Timeseries API v1 - POST data points
  • Reference
  • Published Nov 07, 2019
This API is deprecated. It will be removed in the future. Use Metrics API v2 instead.
Fetches parameters and data points of the specified metric. In comparison to a GET request, a POST request provides less data about the metric itself.
To obtain data points, you must specify the timeframe and the aggregation type supported by the requested metric. See the Parameters section for more details.
The request consumes and produces an application/json payload.
POSTSaaShttps://{your-environment-id}.live.dynatrace.com/api/v1/timeseries/{timeseriesIdentifier}
POSTEnvironment ActiveGatehttps://{your-activegate-domain}:9999/e/{your-environment-id}/api/v1/timeseries/{timeseriesIdentifier}
Authentication
Api-Token:
To execute this request, you need an access token with DataExport scope.
To learn how to obtain and use it, see Personal access tokens.
Parameters
To obtain data points, you must specify the timeframe and the aggregation type.
There are two mutually exclusive ways to set timeframe:
  • Combination of startTimestamp and endTimestamp.
  • relativeTime
The maximum allowed timeframe is 6 months.
ParameterTypeDescriptionInRequired
timeseriesIdentifierstring
The case-sensitive ID of the timeseries from which you want to read parameters and data points.
pathRequired
bodyTimeseriesQueryMessage
The JSON body of the request, containing parameters to identify the required data points.
bodyOptional
Request body objects
The TimeseriesQueryMessage object
Filtering parameters for a timeseries query.
ElementTypeDescriptionRequired
aggregationTypestring
The aggregation type for the resulting data points.
If the requested metric doesn't support the specified aggregation, the request will result in an error.
The element can hold these values
  • AVG
  • COUNT
  • MAX
  • MEDIAN
  • MIN
  • PERCENTILE
  • SUM
Optional
considerMaintenanceWindowsForAvailabilityboolean
Exclude (true) or include (false) data points from any maintenance window, defined in your environment.
Optional
endTimestampinteger
The start timestamp of the timeframe, in UTC milliseconds.
If later than the current time, Dynatrace automatically uses current time instead.
The timeframe must not exceed 6 months.
Optional
entitiesstring[]
Filters requested data points by entities which should deliver them. You can specify several entities at once.
Allowed values are Dynatrace entity IDs.
If the selected entity doesn't support the requested metric, the request will result in an error.
Optional
filtersobject
A filter is an object, containing map of filter keys and its values. Valid filter keys are:
processType: Filters by process type. See Process types for allowed values. osType: Filters by operating system. See OS types for allowed values. serviceType: Filters by service type. See Service types for allowed values. technology: Filters by technology type. See Technology types for allowed values. webServiceName: Filters by web service name. webServiceNamespace: Filters by the web service namespace. host: Filters by entity ID of the host, for example HOST-007.
Optional
includeParentIdsboolean
Specifies whether the results should exposes dimension mappings between parent entities and their children.
For instance: SERVICE-0000000000000001, SERVICE_METHOD-0000000000000001
Optional
percentileinteger
Specifies which percentile of the selected response time metric should be delivered.
Only applicable to the PERCENTILE aggregation type.
Valid values for percentile are between 1 and 99.
Please keep in mind that percentile export is only possible for response-time based metrics such as application and service response times.
Optional
predictboolean
The flag to predict future data points.
Optional
queryModestring
Defines the type of result that the call should return. Valid result modes are:
series: returns all the data points of the metric in the specified timeframe. total: returns one scalar value for the specified timeframe.
By default, the series mode is used.
  • SERIES
  • TOTAL
Optional
relativeTimestring
The relative timeframe, back from the current time.
  • 10mins
  • 15mins
  • 2hours
  • 30mins
  • 3days
  • 5mins
  • 6hours
  • day
  • hour
  • min
  • month
  • week
Optional
startTimestampinteger
Optional
tagsstring[]
Filters requiested data points by entity which should deliver them. Only data from entities with the specified tag is delivered.
