Send Dynatrace notifications to ServiceNow
  • Dynatrace Classic
  • How-to guide
  • 9-min read
For extended capabilities and workflow automation (for example, enabling targeted notification and problem remediation), see Workflows Connectors and actions.
To connect your Dynatrace monitoring environment to your ServiceNow instance, configuration is required both on the ServiceNow instance and in the Dynatrace web UI.
For ServiceNow, Dynatrace offers:
  • Incident integration
  • Event management integration
  • Configuration Management Database (CMDB) integration
Incident integrations
Once you configure Dynatrace incident integration, Dynatrace automatically creates an incident within your ServiceNow instance for every auto-discovered problem.
Dynatrace Incident Integration app
Dynatrace Incident Integration is a ServiceNow environment application that accepts and processes Dynatrace problems and allows you to create incidents within ServiceNow.
If you have installed the ServiceNow Service Graph Connector for Dynatrace, the CIs (Configuration Items) will automatically be associated within the incident.
Prerequisites
  • You have an active ServiceNow ITSM module and license
  • Your ServiceNow user has web_service_admin and x_dynat_ruxit.Integration roles
Set up a ServiceNow configuration
  1. Go to Dynatrace Incident Integration page in the ServiceNow Store and select Get to install Dynatrace Incident Integration in your ServiceNow instance.
  2. Follow the Guided Setup for an initial configuration of the application.
    Guided setup
    Guided setup
  3. After the application is installed, go to the new Dynatrace Incident Integration menu on your ServiceNow instance to further configure (Setup, Settings) and explore (Problems, ServiceNow Incidents) the application.
    Main modules
    Main modules
  4. Use the Problem to Incident Transform Map module to transform the incoming Dynatrace data in the Problems import set table (x_dynat_ruxit_problems) into a ServiceNow Incident table.
    Transform map
    Transform map
Set up a Dynatrace configuration
To create a ServiceNow problem notification
  1. In Dynatrace, go to Settings.
  2. Select Integration > Problem notifications.
  3. Select Add notification.
  4. In Notification type, select ServiceNow.
  5. Enter the requested information:
    • ServiceNow instance identifier refers to the "instance identifier" part of your own ServiceNow URL (https://<instance identifier>.service-now.com) that is used by the ServiceNow API call. This ServiceNow instance identifier is mutually exclusive to the OnPremise URL field, so you can only use one of them.
    • In the Description field, you can customize the text message associated with problem notifications by combining any of the placeholders from Available placeholders list in any order according to your needs.
  6. Turn on Send incidents into ServiceNow ITSM.
  7. Select Send test notification to make sure your ServiceNow integration is working.
  8. Select Save changes.
There are several integration options for event management that use Dynatrace problem notifications. You can:
  • Send events using Dynatrace custom integration problem notifications
  • Send events using Dynatrace ServiceNow problem notifications
ServiceNow Event Management provides an inbound event API for third party tools to receive events.
This configuration uses a custom integration Dynatrace problem notifications. You can configure custom integration notifications with the ServiceNow inbound event API URL and the JSON payload it expects.
When configured, the Dynatrace problem notification will send grouped events related to a problem.
If you have ServiceNow Service Graph Connector for Observability - Dynatrace, see Set up push notifications from Dynatrace for configuration and usage details. Otherwise, see Integrate Dynatrace with basic authentication or Integrate Dynatrace with OAuth authentication.
ServiceNow Event Management provides a general purpose webhook API for receiving events the populates the ServiceNow ITOM event table (em_event).
This configuration uses a ServiceNow Dynatrace problem notification. You can configure ServiceNow notification with the ServiceNow webhook API URL and the JSON payload it expects. For more information about the webhook API, see Pushing events to the instance using web service API.
When configured, the Dynatrace problem notification will send all events related to a problem.
Prerequisites
  • You have an active ServiceNow ITOM module and license
  • Your ServiceNow user has a snc_platform_rest_api_access role
  • Your ServiceNow Event filters and alerting rules are set to react to incoming events sent by Dynatrace
Your ServiceNow ITOM module and license need to be active to use this integration option.
