Timeseries API v1 - DELETE a custom metric
  • Reference
  • Published Nov 07, 2019
Deletes the specified custom metric. If you delete a metric definition, you lose all of that metric's data, so be careful with deletes.
Built-in metrics can't be deleted.
DELETESaaShttps://{your-environment-id}.live.dynatrace.com/api/v1/timeseries/{timeseriesIdentifier}
DELETEEnvironment ActiveGatehttps://{your-activegate-domain}:9999/e/{your-environment-id}/api/v1/timeseries/{timeseriesIdentifier}
Authentication
Api-Token:
To execute this request, you need an access token with DataExport scope.
To learn how to obtain and use it, see Personal access tokens.
Parameters
ParameterTypeDescriptionInRequired
timeseriesIdentifierstring
The ID of the metric to delete.
pathRequired
Response
Response codes
CodeTypeDescription
204-
Success. The custom metric has been deleted.
4XXErrorEnvelope
Client side error.
5XXErrorEnvelope
Server side error.
Response body objects
The ErrorEnvelope object
ElementTypeDescription
errorError-
The Error object
codeinteger
The HTTP status code
constraintViolationsConstraintViolation[]
A list of constraint violations
messagestring
The error message
The ConstraintViolation object
locationstring-
messagestring-
parameterLocationstring-
The element can hold these values
  • HEADER
  • PATH
  • PAYLOAD_BODY
  • QUERY
pathstring-
Response body JSON models
"error": {
"code": 1,
"constraintViolations": [
"location": "string",
"message": "string",
"parameterLocation": "HEADER",
"path": "string"
"message": "string"
Example
In this example, the request deletes the custom:firewall.connections.dropped custom metric.
The API token is passed in the Authorization header.
Curl
curl -X DELETE \
https://mySampleEnv.live.dynatrace.com/api/v1/timeseries/custom:firewall.connections.dropped \
-H 'Authorization: Api-Token dt0c01.abc123.abcdefjhij1234567890'
Request URL
Response code
204