You can specify several tags in the following format: tags=tag1&tags=tag2. The entity has to match all the specified tags.
In case of key-value tags, such as imported AWS or CloudFoundry tags use following format: [context]key:value.
Optional
timeseriesIdstring
The case-sensitive ID of the metric, where you want to read data points.
You can execute a GET timeseries request, to obtain the list of available metrics.
Optional
Request body JSON model
This is a model of the request body, showing the possible elements. It has to be adjusted for usage in an actual request.
"aggregationType": "AVG",
"considerMaintenanceWindowsForAvailability": "false",
"endTimestamp": 1521542929000,
"entities": [
"HOST-0000000000000007"
"includeParentIds": "false",
"predict": true,
"queryMode": "SERIES",
"relativeTime": "HOUR",
"startTimestamp": 1521042929000,
"tags": [
"office-linz"
"timeseriesId": "com.dynatrace.builtin:host.cpu.idle"
Response
The result is a JSON object that contains metric data points and parameters.
Response codes
CodeTypeDescription
200TimeseriesQueryResultWrapper
Success
4XXErrorEnvelope
Client side error.
5XXErrorEnvelope
Server side error.
Response body objects
The TimeseriesQueryResultWrapper object
resultTimeseriesDataPointQueryResult
List of metric's datapoints, as well as their parameters.
The TimeseriesDataPointQueryResult object
The type of data points aggregation.
  • AVG
  • COUNT
  • MAX
  • MEDIAN
  • MIN
  • PERCENTILE
  • SUM
dataPointsobject
Data points of a metric.
A JSON object that maps the ID of the entity that delivered the data points and an array, which consists of arrays of the data point float values.
May contain more than one entity ID per record (for example, a host and its network interface). In such cases, entity IDs are separated by commas.
A datapoint contains a value and a timestamp, at which the value was recorded.
Dynatrace stores data in time slots. The dataPoints object shows the starting timestamp of the slot. If the startTimestamp or endTimestamp of your query lies inside of the data time slot, this time slot is included into response. Due to the fact that the timestamp of the first data point lies outside of the specified timeframe, you will see earlier timestamp than the specified startTimestamp in the first data point of the response.
There are three versions of data points:
  • Numeric datapoint: Contains a numeric value.
  • Enum datapoint: Contains an enum value, currently only for availability timeseries.
  • Prediction datapoint: Similar to the numeric datapoint, but it contains a confidence interval, within which the future values are expected to be.
entitiesobject
The list of entities where the data points originate.
A JSON object that maps the entity ID in Dynatrace and the actual name of the entity.
resolutionInMillisUTCinteger
The resolution of data points.
timeseriesIdstring
The ID of the metric.
unitstring
The unit of data points.