  1. Go to Settings.
  2. Select Integration > Problem notifications > Add notification.
  3. In Notification type, select ServiceNow.
  4. Enter the requested information:
    • ServiceNow instance identifier refers to the "instance identifier” part of your own ServiceNow URL and is used by the ServiceNow API call https://<instance identifier>.service-now.com. This ServiceNow instance identifier is mutually exclusive to the OnPremise URL field, so you can only use one of them.
  5. Turn on Send events into ServiceNow ITOM
  6. Select Send test notification.
  7. Select Save changes.
After you enable the push of ITOM events, all events for any problem detected by Dynatrace will be automatically pushed to the ITOM event API.
View events
You can create event filters and alerting rules in the Event table view to flexibly react to incoming Dynatrace-detected events, as shown in the example below:
Events-SN
Events-SN
ServiceNow offers a dedicated Service Graph Connector for Observability – Dynatrace application for pulling Dynatrace observability information into your ServiceNow CMDB.
Service Graph Connector for Observability – Dynatrace pulls the following types of topology information data:
  • Hosts
  • Processes
  • Services
  • Applications
  • Kubernetes entities
  • Cloud entities
Service Graph Connector for Observability – Dynatrace uses the relationship between various applications, application services, and infrastructure elements to create a Service Map.
Some of the Dynatrace entity types are not imported into ServiceNow. For configuration and usage details, see Service Graph Connector for Observability - Dynatrace.
FAQ
General
Which Dynatrace IP addresses are allowed for ServiceNow integration?
For your Dynatrace instance to communicate with ServiceNow, you need to provide ServiceNow with a list of Dynatrace IP addresses that will be allowed to send information to ServiceNow. Dynatrace servers are distributed throughout various regions. The best way to ensure that you get the right IP addresses for your region is to look up the IP addresses by running the nslookup command. You must first create your environment in Dynatrace and then execute nslookup.
Example:
C:\>nslookup abc.live.dynatrace.com
Optionally, you can review the OneAgent download page to see the IP addresses for your region.
Dynatrace Incident integration
How does the integration work?
You can see an overview Dynatrace Incident integration in the flowchart below:
Incident flow
Incident flow
After configuring the application on both sides, problem notifications are pushed from Dynatrace to your ServiceNow instance.
Incident creation
Incident creation
The Scripted REST APIs module is the entry point of the Dynatrace information into ServiceNow. It pushes the data into the Problems import set table.
The Problems import set table automatically transforms any incoming Dynatrace-detected problem into an incident within the ServiceNow incident table.
Transform map
Transform map
When a problem is closed in Dynatrace, the incident is marked as Resolved in ServiceNow.
Which ServiceNow tables are filled by the ServiceNow Dynatrace application?
  • Dynatrace sends all detected problems into the ServiceNow incident table (incident).
  • All single events that are correlated with a Dynatrace-detected problem are sent to the ITOM event table (em_event).
  • The relationship between a CI and a Dynatrace-detected problem is sent into the CIs Affected table (task_ci).
  • If enabled, Dynatrace synchronizes all auto-discovered web services into the CMDB application services table (cmdb_ci_services_discovered).
  • All hosts and process groups running on those hosts are synchronized into the CMDB server table and derived Linux and Windows server tables (cmdb_ci_server), and into the process groups related tables in ServiceNow (cmdb_ci_appl).
How can I change the table or field where Dynatrace pushes the data?
Incidents are imported through an import set table (x_dynat_ruxit_problems). You can reconfigure the default transformation map Problem to Incident Transformation Map to route the information to different tables or fields.
Is there support for multiple environments in Dynatrace integration?
Multiple Dynatrace environments can be configured within the Dynatrace environments table in ServiceNow.
Event flow
Event flow
Troubleshoot
Check out the following articles in the Troubleshooting forum in the Dynatrace Community.
General
  • Events don't show up in the ITOM events table
  • HTTP 403 Forbidden Access Restricted Not Authorized Error when sending a test notification
  • Problem link is broken in the ServiceNow incident
  • Incidents aren't created correctly
  • Dynatrace-detected hosts, process groups, applications and services don't show up in the CMDB
  • Dynatrace-monitored servers don't show up in the CMDB
  • Incoming incidents aren't mapped to the affected server in the CMDB
Related tags
Notifications Classic
