Synthetic metrics API - POST a metric
  • Reference
  • Published Apr 16, 2020
Creates a new calculated synthetic metric.
The request consumes and produces an application/json payload.
POSTSaaShttps://{your-environment-id}.live.dynatrace.com/api/config/v1/calculatedMetrics/synthetic
POSTEnvironment ActiveGatehttps://{your-activegate-domain}:9999/e/{your-environment-id}/api/config/v1/calculatedMetrics/synthetic
Authentication
Api-Token:
To execute this request, you need an access token with WriteConfig scope.
To learn how to obtain and use it, see Personal access tokens.
Parameters
ParameterTypeDescriptionInRequired
bodyCalculatedSyntheticMetric
The JSON body of the request. Contains definition of the new calculated synthetic metric.
bodyOptional
Request body objects
The CalculatedSyntheticMetric object
Definition of the calculated synthetic metric.
ElementTypeDescriptionRequired
dimensionsSyntheticMetricDimension[]
A list of metric dimensions.
Optional
enabledboolean
The metric is enabled (true) or disabled (false).
Required
filterSyntheticMetricFilter
Filter of the calculated synthetic metric.
Optional
metricstring
The type of the synthetic metric.
The element can hold these values
  • ApplicationCache
  • Callback
  • CumulativeLayoutShift
  • DNSLookup
  • DOMComplete
  • DOMContentLoaded
  • DOMInteractive
  • FailedRequestsResources
  • FirstContentfulPaint
  • FirstInputDelay
  • FirstInputStart
  • FirstPaint
  • HTMLDownloaded
  • HttpErrors
  • JavaScriptErrors
  • LargestContentfulPaint
  • LoadEventEnd
  • LoadEventStart
  • LongTasks
  • NavigationStart
  • OnDOMContentLoaded
  • OnLoad
  • Processing
  • RedirectTime
  • Request
  • RequestStart
  • ResourceCount
  • Response
  • SecureConnect
  • SpeedIndex
  • TCPConnect
  • TimeToFirstByte
  • TotalDuration
  • TransferSize
  • UserActionDuration
  • VisuallyComplete
Required
metricKeystring
The unique key of the metric.
The key must have the calc:synthetic prefix.
Required
monitorIdentifierstring
The Dynatrace entity ID of the synthetic monitor to which the metric belongs.
Required
namestring
The name of the metric, displayed in the UI.
Required
The SyntheticMetricDimension object
Dimension of the calculated synthetic metric.
dimensionstring
The dimension of the metric.
  • Event
  • Location
  • ResourceOrigin
Required
topXinteger
The number of top values to be calculated.
Optional
The SyntheticMetricFilter object
actionTypestring
Only user actions of the specified type are included in the metric calculation.
  • Custom
  • Load
  • Xhr
Optional
errorCodeinteger
Only executions finished with the specified error code are included in the metric calculation.
Optional
eventstring
Only the specified browser clickpath event is included in the metric calculation.
Specify the Dynatrace entity ID of the event here. You can fetch the list of clickpath events of the monitor with the GET a synthetic monitor request from the Environment API
Optional
hasErrorboolean
The execution status of the monitors to be included in the metric calculation:
  • true: Only failed executions are included.
  • false: All executions are included.
Optional
locationstring
Only executions from the specified location are included in the metric calculation.
Specify the Dynatrace entity ID of the location here. You can fetch the list of locations the monitor is running from with the GET a synthetic monitor request from the Environment API.
Optional
Request body JSON model
This is a model of the request body, showing the possible elements. It has to be adjusted for usage in an actual request.
"dimensions": [
"dimension": "Location"
"enabled": true,
"filter": {
"event": "SYNTHETIC_TEST_STEP-1234",
"hasError": true
"metric": "UserActionDuration",
"metricKey": "calc:synthetic.browser.mymetric",
"monitorIdentifier": "SYNTHETIC_TEST-1234",
"name": "MyMetric"
Response
Response codes
CodeTypeDescription
201EntityShortRepresentation
Success. The calculated synthetic metric has been created. Response contains its key and name.
400ErrorEnvelope
Failed. The input is invalid
Response body objects
The EntityShortRepresentation object
The short representation of a Dynatrace entity.
descriptionstring
A short description of the Dynatrace entity.
idstring
The ID of the Dynatrace entity.
namestring
The name of the Dynatrace entity.
The ErrorEnvelope object
errorError-
The Error object
codeinteger
The HTTP status code
constraintViolationsConstraintViolation[]
A list of constraint violations
messagestring
The error message
The ConstraintViolation object
locationstring-
messagestring-
parameterLocationstring-
  • HEADER
  • PATH
  • PAYLOAD_BODY
  • QUERY
pathstring-
Response body JSON models
"description": "Dynatrace entity for the REST API example",
"id": "6a98d7bc-abb9-44f8-ae6a-73e68e71812a",
"name": "Dynatrace entity"
"error": {
"code": 1,
"constraintViolations": [
"location": "string",
"message": "string",
"parameterLocation": "HEADER",
"path": "string"
"message": "string"
Validate payload
We recommend that you validate the payload before submitting it with an actual request. A response code of 204 indicates a valid payload.
The request consumes an application/json payload.
POSTSaaShttps://{your-environment-id}.live.dynatrace.com/api/config/v1/calculatedMetrics/synthetic/validator
POSTEnvironment ActiveGatehttps://{your-activegate-domain}:9999/e/{your-environment-id}/api/config/v1/calculatedMetrics/synthetic/validator
Authentication
Api-Token:
Response
Response codes
CodeTypeDescription
204-
Validated. The submitted calculated synthetic metric is valid. The response doesn't have a body.
400ErrorEnvelope
Failed. The input is invalid.
errorError-
The Error object
codeinteger
messagestring
The error message
locationstring-
messagestring-
  • HEADER
  • PATH
  • PAYLOAD_BODY
  • QUERY
pathstring-
"error": {
"code": 1,
"path": "string"
"message": "string"
Related topics
  • Synthetic Monitoring Classic