  • Ampere (A)
  • Billion (Gcount)
  • Bit (bit)
  • BitPerHour (bit/h)
  • BitPerMinute (bit/min)
  • BitPerSecond (bit/s)
  • Byte (B)
  • BytePerHour (B/h)
  • BytePerMinute (B/min)
  • BytePerSecond (B/s)
  • Cores
  • Count (count)
  • Day (ds)
  • DecibelMilliWatt (dBm)
  • G
  • GibiByte (GiB)
  • GibiBytePerHour (GiB/h)
  • GibiBytePerMinute (GiB/min)
  • GibiBytePerSecond (GiB/s)
  • GigaByte (GB)
  • GigaBytePerHour (GB/h)
  • GigaBytePerMinute (GB/min)
  • GigaBytePerSecond (GB/s)
  • Hertz (Hz)
  • Hour (hs)
  • KibiByte (KiB)
  • KibiBytePerHour (KiB/h)
  • KibiBytePerMinute (KiB/min)
  • KibiBytePerSecond (KiB/s)
  • KiloByte (kB)
  • KiloBytePerHour (kB/h)
  • KiloBytePerMinute (kB/min)
  • KiloBytePerSecond (kB/s)
  • M
  • MSU
  • MebiByte (MiB)
  • MebiBytePerHour (MiB/h)
  • MebiBytePerMinute (MiB/min)
  • MebiBytePerSecond (MiB/s)
  • MegaByte (MB)
  • MegaBytePerHour (MB/h)
  • MegaBytePerMinute (MB/min)
  • MegaBytePerSecond (MB/s)
  • MicroSecond (µs)
  • MilliSecond (ms)
  • MilliSecondPerMinute (ms/min)
  • Million (Mcount)
  • Minute (mins)
  • Month (mos)
  • N/A
  • NanoSecond (ns)
  • NanoSecondPerMinute (ns/min)
  • PerHour (count/h)
  • PerMinute (count/min)
  • PerSecond (count/s)
  • Percent (%)
  • Pixel (px)
  • Promille (‰)
  • Ratio
  • Second (s)
  • State
  • Trillion (Tcount)
  • Unspecified
  • Volt (V)
  • Watt (W)
  • Week (ws)
  • Year (ys)
  • k
  • km/h
  • m/h
  • m/s
  • mCores
The ErrorEnvelope object
errorError-
The Error object
codeinteger
The HTTP status code
constraintViolationsConstraintViolation[]
A list of constraint violations
messagestring
The error message
The ConstraintViolation object
locationstring-
messagestring-
parameterLocationstring-
  • HEADER
  • PATH
  • PAYLOAD_BODY
  • QUERY
pathstring-
Response body JSON models
"result": {
"dataPoints": {
"HOST-0000000000000007": [
1522220334000,
89
"entities": {
"HOST-0000000000000007": "Laptop-8"
"resolutionInMillisUTC": 300000,
"timeseriesId": "com.dynatrace.builtin:host.cpu.idle",
"unit": "Percent"
"error": {
"code": 1,
"constraintViolations": [
"location": "string",
"message": "string",
"parameterLocation": "HEADER",
"path": "string"
"message": "string"
Timeframe note
Dynatrace stores data in time slots. The dataPoints object shows the starting timestamp of the slot. If the startTimestamp or endTimestamp of your query fall within the data time slot, this time slot will be included in the response. Due to the fact that the timestamp of the first data point lies outside of the specified timeframe, you will see an earlier timestamp than the specified startTimestamp in the first data point of the response.
Timestamp scheme
Timestamp scheme
Example
In this example, the request returns values of the Actions per session (com.dynatrace.builtin:app.actionspersession) metric within the last hour for the APPLICATION-85A7CC and APPLICATION-8E41C8 applications. The result returns the average numbers of user actions per application. The result is truncated to three data points per application.
Curl
curl -X POST \
https://mySampleEnv.live.dynatrace.com/api/v1/timeseries \
-H 'Authorization: abcdefjhij1234567890' \
-H 'Content-Type: application/json' \
-d '{
"timeseriesId": "com.dynatrace.builtin:app.actionspersession",
"relativeTime": "hour",
"aggregationType": "avg",
"entities": [
"APPLICATION-85A7CCAAC7345F0B",
"APPLICATION-8E41C8C247910758"
Request URL
Request body
"entities": [
"APPLICATION-85A7CC",
"APPLICATION-8E41C8"
Response content
"result": {
"dataPoints": {
"APPLICATION-85A7CC": [
1534920000000,
1.6666666666666667
1534920060000,
2.5
1534920120000,
2.888888888888889
"APPLICATION-8E41C8": [
1534920000000,
null
1534920060000,
3
1534920120000,
null
"unit": "PerMinute (count/min)",
"resolutionInMillisUTC": 60000,
"entities": {
"APPLICATION-85A7CC": "Permanent Docker",
"APPLICATION-8E41C8": "easyTravel AMP"
Response code
200
