains monitors to be executed on demand from the locations specified.
customizedScriptobject
Customized script properties for this on-demand batch execution.
Optional
executionCountinteger
The number of times the monitor is to be executed per location; if not set, the monitor will be executed once.
Optional
locationsstring[]
The locations from where the monitor is to be executed.
Optional
monitorIdstring
The monitor identifier.
Required
repeatModestring
Execution repeat mode. If not set, the mode is SEQUENTIAL.
  • SEQUENTIAL
  • PARALLEL
Optional
Request body JSON model
This is a model of the request body, showing the possible elements. It has to be adjusted for usage in an actual request.
"failOnPerformanceIssue": false,
"failOnSslWarning": true,
"group": {
"applications": [
"APPLICATION-CD4BEF05FA9DD044"
"services": [
"SERVICE-01C6C1282960638B",
"SERVICE-B18840B4E3115C1A"
"tags": [
"tag-production",
"another-tag"
"metadata": {
"key": "value",
"version": "1.255.20221022"
"monitors": [
"customizedScript": {
"requests": [
"sequenceId": "1",
"url": "https://www.somepage.org",
"validation": {
"rules": [
"passIfFound": "true",
"type": "httpStatusesList",
"value": "=201"
"executionCount": 3,
"locations": [
"SYNTHETIC_LOCATION-9BB04DAEBA71B8CA",
"SYNTHETIC_LOCATION-ACCA399FAA1194DD"
"monitorId": "HTTP_CHECK-6349B98E1CD87352",
"repeatMode": "SEQUENTIAL"
"processingMode": "EXECUTIONS_DETAILS_ONLY",
"stopOnProblem": true,
"takeScreenshotsOnSuccess": true
Response
Response codes
CodeTypeDescription
201SyntheticOnDemandExecutionResult
Success. The monitor's execution response details
400ErrorEnvelope
Failed. The input is invalid.
503ErrorEnvelope
Unavailable
4XXErrorEnvelope
Client side error.
5XXErrorEnvelope
Server side error.
Response body objects
The SyntheticOnDemandExecutionResult object
The result of on-demand synthetic monitor execution.
batchIdstring
The batch identifier of the triggered executions.
triggeredSyntheticOnDemandTriggeredMonitor[]
Monitors for which on-demand executions were triggered.
triggeredCountinteger
The total number of the triggered executions within the batch.
triggeringProblemsCountinteger
The total number of problems within the batch.
triggeringProblemsDetailsSyntheticOnDemandTriggeringProblemDetails[]
List with the entities for which triggering problems occurred.
The SyntheticOnDemandTriggeredMonitor object
Contains the list of on-demand executions of the monitor.
executionsSyntheticOnDemandTriggeredExecutionDetails[]
The list of triggered executions.
monitorIdstring
The SyntheticOnDemandTriggeredExecutionDetails object
Contains details of the triggered on-demand execution.
executionIdstring
The execution's identifier.
locationIdstring
The identifier of the location from which the monitor is to be executed.
The SyntheticOnDemandTriggeringProblemDetails object
Contains the details of problems encountered while triggering on-demand executions.
causestring
The cause of not triggering entity.
detailsstring
The details of triggering problem.
entityIdstring
The entity identifier.
executionIdstring
The execution identifier.
locationIdstring
The location identifier.
The ErrorEnvelope object
errorError-
The Error object
codeinteger
The HTTP status code
constraintViolationsConstraintViolation[]
A list of constraint violations
messagestring
The error message
The ConstraintViolation object
locationstring-
messagestring-
parameterLocationstring-
  • HEADER
  • PATH
  • PAYLOAD_BODY
  • QUERY
pathstring-
Response body JSON models
"batchId": "22396514015719218",
"triggered": [
"executions": [
"executionId": "1069999568093682590",
"locationId": "SYNTHETIC_LOCATION-9BB04DAE11123122"
"monitorId": "HTTP_CHECK-69A9B98E1CD87352"
"triggeredCount": 1,
"triggeringProblemsCount": 4,
"triggeringProblemsDetails": [
"cause": "Location not found",
"entityId": "HTTP_CHECK-6349B98E1CD87352",
"locationId": "SYNTHETIC_LOCAT-9BB04DAEBA71B8CA"
"cause": "Monitor not found",
"entityId": "HTTP_CHECK-6349B98E1CD85432"
"cause": "Incorrect monitor identifier format",
"entityId": "HTTP_HACK-AAAAAAA"
"cause": "Incorrect application identifier format",
"entityId": "APPLICATION-WRONG"
"error": {
"code": 1,
"constraintViolations": [
"location": "string",
"message": "string",
"parameterLocation": "HEADER",
"path": "string"
"message": "string"
Related topics
  • Synthetic Monitoring Classic
